• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • DAZ 4.15 keeps crashing within 1 minute of working in it.
    princeofgames06 said:
    Richard Haseltine said:
    The CPU is the central processor, an Intel chip of some kind on older Macs or possibly one of the new M1 chips on a new Mac.
    The GPU is the graphics card - unless your machine is very old or customised probably an AMD device  Help>Troubleshooting>About your Video card should have the details.
    2.5 GHz Duel-Core Intel Core i5
    Intel HD Graphics 4000 1536 MB
    What are your settings for performance, pixelbuffer etc?
    Unsure. Where should I go to find out?
    Assuming you can get there, Daz Studio>Preferences, in the Interface tab.
    By
    Richard Haseltine Richard Haseltine November 2021 in Daz Studio Discussion
    By
    Kestrel Omega Kestrel Omega November 2021 in Daz Studio Discussion
  • Daz to C4D (R24) and Maxon Moves
    The latest via Daz Central - 1.3.0
    The morphs don't work at all for me in R24, only the head rotation.
    Hence, the reason I installed R23 to see if I could get it to work at all.
    In R23, there's no eye rotation option with the imported face capture data and the mouth stays open as mentioned.
    Hopefully this will be resolved as it has great potential.
    By
    pixelmunki pixelmunki November 2021 in Cinema 4D Discussion
  • Daz Studio don't open, error in log-file
    I use Daz Studio 4.15.0.2 since months without any problems until yesterday. When I try to open it, it shows the opening screen and then it appears only as button in the task bar. The Background is white and clicking on it does nothing.
    Update:
    I deleted my old Installation of Daz Studio and Daz Central, all Folders with 'Daz' in it, Registry entries.and started from scratch. New download of Daz Central, new download of Daz Studio thru Daz Central and now it opens again with the default design. Though there is still a lot to do to get my customisation back, I'm really happy that I got it back to open. No idea what caused the issue...
    By
    chanur chanur November 2021 in Technical Help (nuts n bolts)
    By
    Totte Totte November 2021 in Daz Studio Discussion
  • Headshop Not Showing in Edit Menu
    Installation issues usually caused by attempting to install with either DIM or DAZ Central. Remedy: please read!!!!!! the README that has detailed installation guide.
    HeadShop comes with its own installer, there are also videos of how to install: https://youtu.be/5N-8KE4BCbo  and also https://youtu.be/QACNeyStmT0
    If still no luck, email tech support at [email protected]
    By
    info_b3470fa520 info_b3470fa520 November 2021 in Technical Help (nuts n bolts)
    By
    By
  • I broke DAZ again, help!
    RE: My DAZ is broke again.
    MY SYSTEM: DS 4.15 Pro, WIN 10 X64 21H1
    PROBLEM(s): DIM WORKS FINE, BUT
    1. DAZ CAN’T SEE OR USE MY SMART CONTENT (see image), AND
    2. DAZ CENTRAL FAILS TO RECOGNIZE EVERYTHING IS INSTALLED.
    INTRO TO THE ISSUE: (Probably a Content cluster or CMS path issue)
    I've had to move content around several times since I started using DAZ a year and a half ago (BECAUSE I RUN OUT OF SPACE). I began with DAZ defaults (C: Drive) on a 1Tb SSD (Disk-0), RAN OUT OF SPACE FAST, and I realized I needed to backup windows (without the huge DAZ content directories on the system drive) as well. So I MOVED DAZ AND DIM to some other internal HDD's (Disk 1 & 2 spanning as Dynamic RAID-0, volume F).
    Then my content collection expanded again, and ...
    =>I'm maxed out again, I now have 3 gigantic duplicate components: DIM DOWNLOAD ZIP FILE ARCHIVE, MY DAZ 3D LIBRARY, CLOUD CONTENT
    (Lots of DAZ content + tutorials + Rendo + Cube Brush + HDRI content and other low quality freebies)
    FIRST FAILED ATTEMPT TO RESOLVE THE SPACE ISSUE: Folder/directory compression
    =>Result: Accomplished nothing (no significant gains).
    SECOND ATTEMPT: Moving Templates and Tutorials elsewhere
    =>Result: This only freed up ~16GB space.
    THIRD FAILED ATTEMPT TO RESOLVE THE SPACE ISSUE: I initially moved the DIM archive to an external HDD.
    =>Result: I found that adding new content would cause the problem that I would also need to download all the previously installed content because I [sometimes] could not figure out what was my new and what was my old (content) so I had to bring the DIM archive back to volume F.
    FORTH (CURRENT) ATTEMPT:
    I bought more internal HDD storage (volume G) and made the decision to split up the 3 Giant Duplicate DAZ components (above) as follow:
    1. HDD VOLUME F (Disk1&2 RAID-0): Daz Studio Installation+MY DAZ 3D LIBRARY+ CLOUD (CONNECT DATA) CONTENT.
    2. NEW STORAGE HDD VOLUME G (Disk3): Installed DIM there, +moved my content cluster (database), DIM Downloads (Archive zip files), Manifests, Thumbnails, and my personal data (“My Library,” scene, subscene, presets, renders, project folders).
    ABOUT MY CURRENT DAZ STUDIO ISSUE:
    =>The Content Library tab sees/has all INSTALLED content.
    =>I changed the content cluster and other necessary information in DAZ to the G drive (see the attached image from DAZ CONTENT DIRECTORY MANAGER), but DAZ will not find my SMART content.
    =>So I reinstalled DAZ using DIM, (hoping DAZ would migrate to and take up my new DIM settings)... that did not fix DAZ smart content.
    =>So I re-imported Metadata results in DAZ, and DAZ acknowledged most of my Smart Content (Icons only) and the number of DIM packages is almost correct, but when you click on a content package icon, there is no smart content files (e.g. duf’s, images, or material files etc).
    =>I’ve tried connecting DAZ cms SETTINGS to both the CMS database and the Content Cluster, but neither results in Smart Content availability.
    ABOUT MY DAZ DATABASES:
    =>I’ve identified 3 DIFFERENT DATABASES???
    C: ROAMING/… cms directory
    F: CLOUD/meta directory
    G: DIM/ … CONTENT DATABASE/ContentCluster directory
    (see attached images)
    QUESTIONS:
    1. How do I fix the (no smart content issue) and the DAZ central issue?
    2. What databases do I connect to what PROGRAM (DAZ, DIM, Central) after moving my DIM downloads, manifests, thumbnails and ContentCluster to the G drive?
    3. What is the function of the ROAMING CMS database vs the ContentCluster, and is it mandatory to add the directory links anywhere else (what resource location box gets what link)?
    Can anyone identify the problem (e.g. is it content cluster, multiple HDD locations, something else needs to be reset?
    By
    ATLPR ATLPR November 2021 in Technical Help (nuts n bolts)
  • So in the last 2 installs of DS Pro 4.15 goes in application folder why...?
    I decided to uninstall everything DAZ and reinstall DAZ Central, which now has an icon again :D So, I tried the reinstall from DC after fixing the paths again. And, again, I am stuck on this screen. [Frustrated screams of angst deleted.]
    By
    DannisWrites DannisWrites November 2021 in Daz Studio Discussion
    I am also having this problem. I have 2 external hard drives I use with my new PC. I had to reinstall DAZ because CMS wouldn't update. Coming here for help I was pointed to the Application Data folder on my C: drive [originally installed DAZ to C:, which is my SSD].
    The Application Data folder somehow had a baby Application Data folder. So it was a Windows 11 problem. I found some really old references to this nested Application Data problem. One solution was to rename then delete the extra one. I tried, then the extra folder had a baby that was a link to Application Data and all the files and folders were in it. Huh?? So, I had to reinstall Win 11. Pain, pain, pain. I have been reinstalling programs that were on C: for days.
    Today I wanted to start DAZ and play with some shiny new items. I went into IM [mind you, I used it only yesterday to install ALL my content on D:\DAZ Library] and installed all my new content. I noticed it wanted to reinstall DAZ. Oops. Why?? I have NOT changed my install directory.
    So I went and started DAZ and it hung on the starting screen, the same CMS issue.
    Ok, so reinstalling DAZ is inevitable, I get it. I go to DAZ Central and my paths are messed up. I put my install path as D:\Program Files and my content directory is D:\DAZ Library. Since I have a ton of content, I keep all the 3rd party stuff out of my DAZ Library so I have that as D:\3D\3rd Party but I will put that in DAZ when I  an get it to run.
    Everything DAZ, my Carrara 8.1 trial, my Hexagon, my Bryce 7.5, all are installed in D:\Program Files
    As I understand it, Program Data and its wayward child Application Data are not directories for installation of any program, just for settings.
    So, I am confused as to why DAZ IM AND DAZ Central decided to change the directories I put in to Application Data.
    My D: removable drive is just a data drive without an operating system installed, it's just formatted NTFS for Windows, nothing unusual about it.
    And, I just tried to reinstall DAZ and got the same stuck on CMS problem.
    From reading here, I will go change my program files path back to D:\Program Files and I will add to my post. Wish me luck!
    Any advice much appreciated!
    A Very Frustrated 63-Year Old Dannis
    By
  • safely remove and restore product files
    I've notice through Daz central that i have about 20 products that are 1gb in size.
    Is it possible to remove these products until needed to save on c drive file size. Then re install when neede for a scene.
    Running low on valuble c drive size.
    By
    rkeene_18d39bc001 rkeene_18d39bc001 November 2021 in Daz Studio Discussion
  • Ultimate PBR skin manager
    I installed through Daz Central, so everything should be there. Where do you load it from? I see it in my PRODUCTS under "U." it has a script, but i st an error when I apply it. Do I apply it to the model, the texture? I see no menu windows when I use it. The instructions say nothing as to where it is or how to apply it. How doI get ahold of D3Ciditimes? I see no e-mail link or a place for questions.
    By
    kurtmurphy1 kurtmurphy1 November 2021 in Daz Studio Discussion
  • moving file location
    There is no need to have both DIM and Central and DIM is the better of the two.
    By
    jestmart jestmart November 2021 in New Users
    How did you install? Scripts are often not written in a way that is compatible with installing through Daz Studio itself, so if that is what you did it may be worth uninstalling and installing through Daz Central or Daz Install Manager instead.
    By
    through daz central, my texture file is 32 gibytes and my data file is about the same but I don't want to mess with it.
    I have new Dim and daz central installed , i also used to instal manually and all these files went into c daz3d/ studio/  my librarys.
    But most of those installed into daz by by daz central went to C/daz3d/ Applications/ Data / daz3d/ my Daz3d Library.
    By
    rkeene_18d39bc001 rkeene_18d39bc001 November 2021 in New Users
  • Daz Central Install Path
    I want Daz Central to install my content on my larger hard drive, rather than my smaller solid-state drive.
    How do I accomplish this?
    By
    dash2128 dash2128 November 2021 in Technical Help (nuts n bolts)
  • Default resources? I'm missing iray uber base
    Alewis478 said:
    Leana said:
    What do you mean by "not actually installed"?
    Where does DazCentral install your content, and is that directory listed as a content directory in DS preferences?
    "Not actually installed" meant Daz Central says Installed but it shows up in Smart Content as available for install. The problem was the base file path in Daz Central was set to "managed by DIM", which I don't use. Because I had fits trying to make Daz install somewhere other than the C: drive, I let Central install to the default path and then manually move it to my actual library on another drive. Apparently that stopped working at some point.
    Whatever 'Smart' Content is telling you - Don't listen !!!
    Do yourself a favor, and configure DS for offline use, if you are using DIM or DAZ Central to install content, you do not need to log in/sign in to DS at any point, logging in is only needed for installing content with DAZ Connect within DS and then it gets installed to an other location.
    By
    PerttiA PerttiA November 2021 in New Users
    By
    Alewis478 Alewis478 November 2021 in New Users
  • Need a clean uninstall: HELP!!!
    I always did a manual uninstall of Daz directories and reg entries. It takes a while. Restart do a search of your computer for DAZ. Don't forget to search hidden files and folders also. Select all and delete. This will delete all forms of installers DIM and Daz Central and any downloads of the installers and all content. Most free reg cleaners will clean your registry up for the missing file associations of Daz.
    By
    AgitatedRiot AgitatedRiot November 2021 in Technical Help (nuts n bolts)
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
