• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • DAZ Central not working
    Well, it could be that you have a full version of PostgreSQL installed - I'm not at all sure about that. Deleting the whole %AppData%/daz 3d/ folder removes all settings, so it could be Daz Central (perhaps an issue with the account file) or the CMS database (although it's possible Daz Central defaults to putting that in the [drive]:/Daz 3D/ folder) - try going into the folder and removing the Daz Central folder (which will test if it's the account file or the database).
    By
    Richard Haseltine Richard Haseltine April 2021 in Technical Help (nuts n bolts)
    Okay. Here's my issue:
    Every time I load DAZ Central, it states that there's an update for it, and if I don't update, it won't work. I click "Update," and it tries for a while, then states it can't download the update from DAZ at this time, and then works normally.
    Wouldn't really bother me, except it slows everything down by 5 miutes or so. DC has so many other problems (like timing out on downloading products, sometimes for hours on a sing;e product) that this is just one more bugaboo that seems like it should be an easy fix.
    My system is relatively stock, except that all my DAZ content is on a separate D drive, rather than crowding the C:\ OS drive with a lot of superflous items.
    ..Joe
    By
    joegerardi joegerardi April 2021 in Technical Help (nuts n bolts)
    cnoliver86 said:
    Oi! Daz Productions! Fix your stupid software. It doesn't work!
    It runs the first time I load it after installation on Windows 10, then it just loads forever if I try to open it again after that.
    I've tried rebooting, deleting AppData and reinstalling multiple times. It doesn't work! Fix it!
    I've subscribed to your Platinum Club, and I've tried emailing your support email address from your website (which doesn't exist).
    But I'm very skeptical about all of this at the moment. You're pushing software that doesn't run.
    Fix it!
    Provide enough information to diagnose the issue!
    Peremptory demands aside, and assuming you are looking at Daz Central since that is the subject of the thread, what are your system specifications? What security software are you running? Is theer an error message of any kind in the window that opens (assuming one does)? If you check Task Manager, with the more details option enabled, are there any PostgreSQL processes listed in the background process list?
    By
  • Daz Studio and Linux
    can somebody do a step guide for what to do now that we are using Postgres 12? it would help if we could get a central Guide for keeping it running. thanks and have a good day!
    By
    deanetruelove deanetruelove April 2021 in The Commons
  • Exporting all content of a scene to a folder
    A couple of other things that I only remembered after the fact...
    The beauty of CG was it is able to locate all files used in a DAZ Studio project file; the auto adapted data files, custom textures, imported models, and 3rd party models.
    When you create a ZIP archive of the used files, CG will recreate the directory structure, even if it spans multiple install locations / drives. This way when you unzip the archive, all the files will be in the right place and DS will see 99% of them automatically. So no "unable to find file, locate?" messages.
    If you unzip to a place that is recognized in the Content Manager then this is even more foul proof as all the Data and Runtime files unzip to where DS expects to see them.
    The problem is that CG was designed for 2013 era DS save files; so it doesn't know how to handle DAZ Connect or (most likely) DAZ Central files. There is also the potential that future DS versions will change the way Save files are written, which would most likely break CG. With the developer deceased, it's unlikely to be updated.
    The product description really should be updated to reflect the lack of DAZ Connect compatibility, but it is what it is.
    By
    Jason Galterio Jason Galterio April 2021 in The Commons
    Keep in mind that Content Gatherer does not work with DAZ Connect items and may not work with DAZ Central.
    If you are going to buy it, try it out immediately after purchase to make sure it works. It was released in 2013 and may not keep pace with current DS releases.
    By
  • NFT and the Future of Digital Content
    JStryder said:
    You are certainly right about the economics of immutable records! Ethereum technology does allow for storing any data or code you please, though. I haven't tried to store a GIF on the blockchain myself, so I'll have to take your word that it would be too expensive for images or short video clips. My point was more about possession: if you control the token but not the asset identified by the token, what do you really have? It all depends on the rights associated with the token; which if not clearly defined in a contract that will likely be respected and could be enforced if necessary, mean nothing.
    The value of an immutable record of an identifier (which is what a hash is: an identfier, like a fingerprint) is to prove that the thing identified existed at the time the record was made. Proof of original creation can have actual value in an IP context, but rarely; and usually other records and witness testimony suffice to prove who created what and when if needed. Immutable records are great for financial and ownership ledgers; everybody understands that. The immutability of its ledger coupled with the transparency of its protocols is why Bitcoin has become so valuable -- it is perceived as more trustworthy than the Central Banks of the world. More Bitcoin cannot be created than the protocol allows, and banks are not needed to keep the records.
    This is a bit off topic, but NFTs could have real value as transferable tokens redeemable by presentation to the issuer. Essentially we could each issue our own money, in the form of tokens to perform some service, e.g., mow the lawn, etc. The value of our tokens would depend on the demand for the services we offer, our reputations as trustworthy providers of those services, and the number of tokens we have issued. This would be a truly beneficial use of NFTs that would free a lot of people from debt slavery and allow all people to keep the fruit of their own labor. All the hullaboo about speculating in NFTs for digital art feels like noise to me, and a distraction from the true social benefit of blockchain ...as explained more fully in my book. If we are going to tokenize anything, we should tokenize and keep our promises. Better to just keep our promises without tokens...but memories and mores being what they are, we need records of those promises that can't be back-dated, hence, blockchain and tokens.
    NFTs at DAZ will fade away, just as their foray into 3D-printable models did. They should stick to their knitting.
    I am just generally mistrustful of solutions that boil down to, "If we can only accomplish total social upheaval and are totally correct about this technology encouraging the better angels of humanity's nature, the benefits will be incalculable!" In my experience it's a really hip way for people to justify total self-interest. Problems in the now are boring and hard and solving them is thankless. The world doesn't crown you King Genius for doing it--you get condescended to and told to shut up and even hurt. You may have to help people that don't like you and won't be grateful. When you bring up issues and offer solutions you have to fight to get anyone to take you seriously instead of being applauded and praised. You don't get to give the keynote speech and there's a good chance it hurts your livelihood instead of supercharging it.
    But if you just believe in a technology so transcendent that it changes everything, you don't need to worry about the now. Shouldn't the priority be doing the thing that will solve hundreds of problems at once, and isn't it more ethically sound to push it forward as quickly as possible?
    This is a very seductive mindset because it lets people envision themselves as powerful protagonist visionaries, solving the world's problems by (coincidentally) doing things they think are exciting and making a lot of money. It's a morally unimpeachable position, because when someone points out that they're not doing anything to help, this protagonist figure gets to say that they are in fact Superhelping™ by taking the long view and it's actually everyone else delaying progress by getting bogged down in the now.
    It's a mindset that ruins businesses constantly in addition to scrambling social movements. My former boss was head of a mid-tier studio and he was so dead sure that we were going to build the metaverse that he tried to sunset the product that was keeping our lights on for basically no other reason than that he was bored of it and wanted to revolutionize our industry instead. This was an older guy with a decent career record who had held power at a company you've probably heard of and founded another one successfully. He was considered smart and given tons of leeway even as the projects got restructured and rescoped and everyone was panicking because only he knew what he wanted out of them, and he hadn't seen it yet. He oversaw the very first round of layoffs in over a decade of operations. If we hadn't been a subsidiary of a company that finally, eventually pulled the reins, he would have moonshot us straight into the ground. All because the core product needed some serious investment and problem solving, and it was much more in line with his personal narrative to start over Better and New.
    He wasn't fired and he was allowed to stay on long enough to flounce away, still feeling like a misunderstood prophet. The core product is only now being treated as the breadwinner it is and developed accordingly, because it's all there is.
    It would rule if someone with decision-making power read and thought about this.
    By
    plasma_ring plasma_ring April 2021 in Non-Fungible Token (NFT) Art
    JStryder said:
    Mark_e593e0a5 You are certainly right about the economics of immutable records! Ethereum technology does allow for storing any data or code you please, though. I haven't tried to store a GIF on the blockchain myself, so I'll have to take your word that it would be too expensive for images or short video clips. My point was more about possession: if you control the token but not the asset identified by the token, what do you really have? It all depends on the rights associated with the token; which if not clearly defined in a contract that will likely be respected and could be enforced if necessary, mean nothing.
    May I ask you as a person familliar with law (I am not): how do you enforce your rights? On an NFT? For tangible items, all the law systems in the world have some - more or less - efficient ways that the ownership of such an item can be ensured. That is even valid for intangible assets like IP, because there is an international agreeent an that (the international agreement of Paris from March 1883, IIRC). There is no international agreement that I am aware of regarding NFT's. So, do you really "own" such an NFT if there is no way to legally enforce youre ownership?
    By
    Mark_e593e0a5 Mark_e593e0a5 April 2021 in Non-Fungible Token (NFT) Art
    By
    JStryder JStryder April 2021 in Non-Fungible Token (NFT) Art
  • Error in loading Daz Central
    Hello...Error question...When loading the DAZCENTRAL I answer all(not many) requests and wait for it to load and run I get the error THIS APPLICATION UNABLE TO START.Error( 0xc000007b)..Something on my end needing correction?...
    By
    wade.rittiner2018 wade.rittiner2018 April 2021 in Technical Help (nuts n bolts)
  • I'm a Daz3D old-timer who isn't easily impressed, but
    Yeah, I still install through DIM, maybe out of habit I don't know, but then when I'm working on stuff I keep Daz Central open because usually the stuff I need to use I bought more recently and it's a heck of a lot easier to find and or jog my memory of what I have when I tab over to it and scroll through everything. I think it's a wonderful addition as well.
    By
    benniewoodell benniewoodell April 2021 in The Commons
    I resisted using DIM for a while, installing content manually. In the end, it was just simpler and easier to use DIM. Then I resisted using Daz Central for a while, installing content using DIM. I recently tried Daz Central and found it to be user friendly and not at all that difficult to use. Some advantages I noticed of using Daz Central on my old hardware rig:
    1) Loading Daz Studio Pro is faster from inside Daz Central. I don't know why. Never mind.
    2) Visual display of Daz3D assets in my library (compared to text-only listing in DIM and a few additional steps to get to a product page to see what the item is).
    3) Loading of assets into Daz Studio via visual display (convenient).
    DIM and DC compliment each other.  I still prefer controlling installations using DIM. But loading content and checking assets is so much easier using DC.
    By
    ibr_remote aka infinity10 ibr_remote aka infinity10 April 2021 in The Commons
  • I love the Invisible Chair
    Bummer... It's Daz Central only...
    By
    PerttiA PerttiA April 2021 in The Commons
  • Downloading issue with Daz Connect, I might have messed up
    It doesn't matter which method you use to install, you will get the same Smart Content (which is a function of the metadata) so you won't be missing out on anything.
    I am a little confused, though. You say "the separate DAZ Connect software". Connect is built-in to Studio, not separate, and is used to install from within Studio when you login to your DAZ account. That is the one with the thumbnail problem right now. Note: the Product thumbnail is the one that would show the left side of the tree you show in the attachment, and not the thumbnails for the individual assets shown on the right.
    External installation can be done with DIM or DAZ Central, but installs to a different location than Connect.
    Just to make it clear, could you show a screenshot of where you install your products from?
    By
    NorthOf45 NorthOf45 April 2021 in Technical Help (nuts n bolts)
  • DAZ Central
    Anyone know why DAZ central can take over two hours to install a single prop? I've been trying to install the Fantasy IBL Sandy Beach for over two hours now, and it downloads a little bit, the install cancels, I restart. Rinse and repeat. In fact, since starting to write this post it's cancelled once again. Up to 76% downloaded.
    Not just this one, it happens all the time. I actually manually downloaded the above prop in about 7 minutes while DC was running, trying to do see if it was my pipe. It's fine.
    The first time ever I use the DAZ method, (I always manually installed before 4.14) and it seems my unwillingness to trust DAZ to do omething right is still justified.
    ..Joe
    By
    joegerardi joegerardi March 2021 in Technical Help (nuts n bolts)
    GiGi_7 said:
    Jason Galterio said:
    GhostofMacbeth said:
    Jason Galterio said:There is also the tendancy for DAZ to abandon initiatives...  Example: going from DIM, to Connect, to Central. With very little notice or documentation. Instead of improving on a base, a new base is devised and that gets the attention. And usually just inherits the flaws of the previous bases.
    DIM hasn't gone anywhere. That is all I use. Each of the others was an attempt to make something that was easier and more approachable for new users. But DIM has always been there.
    I know it hasn't gone anywhere, but it certainly hasn't progressed either. There's been no major updates to its functionality, no real user manual. And, instead, the resources were tossed to Central and Connect.
    If they really wanted to introduce DRM, why wasn't it just included into DIM? Instead of creating a brand new method for distribtution? That's what I mean about being abandoned; supported but not improved.
    DIM is updated in parallel with central, they share code. I wouldn't call progress to Central anyways, it was a beauty "mutilated" DIM the last time that I try it.
    About DIM versus Connect, believe me, some times is better build a new thing than try to modify and old thing. I hate each time my boss want  a new unplanned changes of paradigm on codes because the result is a complete mess of unnecessary workarounds, being better begin from zero.
    I can understand that...  However, sometimes its a good idea to try and get the foundation correct. Instead of endlessly taking new shots at the pitch that go no where.
    If DAZ really wants to attract new customers they need to work on the user interfaces and the learning curves.
    That DIM can't do something simple like "show me G8 Characters" is embarassing. Of course a new user can't make heads or tails out of things. I mean it should be common sense; show me what hair I can use, show me what wardrobe I can use. That that functionality seems alien and worthless to DAZ means that they just don't understand their customers.
    That product organization standards have never been enforced in 20 years...  that's just criminal if you expect new users to become regular users.
    By
    Jason Galterio Jason Galterio March 2021 in Non-Fungible Token (NFT) Art
    By
    almahiedra almahiedra March 2021 in Non-Fungible Token (NFT) Art
    Improved can be a double-edged sword in the land of Daz. Not saying it can't use some improvements (I would like the ability to see a thumbnail, for example) but, from past experience, if they were to improve it there would be a huge uproar and the sky would be falling for certain users. Daz has never really be strong on user manuals, that is just a "Install, done" kind of thing so maybe they didn't think there needed to be one.
    Sadly, you are quite correct here. I would love to one day be able to have meaningful search and filtering functions, but I know thats just a pipe dream.
    By
    By
    GhostofMacbeth GhostofMacbeth March 2021 in Non-Fungible Token (NFT) Art
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
