Need help with Daz Default Paths and HD install problems
If you want to customise paths, rather than just set a single root folder, use Install Manager https://www.daz3d.com/get_install_manager/
Is the onyl chnage a new HD, or have you also got a new C: drive? By default the manifests that Install Manager and Daz Central use to track what is installed go on C: so a complete reinstall may have lost those.
AIUTO...CHI CONOSCE L’ITALIANO? PARTE TREDICIImago said:
Tiziano said:
Ho bisogno di AIUTO con il mio SMART CONTENT-PRODUCTS: una gran parte delle "copertine" dei prodotti sono sparite.
Nessun problema con lo SMART CONTENT-FILES.
Ho provato col CONTENT DB MAINTENANCE: RESET DATABASE e RE-IMPORT METADATA, e tutto va a posto, ma se chiudo e riapro DS il problema si ripresenta.
Ho addirittura disinstallato e reinstallato TUTTO, ma il problema non si è risolto.
Qualcuno ha qualche idea?
Cosa hai usato per l'installazione? DIM, Connect o Central?
Ho usato DIM. Il problema è sorto improvvisamente, senza che io installassi o disinstallassi niente.
Need help with Daz Default Paths and HD install problemsI am sure this has to be around somewhere, but after a lot of googling I can only find old information that is no longer relevant with the new Daz Central system. Here is my situation:
A couple of years ago I switched my Daz content to an external E:/ drive. I thought I continued to have the actual program still on my main computer and just had the paths point to my E:/ drive. It has all worked exactly as I wanted it to since then. However, I just bought a bigger HD to move my content and work onto. I figured since I was accessing the program via my computer, all I'd have to do is copy my content from my E:/ drive to my F:/ drive, point the directories/download paths to the new drive and be done.
Unfortunately, as soon as I logged into Daz Central, it wanted me to re-install. This made no sense to me as I thought the main program was always on my main HD (not my external one) and therefore Daz Central shouldn't be confused. I wasn't sure what was happening, but I went ahead and tried to install it again figuring it would install to wherever it was set to do so before and all would be well. It got to 64% multiple times and stalled. I then decided I must have been wrong and that the main program was being accessed from the old E:/ drive (it did have a Program Files folder with all of the default Daz Studio files on it, including the .exe) and so I figured it was a directory issue and set the Base Path Location on Daz Central to my new F:/ drive.
That worked, *however* instead of just updating the Program Files folder I had on my other external HD (see bottom for list), it created a new folder called Application with several subfolders and a whole other base default content library. I never had this Applications folder before on my original external hard drive and I do not want it now. I just want the new drive and folders to work exactly the same as they did before.
I have now uninstalled all of my Daz Studio stuff (hoping I don't regret it) from my hard drive and would like to do a fresh install, but I can't find anywhere that just explains where the default Base Path Location should be and Daz Central doesn't seem to have any kind of 'restore to defaults' option. I cannot find anywhere on my hard drive that has an Applications folder like the one Daz downloaded on my F:/ drive when I tried to point it there and I don't want to add more unnecessary Daz folders to my computer than I already have over the years.
TLDR: I would like Daz Studio and it's main components downloaded to my main computer hard drive and to simply have the download paths/content directories point to my F:/ drive. Also I would like to know the default Base Path Location Daz Central uses so I can try setting it back to that and see if that works.
For reference in case it's needed, my original E:/ external HD worked perfectly with only the following folders:
/My Content Library
/Install Manager
/Program Files
90%+ of March Madness Purchases Thumbnails Not showingPerttiA said:
Richard Haseltine said:
PerttiA said:
DMax said:
PerttiA said:
DMax said:
NorthOf45 said:
I you are installing from within DAZ Studio, you are using Connect. The missing thumbnails are a known problem right now.
I install exclusively via DIM and have the same issue :(
Are you using DS in online or offline mode?
There is no reason for running it online if you are using DIM, Central or manual installationAlwats used DS online ... have never considered using it offline ... always had the impression that it wasn't a good idea to use it offline?
Using DS online allows Daz Connect to retrieve 'updates' and generally mess with the contents, and as it uses different folders (non standard/non traditional) for saving stuff, while at the same time stealing priority over DIM installations, I would say it is far better idea to use DS offline than online.
DS won't install, and won't show any updates for*, content installed through DIM/Daz central/manually with the metadata imported. It will try to install products that, for some reason, are not showing as installed in the CMS (because double-clicking an uninstalled product is telling it to install). So having DS on line will not cause issues for content that has installed and been registerd by the system - if it does prompt a download then something is wrong further up the chain.
* nor will it install updates for Connect-installed products unless explicitly told to - Install update is not the default, double-click, action.
But, if DS looses thumbnails for previously installed products that have had working thumbnails, loosing the thumbnails is obviously related to DS being online => Daz Connect is to blaim.
Yes, metadata will get updated automatically (since it needs current metadata to work).
90%+ of March Madness Purchases Thumbnails Not showingRichard Haseltine said:
90%+ of March Madness Purchases Thumbnails Not showingAre you using DS in online or offline mode?
Good to know, I learn every day!
The only thing I have always ensured was... I never have DS and DIM running simultaneously, always conscientiously closing one program before opening the other.
Hopefully DAZ will resolve this missing thumbnail issue asap.90%+ of March Madness Purchases Thumbnails Not showingDMax said:
There is no reason for running it online if you are using DIM, Central or manual installationDAZ Central."I have defaulted to using DIM. Can anyone help with this please?"
Sounds like you already figured out the solution.
Daz Central has problems installing things. Since that's its main purpose, I haven't had much use for it.
DAZ Central.Every time I try to use DC I get a message stating that an update is available. (EVERY TIME) I am unable to ignore the update so have to accept, the little blue circle goes round and round seemingly forever until I get a message stating that the download has failed. I have defaulted to using DIM. Can anyone help with this please? Thank you................Have a nice day.
Need Help UberEnvironment2 missingIt is part of "DAZ Studio 4.x Pro" in your Product Library. It should be available through all delivery methods, whichever you use (DIM / DAZ Central / DAZ Connect). Look for "Default Resources for DAZ Studio 4.15+" and install like any other product.
[SOLVED] Manually changing product icons in Smart Content?dragotx said:
NorthOf45 said:
If you install with DIM, and everything is good, you do not want to log in from Studio. Ever. You do not benefit in any way from using Connect (that is what you are enabling when you log in). Lately it has been messing with the product thumbnails, as the many threads discussing that problem will attest, which is unfortunate, since it is entirely avoidable if you are using DIM / DAZ Central to manage your content.
The problem with that is ther are times that Studio just flat refuses to reconginze that something has been installed with DIM, no matter how many times it's uninstalled/reinstalled. It will not get added to the database, no matter what. When that happens, connect is the only option
I have installed 20,000 product packages, and I have had that happen maybe 5 or 6 times that I can remember. In each case it was either poorly packaged (wonky folder structure) or bad metadata. Each case required no small effort to clear up, but I figured it out. I have never used Connect, or ever logged in through Studio, for anything.
Problems with DIM on new laptopNorthOf45 said:
Okay, fresh minds work better.
dzInstall.ini is for DAZ Studio, so, since it isn't installed yet...
It's from a stand-alone installation of DS, not DIM/Daz Central.
90%+ of March Madness Purchases Thumbnails Not showingThank you both :) I was hoping for another in Daz solution. I have had nothing but huge, massive-I'm-going-to-quit-Daz issues with DIM and Central- a small part of which helped kill my hard drive (not that I'm still bitter or anything ;) ) I guess I'll be filling out a help ticket too because I don't want to touch DIM- it usually just introduces more problems instead of fixing anything for me :( But thanks for the suggestions!
Item Icons MissingI have been buying from the Daz Store and installing via Daz Central for a while but since yesterday any new items I have bought and installed are missing their package icon picture in the Smart Content Panel. There is just a question mark instead. The items work as they should but this is puzzling me....
90%+ of March Madness Purchases Thumbnails Not showingMy advice applies if you are using DIM / DAZ Central as your installation method of choice. If you wish to stay with Connect, then you will have to live with it until it gets corrected at the DAZ end. At this point, another help ticket might add some more weight to the problem. Mixing the two installation methods is not recommended for basic content, especially if using both for the same product. It will install twice (in different locations) and Connect has precedence.
