• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Ultimate PBRSkin Manager
    There are no presets, I explained why in the commercial thread. This is just an easier more efficient and organised (one tab by theme "tone & volume", "bump+details&gloss", "additional (maketup, etc)") way to access the properties on predefined groups of surfaces (skin lips nails, skin only, nails only, skin without lips and nails, skip without nails, lips..). It is also a powerful gamma manager to change the skin look, and a saver loader of properties without maps (allowing cross figure, cross UV skin properties transfer (without maps), and transfer of properties to anatomical elements). But no, there are no presets included, the script supposes that users at least know what a gloss, or a bump, or translucency is. So it is better if you have a minimum of knowledge to have about shader, even if some people told me they learned how to tweak a shader using Ultimate Iray Skin Manager.
    edit:
    If you have questions, it is better to PM me, I'm available (Paris time) all day long, or to come to the commercial thread, because I saw your question 'by accident' while watching a bit the forums.
    By
    V3Digitimes V3Digitimes March 2021 in The Commons
  • The Mac FAQ
    Richard Haseltine said:
    Totte said:
    Chronopunk said:
    Totte said:
    Chronopunk said:
    So I got the new machine set up, I've verified that all of my network settings are correct, both machines can see each other and communicate normally across the network, and I have verified that all network issues are resolved.
    However! (There is always a however)
    I have DIM on the new machine pointing at (Network/Macbook Pro/My Daz 3D Library), I click the refresh icon, and I see... Nothing.
    I would expect to see the contents of the directory and be able to retrieve them, but... Nothing.
    Thoughts? Suggestions? Am I going to have to download everything from Daz and Rendo again? Gods I hope not.
    The problem is probably that the CMS/Postgres is not accessible from machine 1 to machine 2, which is not, it only accepts local 127.0.0.1 accesses in default setup.
    Than can be fiddled with, but not recommended unless you know how.
    My setup is two machines, both with their own content library and their own cms, but my DIM download directory is on another disk on one of the machines, so I only download once and install twice.
    Hmmm. That's vexing.
    I don't suppose there'd be a major issue with me simply copying the files out of my Laptop's Daz 3D Library folder and dropping them directly into the Desktop's associated directories, would there? I don't have any scripts or software that are OS-specific, and the last time I checked, .duf and other files are platform independent, so they should work, yeah?
    If DIM won't do the network transfer, the old fashioned way may be best.
    The problem is the CMS, as it points to every item by a full path and when you move stuff that breaks. If you only render on the "other machine" that wont be an issue, but if you rely on CMS functioning this will be an issue.
    As far as I am aware the CMS uses relative paths, it's only the DIM/Central manifests that use absolute paths (and content that isn't in a content directory).
    It was couple of years ago I tried to do this but on machine A the path was /Volumes/DAZBoot/  on machine it was /Volumes/DAZBoot/DAZContent/ and CMS failed to find anything so I cleared the the db and reimported metadata at it was up and running, maybe it was something else..
    By
    Totte Totte March 2021 in Technical Help (nuts n bolts)
  • The Mac FAQ
    By
    Richard Haseltine Richard Haseltine March 2021 in Technical Help (nuts n bolts)
  • The Mac FAQ
    Hm.
    Daz has never been opened on the new machine, so all that CMS has to work with right now is the basiscs that have already been installed.
    I suppose I could suffer the download of all of my stuff from DAZ to get things where the application wants them to be, then manually copy all of my remaining content across the network, yeah? Things like custom skin mats and character shapes that currently live only on the laptop? Once CMS has its basic understanding of the "things that come from the mothership" it should be fine with the rest, shouldn't it?
    Everytime you install something on machine one and copy to machine two, CMS will be tricked and stuff might go wrong if you try to work on machine two with a scene.
    My current plan is to work on Daz, Blender, etc, solely on Machine Two going forward. Machine One is going back to its original role of writing novels & rpg's, page layout, graphic design, and the like. I have no plans to install anything on Machine One once Machine Two is set up and running.
    If I install all my available Daz store downloads via DIM, then manually copy everything else, except, say, the scenes I've worked on recently (which are little more than single figures in empty space while I continue to fiddle with lighting experimentation), that should work, shouldn't it? Unless I'm missing something very obvious that just keeps going over my head?
    By
    Chronopunk Chronopunk March 2021 in Technical Help (nuts n bolts)
  • The Mac FAQ
    Hm.
    By
  • On The Look Face Morph Resource for Genesis 8.1 Females
    Is a version of [On The Look Face Morph Resource] this going to be released for the G 8.1 Males?
    Edited for Please put your question in the post body and the title - Daz 3D Forums
    By
    inquire inquire March 2021 in Product Suggestions
  • The Mac FAQ
    Hm.
    By
  • The Mac FAQ
    By
  • The Mac FAQ
    By
  • dForce Classic Fur Cape [Commercial]
    i53570k said:
    Does this product have a lay flat morph so it can also be used as a rug?
    It does not, but a good idea.  I will see what I can do.
    By
    the3dwizard the3dwizard March 2021 in The Commons
  • is there a way to dial in part of a head morph?
    Another solution is to use Head Propagating scale to dial the head back to human sized again, though the amount of this you need will vary from morph to morph, and it can have unwanted side effects, eg the neck is also scaled down.
    The other thing to look at is if your morph dial is trigging a scale of the head. If so, you just need to put this back to 100 (or whatever it was before).
    By
    Havos Havos March 2021 in The Commons
  • Character Creator 3 to DAZ-- has anyone had success?
    Make a custom morph for Genesis,in a modeling program,
    that resembles the Reallusion CC3 character.
    or try "dialing in" a resemblance with your existing installed Genesis morphs
    or ,if you have CC3 pipeline, use the Diffeo or D2B plugin to send your Daz scene to Blender
    and use the free CC3 pipeline Addon tool to bring that CC3 CHaracter to Blender which will set up the skin shaders automaticly
    then render the scene/animation in blender Cycles or EEVEE
    beyond that forget it!!
    CC3 is a Different Character Eco system with Different geometries and UV's
    pick one Character system or the other or one can mix the two via a third party app or game engine for rendering.
    By
    wolf359 wolf359 March 2021 in Technical Help (nuts n bolts)
  • Who is a girl in promotion photos of "Pearls, Pearls, Pearls for Genesis 8 and 8.1 Females"
    margrave said:
    Looks like a P3D model. https://www.daz3d.com/p3d-mylou-for-genesis-8-female maybe? Just with flatter lighting and maybe some morph tweaks to make the lips wider.
    Thank you! It surely looks like. The auther may have edited the character a bit.
    By
    agyro07 agyro07 March 2021 in The Commons
    So basically, I find a face I like in my dials, go to dial it in, along with changing the face shape, the head starts inflating or deflating like a balloon. Is there a way to make the head stay normal human shaped, but get the look of the face? Some happens worse than others, would love if there was a way to use all face morphs, rather than just trial and error, seeing which will work withough changing the whole head shape.
    By
    TheKD TheKD March 2021 in The Commons
    By
    margrave margrave March 2021 in The Commons
  • I LOVE the goblin
    Sevrin said:
    PerttiA said:
    a16der_9ecbf630c5 said:
    There is no way to load the morphs on to G8, they won't show up in the parameter dials so there is no way to load them  that I can see.
    Inside the installation file, are the morphs located in G8M or G8.1M morph folders?
    File List [Documentation Center] (daz3d.com)
    The file list shows /data/Daz 3D/Genesis 8/Male 8_1/Morphs
    In that case G8M doesn't see the morphs, ie. they are meant exclusively for G8.1M, but...
    I can see two ways to get G8 to see those G8.1 morphs.
    1. Copy or move the morphs manually to G8 morph folders, although copying may not be a good idea with DS 4.15 as G8.1 would see the morphs twice afterwards, may also require some manual editing to fix the paths.
    2. They have introduced a new folder with the G8.1 "...\Data\DAZ 3D\Genesis 8\[Gender] 8_1\Add-ons\Daz 3D\Base\", which contains a file "DazAddonPath.dsf".
    Inside this file they are telling DS 4.15 which folders to read to add the G8 morphs to the figure.
    If you added the same folder stucture to G8 and made G8 it's own "DazAddonPath.dsf" which told G8 to read the G8.1 morph folders, in theory you could get G8 to read G8.1 morphs but I have not tried this (yet)
    By
    PerttiA PerttiA March 2021 in The Commons
  • I LOVE the goblin
    By
    Sevrin Sevrin March 2021 in The Commons
  • Just the HD details of SimonWM's "Hercules HD for Genesis 3 Male", without increasing G3M's size?
    scar_hand said:
    It looks like that editing my morph asset with ERC Freeze fixed the problem. Thank you, Frinkky. I got what I had asked for.
    I also found out why figure Hercules HD is more aestheticly defined than figures Hercules SD and Genesis 3 Male when they all have the morph "Hercules Body HD" dialed at 100%: Hercules HD's SubDivision Level and Render SubD Level (Minimum) is set to 3. In comparison to Hercules SD and Genesis 3 Male, their SubDivision Level and Render SubD Level (Minimum) is set to 1 and 2, respectively. Therefore, setting Hercules SD figure's or Genesis 3 Male figure's SubDivision Level and Render SubD Level (Minimum) to 3 will have their muscular body be as aestheticly defined as Hercules HD.
    Cool - got there in the end. And yep, with HD morphs, increasing render subdivision (up to the subdivision level the HD morph was created at anyway) will bring out more detail. Woe betide ones vram usage past subd level 4 :)
    By
    Frinkky Frinkky March 2021 in The Commons
  • Achieving family resemblance across genders without pen and paper
    Frinkky said:
    If you make the discerning feature/s out of a morph pack that has both male and female counterparts just dial in the same features on each character (eg. https://www.daz3d.com/200-plus-head-and-face-morphs-bundle-for-genesis-8-female-s-and-male-s or the Genesis 8 Head Morphs male/female sets).
    I have that exact product already Frinkky. And that was my method. Hence the pen and paper to keep track.
    Lazy best describes what I am. But thanks, otherwise a good suggestion.
    By
    kerry kerry March 2021 in The Commons
    Thank you all for the tips some really good suggestions here.  Things I didn't even know were possible like transfer morphs, makes sense actually. Good shout j cade.
    Those transgender morphs
    As for a store products, this might be a good excuse to get the Dial Fusion add on https://www.daz3d.com/dial-fusion-for-genesis-2-to-81
    As if I ever needed an excuse to spend in the store.
    I would create the characters from one gender making a headmorph then dial in perhaps 20% mum and 50% dad and the rest their own look since I'm not going for an identical match just similarity. More a facial similarity than anything else.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
