• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • RSSY 3Delight And Iray To Filament
    It will never look like the Iray render, not is it intended to.  I think a fairer comparison would be what it looks like in Filament before and after running the script.
    By
    Sevrin Sevrin January 2021 in The Commons
    Charlie Judge said:
    This looks like it will be extremely useful. Howver, considering the price, I would be interested in comments and seeing renders from people who have purchased it. How well does it actually work and how easy is it to use, etc.?
    Well I tried it first with this picture:
    Original:
    Black Girl sitting in front of another Black Girl
    And with the conversion tool:
    Then I tried this one:
    Original:
    Black Girl on her knees in front of park bench
    In both cases, I loaded the original scene, clicked on the script, chose to scan for items and scan for matches, and had the box checked to update the materials. And in both cases I dragged the exposure slider in the script dialog to try to get the brightness level to be similar to what I remembered the originals to be like. I don't believe I changed any other settings from the default. This was my first and second attempt at using the product.
    By
    NylonGirl NylonGirl January 2021 in The Commons
  • {Solved} Dark object rendering [Light does not catch it]
    I'm not using Filament. I do render in Iray. One of the easiest ways to get some decent light on targets is by making some "spheres" [under the Create menu]. You can create one, after fixing it to be light, make instances of it and rearrange those instances wherever you please.
    On the surfaces tab, select Emission and change the colour to white. More options appear, adjust a few. Then on the geometry dial, set opacity to something like 0.00001.
    The further away the light source is the softer the shadows edges might be. [just like real life lighting]
    By
    Catherine3678ab Catherine3678ab January 2021 in Daz Studio Discussion
  • [Released] RSSY 3Delight And Iray To Filament [Commercial]
    It seems to support Genesis 8 only, I was seeing seams on a Gen 2 figure. Is this an inherent flaw in filament, or is this something that can be fixed?
    By
    MarcCCTx MarcCCTx January 2021 in Daz PA Commercial Products
    Hello, I have adjusted some parameters (Light,Camera,Shader) but they did not work out the way I want
    The first picture is an object on viewport with texture shaded.
    The second is a rendered one, there are lights on the object but it just too tiny (this is a thread, help please)
    The third is when I change to "Dome and Scene" then rendered. Most of the time I stay on "Scene Only"
    The forth one is with "Filament(PBR)" on viewport, this is what after render suppose to be for the finish result
    so, any suggestion would be great
    regard,
    Steve
    By
    stevejinta stevejinta January 2021 in Daz Studio Discussion
  • Daz Studio Pro BETA - version 4.15.0.30! (*UPDATED*)
    jbowler said:
    There seems to have been a correction to the 2EV overexposure problem in Filament rendering; I'm still checking that out but the viewport Filament rendering is now much closer in exposure to the Iray render.
    That's incorrect.  The 2EV bug with respect to dome (Environment Map) illumination is still present.
    By
    jbowler jbowler January 2021 in Daz Studio Discussion
    I can't get my head around the create conversion/expression. It probably isn't helped by the fact that I don't really understand coding.
    I've also been looking over one of my Filament scenes, and I've got a few items in the scene that are metal. However, the Filament converter isn't converting the items to a metal (filament) shader, but just the "basic" Filament Shader.
    By
    N-RArts N-RArts January 2021 in Daz PA Commercial Products
    It looks like no improvements have been made to the long open/load/close times in 4.15.  Here are the results from timing (mainly based on times in the log file) for a test scene with architecture, props, a dome, 2 G8F and one G8M:
    Scene load time: 4:04.371 (from log file)
    DAZStudio close time: 3:58.118 (from log file; "Deleting Scene" to the last entry in the log file).
    Close time with my work-round: About 1 minute (based on the time from the end of the load to the last entry in the log file - almost exactly 1 minute).
    By
  • The Mac FAQ
    I saw the new version, 4.15, a few minutes ago.  I'm also waiting to see how well it runs before/if deciding to update to that version.  Still running 4.12.0.86 on a 2015 Mac mini (Sierra) and a 2020 MacBook Pro 16" (Catalina).
    And waiting to see if Filament is in 4.15. :)
    Lee
    By
    Lee Moon Lee Moon January 2021 in Technical Help (nuts n bolts)
    Does this tool change the materials of characters skin and hair for filament rendering?
    By
    ALLIEKATBLUE ALLIEKATBLUE January 2021 in Daz PA Commercial Products
    Artini said:
    Just got it. Waiting for some more experienced with filament than me, to show up the renders.
    Thanks @Artini!
    By
    RiverSoft Art RiverSoft Art January 2021 in Daz PA Commercial Products
  • More Non-photorealisitic Renders (NPR II)
    Having fun with Filament  - Daz Outline (script) render and Photoshop
    By
    juvesatriani juvesatriani January 2021 in Art Studio
    I am actually hoping DAZ will just add emission to their version of Filament
    By
    WendyLuvsCatz WendyLuvsCatz January 2021 in The Commons
  • Daz Studio Pro 4.15 - Highlights
    4.15.0.2 (January 7, 2021)
    • NVIDIA Iray
      • Integrated Iray 2020.1.3 (334300.6349); see this thread for more detail
        • REQUIRES: NVIDIA Driver 451.48 (or newer) on Windows; see NVIDIA Driver Downloads
          • NVIDIA recommends installing Studio Drivers
      • Added support for tinting environment light
        • Control color via Environment > Dome > Environment Tint
      • Added support for controlling ground reflectivity/glossiness
        • Control color via Environment > Ground > Ground Reflectivity
        • Control glossiness via Environment > Ground > Ground Glossiness
      • Added support for controlling whether or not the environment ground can be seen through
        • Control via Environment > Ground > Ground Visible from Below
      • Added support for visualizing an Iray Section Plane node in the viewport
        • Control color via Display > Scene View > Plane > Plane Color
        • Control opacity via Display > Scene View > Plane > Plane Opacity
        • Does not influence Render Settings (NVIDIA Iray) > Section Objects > Section Caps Color, only what is drawn in the viewport
    • Real-Time Rendering
      • Filament (PBR) DrawStyle
        • Shader/Material Support
          • Automatic translation of specifically named properties in the PBRSkin (MDL) shader:
            • Translated property names:
              • Metallicity Enable, diffuse_enable, Diffuse Enable, Dual Lobe Specular Enable, Dual Lobe Specular Roughness Mult, Specular Lobe 2 Roughness Mult, bump_enable, Bump Enable, Makeup Enable, Makeup Weight, Makeup Base Color, Makeup Roughness Mult, Detail Enable, Detail Weight, Top Coat Enable, Top Coat Bump Weight
    • Shader Mixer
      • Texture Instance brick
        • Added a "Image Polarity (MDL)" setting
        • Added a "Is Polarity Flipped (MDL)" output parameter
        • Added a "Has Mapped Value" output parameter
      • Comparison Operator bricks
        • Fixed RSL version of comparison operator bricks (<, <=, >, >=, ==, etc)
        • Bricks (Default) > Functions > Mathematical > Operators
      • Dynamically Hidden Parameters brick
        • Bricks (Default) > Functions > Utility
      • Is User Parameter Mapped brick
      • Drag and drop events between brick inputs/outputs in order to establish connections are now validated by both sides of the connection
      • Added tooltips to brick input connectors
        • Provides the brick title and output parameter label for a connected input parameter
    • Preparations toward migration to a considerably newer version of the application framework (i.e., Qt)
      • Changes made should have no discernible impact on use of the application
    • Scripting API
      • Made additions in various areas; see the Change Log for more detail
    • Fixed bugs and/or made improvements in various areas; see the Change Log for details
    By
    rbtwhiz rbtwhiz January 2021 in Daz Studio Discussion
    I can set up scenes too in Filament and do, where this could be useful is those sets with hundreds of emissive surfaces such as Urban future 7 or other neon city scenes.
    I will probably pick it up eventually but yes not a huge priority at the price it is, there are other things I want more badly.
    By
    By
    Artini Artini January 2021 in Daz PA Commercial Products
    RiverSoftArt said:
    Martial said:
    Ok i got it now
    It is fast but Iray rendering is much better according the comparaisons i did today
    Oh, I agree.  Iray is what I use (and I have a 2080Ti so it is not terrible to render).  But if I ever start doing more animations, I would use Filament for pre-viz.
    Yeah, one of the big complaints from animators is that it took them ages to find out if their animations even worked, because rendering was so slow.  Iterating was also a huge pain for the same reason.  If you're mostly interested in that, Filament is a great solution.
    By
    Sevrin Sevrin January 2021 in Daz PA Commercial Products
  • Render a filament scene
    Martial said:
    Ok i got it now.
    It is fast but Iray rendering is much better according some comparaisons i did today
    Yes, of course. Filament is handy for quick scene evaluations and for animation, because it is quick. It is not intended to be a competitor to Iray for quality. You pick, based on your need: top speed (Filament) or top quality (Iray).
    By
    barbult barbult January 2021 in Technical Help (nuts n bolts)
    Martial said:
    Ok i got it now
    By
    SimonJM said:
    Martial said:
    Thank Simon JM for reply
    On render setting  i see on editor these options
    View port
    Multi pass openGL
    NDvidia Iray
    3Delight
    script 3Delight
    Which is for Filament rendering ?
    As was said, pick Viewport, but ensure the actual viewport has Filamnet selected first!
    Thanks @SimonJM and @MoreTN!  What they said.  laugh
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
