• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Some Questions About HD Add-on Body Morphs
    The figure isn't HD, the morph is (all of the Genesis figures are sub-divided, to smooth the emsh out; regular morphs move only the base geometry but HD morphs can move the vertices created by the sub division to give finer details). You can mix and match HD morphs just as you can regular morphs, how well they will mix depends on the morphs themselves.
    By
    Richard Haseltine Richard Haseltine May 2021 in New Users
  • Morphs Still Loading (With G8F) After They've Been Uninstalled
    I'd say you just missed some.
    You'll probably need to manually delete them out of your data folder, and all associated files, character presets, morph presets etc. Material presets will generally still work if they don't have any uv mapping requirements(dsf files)
    Make sure dim isn't set to auto install stuff, uncheck the box("install after downloading") and make sure your install list skips the particular items(uncheck them).
    And don't log into your account in DS so as to avoid connect doing anything.
    By
    DrunkMonkeyProductions DrunkMonkeyProductions May 2021 in Technical Help (nuts n bolts)
    In attempting to lessen G8F load times, I took the option to uninstall a host of morphs via DIM. Characters and morph packs were among those uninstalled. Some were deleted. On loading G8F again, I notice that the morphs still show up. Anyone know why this is or have a solution to permanently eradicating these morphs?
    By
    conscience73 conscience73 May 2021 in Technical Help (nuts n bolts)
  • Broken bones for G8?
    Could try making a morph, adjust rigging to mesh, apply ERC freeze, zero morph and save.
    By
    Catherine3678ab Catherine3678ab May 2021 in Daz Studio Discussion
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE TREDICI
    Muscleman said:
    Guardate che NON tutto può essere usato in Dforce. Alcuni vestiti non sono "fatti" per essere "cambiati" in vestiti Dforce eh. Dipende dal PA, non da DS.
    E per alcuni capelli che cambino per via dei morph, dipende da come sono fatti, molti non hanno intere liste di morphs all'interno, non è semplice inserire tutti (troppi forse) morphs dentro dei capelli . dipende dal PA, non da DS...e lo so, sono ripetitivo ma è così.
    Veramente esplodono anche i vestiti (e anche i capelli, per la verità) che sono proprio nativi dForce. E' una cosa molto random, dipende da un sacco di fattori e comunque in genere si rimedia. Anche per la cosa dei morph, sebbene sia un po' una seccatura, basta apparentare i capelli alla testa. Invece la faccenda dei prop che se li parenti poi si spostano è una vera rottura di #%&* perché uno fatica mezz'ora per posizionare dei personaggi e poi li apparenta a un null per poterli spostare insieme. Una volta rimanevano immobili anche dopo apparentati, adesso no, appena li apparenti se vanno a spasso a casaccio e li devi riposizionare da capo frown
    By
    Silvhe Silvhe May 2021 in The Commons
  • One Click Expression Adjustments
    You could apply the expression to a fresh loaded Dev Load figure, export as OBJ, import with morph loader pro, adjust bones to shape, test, ERC freeze, zero morph, save as morph asset, repeat for the rest of the expressions you want to have sliders for.  The new expressions might not play especially well with other expressions also dialed in, since they are now morphs and don't adjust bones, but they should be fine if used by themselves.  If you're not already familiar with the morph loader, ERC freeze process, you may want to read up on it, there's plenty of threads about it.  Hopefully this helps.
    By
    Spacious Spacious May 2021 in New Users
    Hi all,
    I'm trying to create a horror render in which I have a G8 figure with an open arm fracture. Is there any product out there like a morph or something that allows me to bend the arm in the middle of the lower arm and add some blood or something? I could add the supposed bone parts manually, but how to bend the arm is a hard one to figure out... Thanks a lot!!!
    Me
    By
    gibrril_fa945a6cee gibrril_fa945a6cee May 2021 in Daz Studio Discussion
  • VR and Motion Tracking etc.
    Hi team,
    Just want to check but do you have a plan to implement a feature to edit in the VR space? What is the latest?
    It would be awesome if you have a plan to support scenarios like below...
    Best scenario;
    - Support Oculus, dive into the VR world and adjust various settings such as posing, gravity, wind, outfits, cameras, lights
    - Support an App like the Live Link Face to morph
    - Load and analyse a video and match motions, lightings etc.
    Better;
    - Support Oculus controllers to edit in 3D
    Good;
    - Provide an option (monthly subscription) for us to edit on the cloud to have more rendering power.
    By
    kenichik kenichik May 2021 in Product Suggestions
  • Importing EmotiGuy to Unity
    Ok, I have realised that the converter is not necessary.
    Here are the steps while using Daz to Unity bridge from Daz Studio 4.15 Pro to HDRP project in Unity 2020.3.4 f1
    1. Load Emotiguy to Daz Studio and save the scene under the name, you will recognize later on - for example Emotiguy01
    2. Select Emotiguy in the Scene view
    3. Choose "Send To" -> "Daz to Unity" from File menu
    4. In the window with Daz To Unity, you could check "Enable Morphs" and then click on "Choose Morphs", but it did not worked for me
    5. Still in the same window, browse to the Assets folder with your HDRP Unity project
    6. Put the check mark on "Install Unity Files", if it is your first transfer to your project in Unity (I have already transfered items from DS earlier, so I unchecked it)
    7. Switch to the Unity and you will see soon the converted Emotiguy in the scene.
    By
    Artini Artini May 2021 in Unity Discussion
    By
    Muscleman Muscleman May 2021 in The Commons
  • Subsurface Scattering not working G8F?
    IceCrMn said:
    Save a shaping preset so you don't lose it.
    Select the character you want to save
    File>Save as>Shaping preset
    Then you can apply that preset to a new Jacqueline,or any 8.1 for that matter.
    Should work on 8.0 figures as well.
    You can also apply the broken Jacqueline's shape a new Jacqueline in the same scene.
    Select the broken one.
    Click "Edit" on the toolbar.
    Edit>Copy>Copy Figure
    Select new Jacqueline.
    Edit>Paste>Paste Figure Shape
    Studio will appear to freeze while it reshapes the new Jacqueline.
    Starting with different base characters can give different results.Experiment with this sometime if you want to see what it looks like.
    Sometimes Studio just doesn't work right and requires a restart to get it going again.
    I have strange issues when I've been running it for hours on end.Lights don't work, cameras won't work, all kinds of strange things.
    A restart normally gets it sorted out and back going right again.
    Thank you, that is a very useful tip. It did seem to help to transfer the morphs to a new figure. I've no idea why that old figure suddenly broke like that!
    By
    Endlessdescent Endlessdescent May 2021 in New Users
  • NFT and the Future of Digital Content
    plasma_ring said:
    [snip]
    It sucks! This could be good, virtual avatars and the internet as an MMO could be good--that's basically been my Dream Internet since the 90s! It's just irrevocably tainted for me by knowing the people pushing it hardest actually have enough money to shape the future of the world with a "Let's just do it and be legends, man" level of unearned confidence in their own wisdom. When industries move fast, it typically means nobody is stopping to think about collateral damage.
    It's called 'pump-n-dump' for a reason. The ones that started it and have the bigest stake want to do everything they can to make others want to buy into it. So you have a couple of them 'selling' an NFT for sixty-nine million to each other to make others think they want/need in as well. But most of us don't have patrions or friends with millions to throw at 'tokens' for links to something they won't actually own. When we shine a light on things we find the tokens cost real money - as does transfering that token, the only ones certain to make money at the ones selling you the cyrpto coins/NFT/transfer (and if your token doesn't sell for enough, you lose money.)
    Talk it up big as far as it will go, then sell off what you can before the bubble pops. Then if it doesn't disappear you buy some of it back cheap and start talking it up again - there are always new fool to ride the next bubble (until it too pops!)
    By
    allenfesler_2df6b6e506 allenfesler_2df6b6e506 May 2021 in Non-Fungible Token (NFT) Art
    So I loaded a second Jacqueline and SSS works fine on her! Problem is, the broken one has all my custom morph settings and shaping that took hours so... not sure what to do sad
    By
  • Selling base characters without their additional morphs
    Oh no, which characters did you buy? M3 had some good ones, there were a couple that I adored. The Breathtaking Bishounen morph pack was a staple for me, and Kaleya's Ash'ale from over at Rendo. There have been some great advances but M3 was baby's first digital Ken doll, and I have a soft spot for him.
    Those M3 characters should have a warning somewhere in big bold font about how they require morph packs that are no longer sold, and that they will not work if you did not purchase those morph packs in the past. I also ended up buying some characters where it turned out that the requisite morph product for it was no longer available (M4 Enhanced/Mina). That situation was even more complicated because the product I bought was a DO, but the required morphs were a PA product that Daz hadn't bought out the rights to. Fortunately it was all super cheap stuff since I forgot to return it, whoops.
    I've run into other related issues, too. A G2M outfit was distributed missing either eight or ten (I forget which) out of the twelve advertised movement and adjustment morphs for the skirt. Got told that it's old and they're not gonna bother fixing it, thanks for the money. It's still in the store, promising twelve adjustment morphs and only delivering a fraction of them.
    Daz's willingness to sell older content is high, which is AWESOME and I buy a lot of it. Some great legacy stuff out there. Less awesome is how their willingness to support the old content that they sell is non-existent to the point that they won't even update product pages for accuracy. Doesn't help that the "required products" section is still screwed up from November, too.
    By
    Cora Regina Cora Regina May 2021 in The Commons
    icprncss said:
    Best solution is to return the bases and purchase the Genesis iconic shape set. It will give you the shape of M3 with the versatility of Genesis.
    I already have the (Gen 3) Iconic Shapes pack for Genesis. I just didn't have them installed.
    I've tried loading the characters onto the V3 shaped-Genesis, but Daz is still looking for the V3 head and body morphs.
    icprncss said:
    The V3 Digital Beauty bundle is on flash sale. It contains the V3 head and body morphs. I cannot find a listing for the M3 morphs.
    Oh, I missed that sad (added it to wishlist instead).
    icprncss said:
    V3 comes with a male morph in the morph packs.
    I didn't know that.
    Thank you for looking. I would never have thought about checking a bundle. smiley
    By
    N-RArts N-RArts May 2021 in The Commons
  • Why so many high heels
    And you can't just flatten the heels in Daz and hope for the shoes to work. The shape of the sole often distorts when you bend it far enough to be flat. You really have to haul the boots into a modeling program and make a flats morph from the existing geometry. That's more a statement of fact than a complaint. I've heard the idea floated that boots can have variable heel lift, but that is a fair amount of extra work to make the morphs needed to achieve that and to account for changes in heel shape relative to height. You probably need/want extra fit poses for the character, too. It's never easy.
    By
    Torquinox Torquinox May 2021 in Product Suggestions
  • Plugin does not work in C4D R23
    Some of the code has been updated for R23 -  for instance, the DRAWFLAGS_NO_REDUCTION  has been removed and they tried to change floats for integers, but the script still does not run.
    I still can't get files to transfer.  OIn the C4D side it says 'nothing to import'. On the DAZ side when trying to run the script, the screen flashes but does not go through the prep process. Any thoughts?
    By
    chweintr chweintr May 2021 in Cinema 4D Discussion
  • Daz to Unreal Engine
    I would like to know what the time line for this is? It seems like many of the added features of Daz do not include Ma users. For instance, face transfer would be one. As a person who uses both Daz and Unreal on the Mac/Apple platform it would be great to see this sort of functionality extended to us as well. So, will there be a Daz to Unreal Engine soon?
    Thank You
    SC
    By
    ceo_fbf4b402 ceo_fbf4b402 May 2021 in Unreal Discussion
  • Jazz 8.1 discussion
    Stylized figures? I'd rather do that myself. I mix existing figures with things like 3d Universe's Toon Generations or Lady Littlefox's Star 2.0. I think another PA created a toonify morph/script? By using a common base for toonification, I can get a consistent look & feel in my stylized figures.
    I think a lot of recognizable "Daz figure" work tends to be in pr0n games with raw render output. Does that bother me? No.
    The quality issues are a concern, however. They've been a concern for a while. There are many questions about the content of the store (like the increasingly conversative attire), but quality concerns are something that cuts across all of our interests.
    I've got another Jazz render in the works. I don't honestly know how much I'll use him after this contest. Of the 3 so far, I'll probably use Jacqueline the most.
    If there are fewer contest entries for me to compete against, I am okay with that this time.
    laugh
    By
    The Blurst of Times The Blurst of Times May 2021 in The Commons
  • How do i insert a Facegen Modeller Face in a Daz Character
    The Facegen product comes with a set of starting maps of a head.  First, you'll need to find the set for your DS model base.  If you have built a model body etc of your own, you are SOL.
    In any case, you can download the mapping you need, just look up the download for the model base you wish to use as your template.
    Case one:  You've designed your own model\rigging\mapping set
    This is a tough one, but not impossible.  You will have to use python or another compatible scripting language to do this quickly, but you can do this by hand and slowly if you're not practiced at programming.  The idea here is that you will not be exporting your native model, but a base model that has been fitted to your form using a difference morph creator (which calculates the differences and generates body and face morphs accordingly), or using a hand tool to create each morph on the base model to get it to match your native model.  Once you've converted them, you can save the model and await the overlay of the face.  At this point, if you haven't downloaded the faceset for facegen that matches the base model, you should do so.  Install the base set into facegen and open it.  Now you can create your new face in facegen, using whatever method you find capitol among its toolset.  Now you should be able to export the face to DAZ studio.  Technically, the Artist version of facegen has the ability to do this directly, but you can utilize the same tools I describe above to match your native face to the modelled face, and tie it all up into a nice morph set.
    Case Two: You are using the base model set
    Download the base model face set from Facegen that matches your base model in DS.  Using this set, you should be able to get a face design from the Facegen app.  There are two ways this can work from here on.  If you have the Artist version of the Facegen software, you will have the ability to export to a DS compatible format, and it should work as a morph for the base face.  If you have the Modeller set, you have access to the capability, but not so directly.  You can download the artist version and run a fully functional trial (no watermark) in order to export the face, but you may have to reinstall every time, and you'll have to mess with your registry values to wipe a few things.  Not fun.  If you have both versions as a package deal, which they have pushed in a few instances, you should be alright, create the face in modeller, open it in artist and export to DS.  If neither of these fits you, you'll export something you can import into DS as an object or garment, then you'll either use a script to map the morphs for the base face, or you'll morph it yourself.  Technically, the object should contain the same mapping information as the base face, but the sizing measurement standards may be different.  If so, you can also reset those for the object in hexagon or other software, then copy them and paste them over the mappings of a copy of the base face, save that from hexagon to ds.  This can get slow, but it can work.
    Personally, I prefer Reallusion software to facegen.  They have an addon that allows you to import and export to different modelling software and they can mold their power to your pipeline.  Facegen is more for the still life, and can be very helpful when creating still imagery or concept, but other than that, it just has too many limitations.
    By
    harleydavispersonal harleydavispersonal May 2021 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
