• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Daz3d to Unreal Engine Bridge
    1. The physics asset generated from the import of Genesis 8 figures doesn't work out of the box. Trying to simulate ragdoll physics breaks the model completely.
    2. Certain Morph targets that change the size of Genesis (like "Height" ) will only rescale the mesh but not the skeleton. This causes animations to break when those morph targets are applied
    1) Yea, the autogeneration doesn't work well with the Daz Assets currently.  If you right-click on the Skeletal Mesh and go to Create -> Create Physics Asset you should be able to play withe settings and generate a new one.
    2) I haven't figured out a good fix for this.  If you don't export these morphs specifically, they'll be baked into the character and that works correctly.  To modify the size of the character in Unreal I scale the skeletal mesh and this seems to work.  It's not a perfect answer though.
    By
    David Vodhanel David Vodhanel September 2020 in Unreal Discussion
    A couple things I noticed while using this plugin:
    in the case if "height morphs i would recomend you to export the character "with the morph already applied it's because how the morph was made, the better way to "rescale a character size in unreal is you direct "re-scale his size by using the tool of scale in unreal unless the size is something with come with a shape like a morph to make a dwarf, would be more right to "use the morph and make the dwarf in daz them export the "dwarf" to unreal than use the morph to turn the character in a dwarf, it's more like a daz issue than unreal, or how the morph is applied in the mesh.
    the physics i've already talked with the creator and he told which is on his "to do list, then until a proper fix come you can use those videos as base since daz characters have a "skeleton which near the same as daz skeleton:
    those videos can help you to setup a proper ragdoll physics, use then as base since character creator and daz are not exactly perfect the same stuffs, then you need to do some extra adjusts in the numbers until you feel happy, but overal they help you to know how to setup all the ragdoll capsules and constrains inside unreal.
    By
    Ellessarr Ellessarr September 2020 in Unreal Discussion
  • Tutorial: Eliminating file bloat and morph slider performance issues
    Also, I'm guessing I have a LOT more morphs and expressions than you, and chose to keep more of them, because my file went down from 8.5GB to 149MB.
    Its just the face morph... ? I cant find the body morphs...
    By
    jeronimocollares jeronimocollares September 2020 in Cinema 4D Discussion
    By
    3DRT 3DRT September 2020 in Unreal Discussion
  • Help with body injection morphs for Kids 4
    Kid 4 might install, but it won't run the script to create the ExP files. Not sure if they would stick around if you ran it manually, Connect likes to stay in control, from what I hear. You could probably load K4, but no morphs would work.
    The problem is not the script, it's that Connect installs each product in its own content structure, while Exp morph system used by generation 4 figures needs all the morphs data files to be in the same Runtime to work.
    Ah, okay. I should stay away from any discussions that involve Connect, anyway...
    By
    NorthOf45 NorthOf45 September 2020 in Daz Studio Discussion
    By
    Leana Leana September 2020 in Daz Studio Discussion
  • The completely gratuitous complaint thread
    Working on learning zBrush again,  thinking about picking up Blender in the (far) future to serve as a suppliment and/or replacement for Cinema4D (Since I never did upgrade from R13 Visualize before they went Subscription-only...)
    If I get Poser,  can you use that to make content that can be shared around?  It was always a mystery to me how people make those Morph Packs, or even the creatures themselves.  All very far-future thinking right now though~
    By
    Rezca Rezca September 2020 in The Commons
  • Black Is Beautiful II
    This is Enayola by Deva3d, she comes with the red fantasy skin and the pointy ears morph. :)
    By
    deathbycanon deathbycanon September 2020 in The Commons
  • what is the hardest part about creating quality characters for G3/G8?
    From a customer prospective
    I'm probably in the minority from what I've read in the forums.  But here's how I create my non-photo real comic book characters.
    1.  I render in 3Delight. (my average scenes with 5-10 characters render in under 10 minutes.).  I used only V4/Genesis until about 4 years ago then moved to G3 (still in process for a lot of assets).  I won't be moving beyond G3 I imagine.  It was too much work getting to this point.  Other than some SASE characters that maybe I'll get and convert to G3 someday, there's really nothing in G8 that looks worth the effort.
    2.  I get rid of all maps other than diffuse and specular.  Specular maps are generic for all my characters that share the same UV set.  All shaders are either Daz Defaults or Ubersurface.
    3.  Resize all maps to be 1024x1024 at the max.  Backgrounds might be bigger, but no character/prop/environment maps are.  I see people debating 4k and larger here; for me, 4k maps just mean 16x more memory eaten up that won't be reflected in my final panels.  Plus most of my map library is quite ancient, from back in the days when 256 and 512 were the norm so 1024 was kind of edgy.
    4.  Dial in some basic morphs that get me kinda close to what I'm looking for.  I'm one that resizes my 'citizen' females down to be somewhere in the 61-69 inch height, guys range from 65-72 inces.  My heros/heroines are in the 69-81 inch range.
    5.  Export to a modeling program for all the detail work.  Personally I love symmetry, it's aesthetically pleasing.  I even want my villains to look good.  Not sure how making something less attractive makes it better, but whatever.
    6.  Use a graphics program to tweak the diffuse of the skin to make it 'unique' somehow.
    7.  Re-import as morph for G3, erc freeze, save as morph, apply textures and save as character.
    I've made around 200 characters this way.  Someday I may get the nerve to actually post one of my comics somewhere :/  For now their adventures live on my hard drives alone.  I've been a 3d hobbiest for about 30 years and Daz for about 10.  I'm no Sickleyield, but I know enough to make what I like.  If you are just starting out making things, there is a learning curve.  Be ready for it and don't let it frustrate you.
    Disclaimer and mini-rant: I'm not a PA and I only purchase a couple of things out of the store because what I'm looking for I haven't seen for the most part, and it's getting worse by the week.  Like dforce, which seems to have given license for the creation of poor quality assets that don't fit properly or look good, with the expectation that the customers will be fine waiting around for a simluation to run to fix it, every time the character is moved.  Where as I can just use an older non-dforce asset that fits properly in the new stuff's place, modify a couple of material maps to make it look different and render immediately after each pose.
    By
    Gazzalodi Gazzalodi September 2020 in The Commons
    Unfortunately, it's not there.
    You don't have the base Kids4 body part selected in the Scene pane.
    Or in the one that says "morphs" when the base is selected.
    You don't have the "morphs" section selected in the Parameters pane.
    Unfortunately, installed Generation 4 morph sets (which includes Kids4) don't work with Connect. Use any of the other installation methods. This is probably why you're having this problem.
    By
    SpottedKitty SpottedKitty September 2020 in Daz Studio Discussion
    1) An actual personality. Far too may items have generic and bland looks, with zero personality to them. A huge part of this leads to...
    2) The face. Give the poor girl a memorable face. Don't just go for the typical BS button-nosed and high-cheekboned doxie - give the character a bit of a big/prominent honker, or a serious overbite, or somewhat bigger-than-usual ears... nothing that makes it plug-ugly, but just enough to make it stand out. The Goal is to rig it so that the individual components are a touch out-of-beauty-standard, but when combined makes for something very pretty. Finally, make sure that the face and personality match the texture! Spend the vast majority of your time on this part of the body if you're serious.
    3) Asymmetry. Very few human beings on this planet have perfectly symmetrical eyes, boobs, nostrils (seriously!), ears, etc. Kick parts of the face and body just a hair off-kilter, like make one eye 0.1 - 0.5 higher than the other. Make one boob a half cup-size smaller than the other and hike it up a centimeter or so on the chest in relation to the other. Oh, and speakin' of mammaries...
    4) Mammaries Based In Reality. Real women do not have massive balloon-like breasts that defy gravity and logic. Make the 'girls' *normal* sized, or explore making them smaller-than-usual, like a B-cup or A-cup.
    5) Proportions. Most women are shorter than most dudes, so shove in a default G8 Male to compare against there. Give the girl a few pounds here and there, depending on what the character is and does. Don't be afraid to get a small/reasonable muffin-top action going if you're handy with making morphs by hand. Most women won't admit it, but unless your character is a teenaged girl fresh out of puberty (or some angular-as-hell hardbodied triathlete, or a scrawny transsexual person), there's gonna be a bit of belly there. Part of what makes most women... a woman.  Oh, and leave at least some waist there, please?  Oh, and it wouldn't hurt to shrink the chest and/or monkey with the shoulder width... the 80's shoulder-pad era is dead, and should stay that way. Finally, the head needs to be in proportion woth the body, and not that tiny alien-head that the defaul Genesis 8 character comes with, so don't be afraid to scale it up a touch.
    6) A Damned Solid Skin. Seriously, this is where a lot fo characters fall mega-short. The texture (and any/all makeup and eye-color options!) should match the personality of the character you're building. I don't mean the obvious stuff like slapping a freckled Irish girl's tecture on a Korean girl's head-mesh... I'm talking the subtleties. If your character is tomboy-ish, then the makeup options should be either very sparse or very over-done (or how about both options? Oh, and don't forget an option with no makeup.) Dig into (or discover!) the ethnic makeup of your character, then go look at photos of real people with the same ethnicity - and get the entire range so you know where your boundaries are. This works even in mixed-race folks. For instance, if, say, my character is half-Black and half-Latina, then I gotta dig into the facial structures for both, blend them in a way that makes sense, but then I dig into the skin tones and find one that makes sense, blend them in a way, ensure the eye color makes sense (yeah, no baby-blue eyes here by default, folks!), and etc. Now for the technicals:  Make triple-certain that your skin will show well in a wide range of lighting circumstances - for both 3DL and Iray versions. I've lost count of the texture kits that look like utter garbage in anything other than the default DS Skydome lighting. Don't get stupid with the pores - I don't need a close-up of her face to resemble a close-up photo of the Moon's surface, and over-poring (is that a word?) tends to exaggerate texture deformation when a joint bends. Don't get stupid with the rez - you do not need a 12,288px x 12,288px shader set.  Unless there is a sudden spike in users who play with DS on 84" 8k UltraHD television sets, 2048x2048 will work just fine for most users, and maybe put in an HD option with 4096x4096 if you want to futre-proof things.
    6a) Don't 'Help' The Skin! What I mean is, don't put in genital textures, don't put in knee wrinkles, don't put in the creases between butt-cheeks and legs, and in general don't paint on anything extra to simulate what movement should be simulating. This actually helps photorealism, because you're not seeing an out-of-place butt-crease on a bent-up thigh, or knee skin wrinkles on a knee that's fully bent, or under-boob lines on a breast that's streched upwards (hey, some folks do nudes, go figure, right?) Point is, don't 'help' the user/customer out. It only leads to headaches.
    7) Get to Know The Personlet You're Creating. The whole process of building a character is like getting to know someone. The deeper you get into the details, the more you come up with and 'discover' about the little person-ish thing that you're building. My favorite way to do this is to build something that sort of stands out, then invent a whole backstory about that person. Then I go back in and tweak it. Then I fill out more details... then go back in again if needed.
    8) Leave Room For Change. If you're making something for yourself you can ignore this, but if you're making something for sale, you need to take this into account. Once you're done making something, toy with it a big - make it fat, make it skinny, make it pregnant (not like that you perv!), make it a midget, make it a giantess, make it a child, make it an old woman, etc... if you make a character morph too rigid, then changes made by a customer will be disappointing to say the least, so do some testing on that beforehand.
    Gone on too long here, but hopefully this helps a bit.
    Cheers!
    I disagree with lots of this, but that is key to what rawart posted, everyone has their own ideas. One of the great things about DS is you can change what you want with other morphs, textures, hair, etc, so no need to strive for perfection  since it technically doesn't exist. I never use any body morph that comes with any character I have purchased since I have my own that i have developed and prefer.
    BTW as for number 4 on your list, more than half the women I interact with in my life have implants, including my GF and my sister. Some are more pronounced, some are more subtle. the point is, they do exist in real life, just maybe not where you live.
    I agree with at least 90% of what the OP wrote. And I don't use any figures "out of the box" too, using morphs to make them into "characters" (see what I did there? wink)
    Contrary to You, I yet have to meet a female in real life that had got herself implants. Except for a few cases of breast cancer recreational surgery. Or some breast size reduction for health reasons, 'cause them big boobies can cause severe back problems. Might be because I live in rural germany now after living in a medium sized (250k people living there) town in germany, where the chance to meet any potential photo models, adult movie actresses and normal movie actresses was rather low. So yeah, implants exist in real life. But the percentage of females having them seems rather low where I live. Less than 5% probably.
    Larger appendages may be nice to look at, but when you are telling a story of a spinster that has her hair tight in a bun and collar buttoned up to her chin, where's the credibility of the character if she has mammoth mammaries?
    None of those characteristics are incompatible with having large breasts.
    Not, if she weighs 300+ lbs...
    Large breasts occur naturally in women with all sorts of body types. Weight influences breast size, but is far from the sole determining factor.
    As a woman with 100% natural G-cup breasts and who doesn't weight even half those 300 lbs, I can guarantee you we exist. Granted, mine are still far from the watermelons some DS users give their female figures...
    The point in this context was, you can easily make mountains out of molehills in DS, but doing the opposite can sometimes be impossible, and having those mountains on a figure sets a tone that you are not looking for or even wanting.
    The fact that there are females with larger than life appendages, doesn't mean that they all do.
    By
    PerttiA PerttiA September 2020 in The Commons
  • Morph to remove nails
    Is there a morph to remove G8M fingernails?
    By
    lilweep lilweep September 2020 in Daz Studio Discussion
    Cheers!
    My sincerest sympathy to your backbone.surprise
    I have had girlfriends with all sorts of body types, from thin to overweight, from absolutely flat chested to really busty, and while I do prefer the curvier body shapes, not all women are like that, nor do they need to be to be attractive to me.
    One problem with the really busty figures I feel in creating scenes in DAZ studio is the challenge to make any combat poses look realistic. Big boobs tend to make many melee weapon poses look like the poor gal is going to either cut pieces of her body herself with the sword swings, or she is surely going to fall over boobs-first, should she dare to move at all.laugh
    I have some body morphs, allowing me to adjust the size of the breasts, as they can help me use a character that won't do with the shapes the character is sold with.
    I am not a PA, only a hobbyist artist. For me to get the "Wow! I really need this character for my collection at this instant!" reaction, or even to immediately picture a scene where I could use that character, the character should follow the guidelines posted by Penguinisto to an extent. There needs to be a distinct personality displayed in the character promos, preferably with a body type that is absolutely not a "they come 12 in a dozen" type. Some make-up matching the personality helps a lot too.
    Oh, and to all the PA's out there, do list the items used in the promos, pretty please. Some of the promos alone would have made me buy your character if only I knew the hairstyle used, and the outfit used, so that I could re-create that striking look.
    By
    watchdog79 watchdog79 September 2020 in The Commons
    Cheers!
    Sometimes I'm afraid of making a character's shoulders too narrow since I play with that slider and I usually dial back "breast implants" and dial up natural
    One of my favorite characters is Amira since she's big yet still pretty. When I dialed up fitness I actually had to dial up her waist too
    Most of the characters I use run a bit thin but it's not the only way to be attractive and even then not all characters have to be hot
    For tomboyish girls I'd add more makeup options such as contouring in a way to achieve a more masculine face and yeah a lot of default looks are madeup too
    There's a whole different set of fashion rules for different bodytypes too
    And I hear you on the rigid part some guys when you use an age down still look way too defined for their new age even if you mess with so many face morphs
    While I don't make models (yet? I know there are good Udemy courses on it) from what I can see it's texturing. Mari's not only expensive but you have to think about making normal maps, bump maps, and all that too and get them to wrap around the model it's made for too
    Tho I'll probably do environments instead of people since there's so many great potential environments. There's so much good new sustainable and hi tech architecture too. So at least one completely green city where poverty's been eradicated and very walkable and cool trainstations too tho maybe I can make them seperate? Anyway it would be set during a good future where climate change is solved and not a worry anymore and some of the buildings will be wavy with cool lights and windows and palms and other trees along the streets and plants seen on some buildings
    By
    BandoriFan BandoriFan September 2020 in The Commons
  • 3ds Max bridge doesn't transfer JCMs.....right?
    Yeah, none of the bridge plugins seem to transfer JCM.
    Well, the Blender and Maya versions do.  Was hoping either 3dsMax or C4d would...
    By
    jeff_someone jeff_someone September 2020 in 3ds Max Discussion
  • Cloths won't stay on character
    I bought a dynamic shirt for Michael4  and when I click it onto the morph it pop on him but in a T positions, and  if I move him the shirt is still hanging in mid air and the morph is left shirtless whereever I've moved him to. How do you make the cloths get "put on"  and move with the characters wearing them. I don't have that problem with all the other cloths.
    By
    Dannycoppell Dannycoppell September 2020 in Technical Help (nuts n bolts)
    Cheers!
    By
    Leana Leana September 2020 in The Commons
    Cheers!
    yeah here a exemple this is a "famous" ex porn japanese now cosplayer Shibuya Kaho
    she is natural large breasts and definitly she is not 300+bls, some peoples have that idea which womans must be "small breasts" all over the world which is the "natural" and only if you get fat which they "grow" but it's not really like that, this what make humans a so special race, because different propertions and spects of the body can happen and is really, really hard to 2 peoples looks like "twins" or equals even when we talk about "races, like 2 caucasian or 2 african never gonna look's like the same, aside from the color, in the same way you can have "ugly or no so attractive womans" being born you have really gorgogoes/awesome or "saiko-desu body" and face womans, the same goes for males, what is matter more is the "genetic" as a big factor, good genes gonna create good look peoples even if they are a little fat(not super ungly fat) the same goes for breast sizes if you family genetic is about "large breast womans" then you aways gonna see "large breast womans" on that family and only few rare cases this not gonna happens.
    By
    Ellessarr Ellessarr September 2020 in The Commons
    Cheers!
    By
    Gordig Gordig September 2020 in The Commons
  • Sci-fi Worlds of Gerry Anderson
    https://www.sharecg.com/v/80049/browse/5/3D-Model/Gerry-Anderson-UFO-TV-Series
    https://www.sharecg.com/v/66550/related/11/Poser/Space-1999-Hawk-Fighter
    https://sharecg.com/v/66558/gallery/11/Poser/Space-1999-Landingspad
    https://www.sharecg.com/v/35523/related/5/3D-Model/Stingray
    https://www.sharecg.com/v/87189/related/5/3D-Model/FAB1
    https://sharecg.com/v/36621/related/5/3D-Model/Thunderbird-4
    https://sharecg.com/v/94263/related/21/DAZ-Studio/Thunderbird-3-for-DAZ-Studio
    https://sharecg.com/v/36586/related/5/3D-Model/Thunderbird-2
    https://sharecg.com/v/94261/gallery/21/DAZ-Studio/Thunderbird-2-for-DAZ-Studio
    https://sharecg.com/v/94255/gallery/21/DAZ-Studio/Thunderbird-1-for-DAZ-Studio
    https://sharecg.com/v/14005/gallery/11/Poser/Thunderbird-1
    https://sharecg.com/v/36284/related/5/3D-Model/Thunderbirds-Elevator-Cars
    https://sharecg.com/v/38675/related/5/3D-Model/Fireflash
    https://sharecg.com/v/35766/related/5/3D-Model/Zero-X
    https://sharecg.com/v/35946/related/5/3D-Model/Zero-X-Assembly-Control
    https://sharecg.com/v/36589/related/5/3D-Model/Mortar-Truck
    https://sharecg.com/v/40201/related/5/3D-Model/Lunar-Carrier
    https://sharecg.com/v/36635/related/5/3D-Model/IR-Deflector-Truck
    https://www.sharecg.com/v/52252/view/5/3D-Model/SHADO-acoustic-gun
    https://sharecg.com/v/43520/gallery/21/DAZ-Studio/SHADO-Operative-Col.-Paul-Foster-M4-Head-MORPH
    https://sharecg.com/v/43411/gallery/21/DAZ-Studio/SHADO-Operative-Col-Virginia-Lake-V4-Head-MORPH
    https://sharecg.com/v/43409/gallery/21/DAZ-Studio/SHADO-Operative-Ayshea-Johnson-Head-MORPH
    https://sharecg.com/v/43195/gallery/21/DAZ-Studio/SHADO-Operative-Nina-Barry
    https://sharecg.com/v/43194/gallery/21/DAZ-Studio/SHADO-Operative-Joan-Harrington
    https://sharecg.com/v/42909/gallery/21/DAZ-Studio/SHADO-Operative-Lt-Gay-Ellis-HeadMorph-V4
    https://www.sharecg.com/v/53143/browse/11/Poser/SteveKitts-SHADO-Hawk-from-U.F.O.-show
    https://sharecg.com/v/48408/gallery/11/Poser/SteveKitts-SHADO-Falcon-from-U.F.O.-show
    https://sharecg.com/v/42781/favorite/11/Poser/S.H.A.D.O.-Uniforms-for-V4
    https://www.sharecg.com/v/44967/related/11/Poser/S.H.A.D.O.-Party-Outfits-for-V4
    https://www.sharecg.com/v/43105/related/11/Poser/S.H.A.D.O.-Uniforms-V4-Addon
    https://www.sharecg.com/v/41331/gallery/11/Poser/S.H.A.D.O.-Moonbase-from-UFO-TV-movie
    https://www.sharecg.com/v/42865/gallery/11/Poser/S.H.A.D.O.-Uniforms-Updater-not-standalone-
    https://sharecg.com/v/50270/gallery/11/Poser/V4-Gaby-Drake-Lt.Ellis-Morph-by-GSayers2005
    https://sharecg.com/v/40461/gallery/11/Poser/SHADO-Moonbase-pure
    https://sharecg.com/v/40912/gallery/11/Poser/V4++-Lt.-Ellis-dialed
    https://sharecg.com/v/30715/gallery/11/Poser/S.H.A.D.O.-Moonbase-uniform-materials-Update
    https://www.sharecg.com/v/53444/browse/5/3D-Model/MOLLY-Rocket-launcher-from-UFO
    By
    Ascania Ascania September 2020 in Product Suggestions
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
