• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Shows That Inspire Animations
    Here is the YouTube channel "48HFP CENTRAL" with entries, tips, etc.
    https://www.youtube.com/channel/UCgMcERvceOG0iuvS6kfzB7w
    By
    Steve K Steve K March 2021 in Carrara Discussion
  • HeadShop products DO NOT use DAZ Central or DIM installers, new how-to video posted.
    We would like to clear up some confusion. The DAZ product page of OneClick2021 erroneously states that OneCkick2021 uses DAZ Central installers. That is explicitly not true.
    HeadShop products come with their own installers and a README document that explains the simple install process.
    We have attached a version of the README to this article. Once installed, HeadShop launches directly from DAZ Studio under the Edit menu.
    Other links: How-to video: https://www.youtube.com/watch?v=FSGRVQn8upc
    Manual: https://printahead.net/wp-content/uploads/OC2021-Manual.pdf
    Thanks for your support!
    By
    info_b3470fa520 info_b3470fa520 March 2021 in The Commons
  • Babydoll 5576 error
    PerttiA said:
    NorthOf45 said:
    The Product Library page appears to be broken: no links for DIM or manual download, and the DAZ Connect Offline packages are MIA, which probably means the online version is, too. It is available in DIM (and presumably Central), but it is not recommended to mix Connect with other methods. You could do it temporarily and re-install with Connect once it gets fixed.
    As this is a V4 item (basically Poser), I wouldn't let Connect mess with it, since Connect uses non-standard paths for product installation.
    When you were searching the item, where were you searching, the database or the actual real folders (setting in DS search)?
    Connect works with Poser format content.
    By
    Richard Haseltine Richard Haseltine March 2021 in Technical Help (nuts n bolts)
  • Dforce Fur/Classic Cape
    dragoneyes002 said:
    Richard Haseltine said:
    Which version of Daz Studio is this? I suspect it's too old to support dForce hair.
    That Cubit look happens all the time when textures are missing. the same thing happened with Victoria 8.1 on launch day when DAZ had not rolled out the new starter essential update (unless you happen to use central)
    the cape is in the scene the fur colar doesn't have the Material its always possible the version is old but do old versions not load materials and textures even if they can't run D-Force?
    to the OP when you loaded the Cape onto the character did you get a pop up window warning you of missing files? or did it just load to the way you screen shot?
    Missing textures won't do that, missing geometry will - if the DS version is too old for dForce hair it won't know what to do with the instructions to draw the strands, which will have the same net result as not being able to find the geometry.
    By
    By
    dragoneyes002 dragoneyes002 March 2021 in Technical Help (nuts n bolts)
    By
    PerttiA PerttiA March 2021 in Technical Help (nuts n bolts)
    hmm... my research into this matter last night showed me that Connect often causes exactly these kinds of errors (or am i getting mixed up with 'Central?' - never used Connect or Central) so i'll just stay with DIM-only and wait it out i think. (it doesn't show up in my DIM)
    it was a Gen 2 item i got at a flash sale that i was wondering if it would work as the basis for a Gen 8 mesh-hack, but i'm partway into modelling my own now anyway.
    By
    clivewil2 clivewil2 March 2021 in Technical Help (nuts n bolts)
    By
    NorthOf45 NorthOf45 March 2021 in Technical Help (nuts n bolts)
  • DazCentral downloading files to external HDD
    patrickgobels said:
    Hello!
    With DIM I was able to download and update all installation files and figures on my external HDD. Is this also possible with the new "DazCentral"?
    PS: Those are installation files as a backup and not installed files for usage. I just want to avoid downloading everything all over again. I already have like 144 GB in my DIM install folder which gets recognized.
    Saludos
    Patrick
    You can change your content path in you Daz Central's preferences.
    Word of caution tho. You use either DIM or Daz Central. Not both of them together.  If you've already used DIM for you initial installs and current content, just stick with DIM. Using both can cause many issues.
    Daz created Daz Central to make it easier for newer users to install apps and content. Daz Central is supposed to be an easier version of DIM, however, Daz failed to synch Daz Central with DIM, so existing users of DIM can't transition into using Daz Central (yet, soon?).
    If you still choose to use Daz Central, I would recommend to unistall everything thru DIM (apps and content) and do a clean install thru Daz Central.
    By
    JVRenderer JVRenderer March 2021 in Daz Studio Discussion
  • The completely gratuitous complaint thread
    certaintree38 said:
    McGyver said:
    certaintree38 said:
    That is a neat idea. I will try using aluminum foil over the lights and see if that helps. Maybe I can cover some of the lights and leave some alone (there are 12 on just the fans!)
    Those house elves won't know what hit them devil
    The stuff that looks like aluminum foil in the picture is actually an adhesive backed foil used for sealing duct work... it's not regular aluminum foil... if you use aluminum foil, you'll have to back it with some sort of spray adhesive or double stick tape.
    It's probably not worth going out and buying a $6 roll of the stuff (aluminum tape), but I figured sometimes people might have some in their homes if they have central heating and air conditioning and had to repair the ducts.
    You could also use blue painters tape and color it black with a sharpie... that's fairly simple too. Just snip it into little squares poke a hole and stick it on.
    By the way, if the House Elves are getting out hand, SC Johnson, the makers of Raid bug spray have a new formula "Elf & Gnome" which is pretty good good at knocking down a bunch of them at once if you have an infestation... it's much better than using the glue traps or baits... especially if you've had one croak in the walls and have had to either break open the wall or just tough it out until the stink goes away.
    By
    McGyver McGyver March 2021 in The Commons
  • Dim?
    JVRenderer said:
    There are three choices :
    Manual Installation (advance)
    DIM (Daz Install Manager)
    Daz Central (Also Known As DIMmer)
    Amongst Daz' installation methods are such diverse elements as Manual, Daz Install Manager, Daz Central, and Daz Connect (the middle two being essentially the same, but Central is more locked down to make life easier for new users).
    By
    Richard Haseltine Richard Haseltine March 2021 in Daz Studio Discussion
  • Dim?
    Don't forget DAZ Connect (inside DS)... Although, based on what can be read here, it tends to make a mess out of everything laugh
    By
    PerttiA PerttiA March 2021 in Daz Studio Discussion
  • Dim?
    By
  • Where do I get G 8.1 F ?
    It's in the "Genesis 8 Female starter essentials".
    If you haven't updated that, run DIM/connect/central, and install the updated version.
    If it doesn't show up in DIM, Try a manual download and install from your "product page" in My account.
    By
    DrunkMonkeyProductions DrunkMonkeyProductions March 2021 in Technical Help (nuts n bolts)
  • send to zbrush not supported?
    Note that there is an issue with using Genesis 8.1, resolved in the latest Public Build (beta) - however you will have to use Install Manager to install that as Daz Central does not handle the public Builds.
    By
    scrap that!
    I just found out that it exists in Daz central, I just installed it. Sorry to bother :)
    By
    anikolo_5d6401c348 anikolo_5d6401c348 March 2021 in Daz Studio Discussion
  • Daz to Unreal Update 4.0
    3DRT said:
    DAZ_sam said:
    Currently DIM and Daz Central can only have one version able to be installed. You will be able to use the automatic install for 4.26 only right now. Until that is changed if you wish to get the older version's plugin you can find it here.
    Just download the zip-labeled builds and in there you will find the plugin for 4.25.
    The link David shared will be if you wish to get the backlog of old versions as well.
    https://github.com/daz3d/DazToRuntime/releases/tag/4.1.0-unreal
    Every release moving forward will be found on our GitHub as well.
    Will 4.25 still be supported going forward (i.e. will new features and fixes for the plugin be available in the 4.25 version)?
    We will be trying our best to keep 4.25 supported as long as we can but, we will be prioritizing updates on the most up-to-date version of the Engine.
    By
    DAZ_sam DAZ_sam March 2021 in Unreal Discussion
    By
    3DRT 3DRT March 2021 in Unreal Discussion
  • HeadShop OneClick2021 now at DAZ! (Commercial)
    Twilight2Shadow12 said:
    I got Headshop Oneclick2021, but so far it has been a disaster. I unzip it and run the installer. It crashes and deletes it's self. I then find that my anti-virus software has declared it to be a virus. I break it out of impound and try again. Crashes again saying it can't find VISETUP.INF. Checking in the 2 very much hidden directories the installer is looking in to find the said file, I conclude that no such file exists on my computer. I have about the same issue when I got the headshop before this one. It is getting far too frustrating! I already have a tech support ticket in, but doubt they will get back to me any time soon. Have searched and I seem to be the only person with this issue. I normal installer like DAZ Central would likely help, but who knows.
    Seems like such a great and useful product, but i greatly doubt I will ever get to use it.
    Did you read tghe README file? HeadShop DOES NOT install with DIM or DAZ Central.  It has its own installer.
    I am happy to help: please email to [email protected] or invite me on skype: lasloves is the skype name.
    By
    info_b3470fa520 info_b3470fa520 March 2021 in Daz PA Commercial Products
    By
    Twilight2Shadow12 Twilight2Shadow12 March 2021 in Daz PA Commercial Products
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
