• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Why Does It Take So Long To Load Figures? ("Solved", with GUIDE)
    TheMysteryIsThePoint said:
    Artist3d_36942d4e3a said:
    But the problem is basically poor coding, and DAZ should really correct that !
    Not necessarily poor coding, but coding without foresight. It was probably acceptable at some point. OK, I suppose that's a specific case of a type of poor coding.
    DS is not Open Source, so none of us know what is happening, and the current behavior could actually be not the worst case scenario; we shouldn't second-guess the devs as we don't know what kind of architecture they have been saddled with.
    But as users, we are certainly entitled to say that we are having a poor user experience, regardless of the technical reasons for it, without anyone trying to minimize or justify. There is no excuse for an architecture that somehow allows other unrelated morphs to erroneously destroy your character, or to require you to install morphs that your character doesn't even use and that didn't even exist when you made the character.
    I'm not sure what you mean about morphs destroying characters, unless it's the cases where a morph loads with a bad default value or the ERC is not correctly set up to limit the scope of a correction (both of which are good functions not correctly applied). I've no idea what you mean by needing to install unrelated morphs.
    Daz needs to fix this. Period. But I do not have super high hopes, because Daz also made an "architecture" that allows PAs to mess up metadata and poorly name things...
    Aside from speed, which as you say may involve tradeoffs, I'm not sure what core-feature issues there are (as opposed to errors in specific products).
    By
    Richard Haseltine Richard Haseltine July 2021 in Daz Studio Discussion
  • V4 to genesis 8 prop converter
    For necklaces and headwear, load the props in place, then one by one - use the transfer utility [from the hamburger menu on the scene tab] Figure is the donor, prop is the target ... be sure smoothing is UNchecked, for the bones select an appropriate option [NOT attachments - those are for geografts] and the program will do the work. Then select that one item and File > Save as > support assets > figure/prop to the clothing or accessory folder for the concern figure. Done. Then you can make mats etc. for it too if so desired.
    By
    Catherine3678ab Catherine3678ab July 2021 in Daz Studio Discussion
  • Saphirewild's Randomness Renders
    I just got CJ8 today so I thought I would give her a go!!!
    I use both CJ and her Morph Gradi also used another GF8 Character!
    Used IRay and no postwork
    By
    Saphirewild Saphirewild July 2021 in Art Studio
  • Blender characters into Daz Studio
    I suggest 2 option:
    1. import as FBX (OBJ doesn't support rigs)
    2. import as OBJ in the self pose (and self scale) of a G8. Use Transfer Utility to copy/paste the rigs from a G8 to your model. So clothing/hair/etc.. won't be supported but you will be able to apply G8 poses
    There is also a third option: convert your model to a morph... it's the most complicated solution but you'll be able to use G8 pose and even cloths/hair/etc..
    By
    Kainjy Kainjy July 2021 in Daz Studio Discussion
  • Have you made Yourself In DAZStudio and What is Best HeadShop or FaceGen?
    The facial geometry matching on all of those is fairly limited. Headshop does a good job with its markers but they are just too few for detailed transfer. There is KeenTools face builder that can do a lot more detailed sculpting but does not support actually applying it to a daz model so you have use it in blender and use a technique like shrink-wrap to get it on a g8 model and that requires some practice and patience and lots of trial and error. But that's just the shape the maps are useless from facebuilder so I usually use one of the other daz face tools for the texture map. That's still only going to get you so far because the blender to daz part is limited to non HD so you don't get the finer details. If it's not for closeups or portraits that's fine otherwise you need to then use your artistic eye and library of morphs to add in and adjust all those details and correct proportions. I'm about to release a type of virtual vellum for the pc for this purpose. In any case the point is there is no magic one click solution it still requires some elbow grease and art.
    By
    charles charles July 2021 in Daz Studio Discussion
    thenoobducky said:
    charles said:
    Those are cool! The second being a very clever speed option. I really just want to cull back my library of stuff I have never used and probably never will. I will probably do it in c# as I can't see it being very complicated. Just a dictionary bucket sort with simple class objects with a counter and cross matching. Parsing is my specialty from my NLP databasing days in PHP. xml and Json I don't even bother to handle in traditional ways. I use regex to locate markers and strip and grab around them. In the end it should just produce a list of every morph folder never used In anything I have in my scene files. I can then pick and choose what to unistall accordingly. That's the plan anyway!
    Coincidentally, I have enough features in my program in a law few days that it almost does what you want. It can analyse files in a single folder and spit out the required Daz product and other files. The only things missing are recursively processed a folder and find transitive dependencies (like if product A requires product B).
    C# definitely make implementing the program easy. Just have to poke at DIM install manifest folder and Daz metadata.
    If I can use it to make a negative list that would be cool. I could just copy all scene files across my work drive and dump then into a single folder on scratch drive. The other thing is though my daz content library is split into 2 locations. One for daz content on work drive and thousands of 3rd party add-ons on a dropbox dedicated drive.
    By
  • Diffeomorphic -Daz to Blender - costume missing?
    I'm not sure where the files are on your computer, but here is a way to fix it.
    Either search for the files on your computer or manually download the Rocker outfit from the DAZ site.
    Right click, copy the 3 or 4 folders in the 'content' folder.  They should include 'data', 'people', and 'runtime' folders.
    Paste those folders to c:\users\admin\documents\daz 3d\studio\my library\   (those folders already exist there, you are adding to them)
    Diffeo will then look for the '...data/mada/rockerg8/...' items in that directory since you have that directory listed in your global settings.
    Basically you are re-saving the morph and texture data to a directory that is listed in the Diffeomorphic global settings so Diffeo knows where to look.
    By
    Krys Kryngle Krys Kryngle July 2021 in New Users
    It's pretty straightforward if it's a genesis.
    1. you export the character from DAZ as an OBJ on base resolution
    2. you import in blender with "keep vertex order"  checked
    3. make your changes and export from blender as obj and import that into DAZ using the advanced morph loader and find the morph dial on the figure
    4. apply shape rigger plus
    if you already have a character made and you want to convert it to a genesis character, can probably try shrinkwrapping it over your character as nicstt stated but can get messy if your character is very unique and you're probably better off starting over
    By
    davidtriune davidtriune July 2021 in Daz Studio Discussion
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE TREDICI
    @Ruthven
    ci sono anche altri 2 bundle in offerta a 1,99
    https://www.daz3d.com/after-party-bundle
    https://www.daz3d.com/sushmita-bundle
    Dovrebbe essere l'offerta "Christmas in July" (sono partiti lo stesso giorno questi sconti).
    Tra l'altro stanno regalando un freebe nuovo ogni giorno.
    Oggi ci sono i character base a 10 € (5€ invece i morph HD)
    PS ho notato che ogni giorno cambiano qualche oggetto in sconto (qualcuno che era in sconto a 1,99 adesso non c'è più)
    By
    Kainjy Kainjy July 2021 in The Commons
    Coincidentally, I have implemented enough features in my program in the last few days that it almost does what you want. It can analyse files in a single folder and spit out the required Daz product and other files. The only things missing are recursively processed a folder and find transitive dependencies (like if product A requires product B).
    By
    thenoobducky thenoobducky July 2021 in Daz Studio Discussion
  • how do i get hair to work with her head morphs : ( the ears are not separated....
    thank you ^^ it not working with this head morph very well as the top of the head still gets removed hmm will have to try a different morph setting
    By
    Akura Akura July 2021 in Daz Studio Discussion
  • 3D Art Freebie Challenge-July 2021-"Wild Wild West" -Entries Thread Only
    Well I finally got my render done... whew!  So my take on the Wild West?  How about a ghost story around a campfire... but is it really just a story??
    A Noise in the Dark
    Pete was just a young cowhand at the ranch.  He had been thrilled to be invited by the trail boss to go on his first real cattle drive… at least until tonight.  The noise was one he had never heard before and sent chills down his back.  Shaken,he looked to Old Rick for reassurance.  Old Rick had been around these parts since he was just a boy and knew everything there was to know.  But Pete found no comfort from his friend as he saw even Old Rick looked pale and rattled...
    Characters:
    https://sharecg.com/v/97276/gallery/21/DAZ-Studio/G8M-Walther-2.0 Walther for G8M
    https://sharecg.com/v/97283/gallery/21/DAZ-Studio/Walther-2.0-simple-hair-for-G8M Walther Hair
    https://www.patreon.com/posts/joel-for-g8m-40154646 Joel for G8M
    https://www.patreon.com/posts/49802480 Brian Irons for G8M
    https://www.patreon.com/posts/42357035 Jack Baker for G8M
    https://sharecg.com/v/97621/browse/21/DAZ-Studio/33-Eyes-Materials-for-the-Genesis-8-%2B-8.1-people  eye materials (some of the characters do not have functional eye material)
    Outfits
    https://sharecg.com/v/80023/browse/21/DAZ-Studio/Ghastlys-Space-Cowboy-Genesis-1 space cowboy outfit
    https://sharecg.com/v/95318/browse/21/DAZ-Studio/Leather-Cowboy-Hat leather hat
    https://sharecg.com/v/56255/browse/21/DAZ-Studio/Medieval-Boots-and-Shoes medieval shoes
    https://www.renderosity.com/freestuff/items/66816 famous hats
    https://www.deviantart.com/infamous-k96/art/Fallout-Lincoln-s-Repeater-for-Daz-Studio-G8-868128400 repeater rifle
    https://www.most-digital-creations.com/revolver.php  revolver
    https://sharecg.com/v/60586/browse/7/Material-and-Shader/J-Tex-Tartan-2-for-Fabricator applied to various shirts
    https://sharecg.com/v/60285/browse/7/Material-and-Shader/J-Tex-Tartan-for-Fabricator applied to various shirts
    https://sharecg.com/v/80223/browse/7/Material-and-Shader/Pd-Soft-Leather-Daz-Studio-Shaders-for-Iray leather shaders
    Environment:
    https://sharecg.com/v/78490/browse/11/Poser/desert-pp2-landscape desert landscape
    https://www.deviantart.com/agentunawares/art/Skyset-005-715173309 sky set agentunawares
    https://www.cgtrader.com/items/2765262/download-page CGTrader campfire
    https://sharecg.com/v/83765/browse/21/DAZ-Studio/HD-Infinite-Rock rock
    https://sharecg.com/v/31571/browse/21/DAZ-Studio/Blowing-Leaves-Prop Blowing Leaves Prop (used to make embers)
    https://www.renderosity.com/freestuff/items/63946/covered-wagon-2 covered wagon 2
    Tools:
    https://www.renderosity.com/freestuff/items/86848/m4h4f4-pose-transfer-to-g8m  M4 to G8M pose transfer by Richard (thanks!)
    https://www.renderosity.com/freestuff/items/75710/wild-west-street-action  wild west poses
    Postwork:
    fixed embers (made them slightly brighter), adjusted colors and added signature in PaintShop Pro 2020
    No purchased items.
    By
    Sky77 Sky77 July 2021 in Freebies
  • Looking for a Lynx
    Lyne made one for Poser a looong time ago that should be useable with some surface tweaking.
    lynesfree (lynescreations.com) scroll down until you see pictures and it's the 4th one down.
    ETA - it's a morph, textures and poses for the old Daz Mill Cat so you'll need that.
    By
    Haruchai Haruchai July 2021 in The Commons
    thenoobducky said:
    charles said:
    When I get back from vacation I'm going to write a program to analyze all scene files from multiple directory trees. Make a USED list and then compare that to a dump list of morphs and return a list of all never used morphs and paths. That way I can figure out what is safe to delete. The only tricky part I can think of is if the zip compression is all that is needed for opening compressed files. I often don't compress scenes and poses but do for subs and materials and each will have to be opened to figure out what type of file it is as they all share the same extension for some brilliant reason.
    This should do what you are proposing and I think it still works (Vaguely remembering it kinda works despite it being an old tool when I tried it). The tricky part is knowing what you want to use in the future and make it easier to add more content to the scene. Which is why I made this.
    On the technical side, the tricky thing is to find dependencies recursively. Otherwise, you just need a programming language that let you open gzip file, query JSON file, and maybe handle xml as well.
    By
  • Brunch Coat - Updated, textures fixed and added to
    pscott2 said:
    Hello again!
    I was hoping I could just download it from the site..I need a Teamviewer to transfer the files to the right folder because I could never get that right.  It's so frustrating..
    Catherine3678ab said:
    Okay. It's in the wilds: Click here for sharecg link.
    It is not perfect. Apparently while the normals made nice buttons, they also raised seams! Which they shouldn't have, I don't know why ... and my first attempts to address that matter didn't help. So rather than keeping everybody waiting, I'm releasing the garment "as is" ... holding texture, 2 sets of buttons as already mentioned, 4 little morphs to start opening the garment [will show on the Parameters Tab], 2 shape presets to get them started, and a couple of mat files, one for open and one for closed. Also the same again with minor changes  for 3Delight mat files. Includes a readme and template.
    I think you sent me an email - so check your emails, I replied.
    Basically, just merge the My Library folder into your My Library folder and everything should land where it goes.
    Where you put your content [not the program folder] ...  \DAZ 3D\Studio\My Library ...
    Then use the Content Library tab to find stuff ... under People > Genesis 8 Female > Clothing > CEF ...
    By
    Catherine3678ab Catherine3678ab July 2021 in Freebies
    3D Art Freebie Challenge July 2021 "Wild Wild West"
    Here is my first render for this month, 2nd is already rendered but still needs some postwork. This 1st picture took an awful lot of D-Formers!
    [Best watched at full size for details.]
    "La mujer de la armónica" (The woman with the harmonica)
    Starring: Nico and Riley
    The tale:
    Once upon a time in the Wild Wild West, one last encounter, the final reckoning...
    Soundtrack:
    Ennio Morricone - Once Upon A Time In The West, Man with a Harmonica (© 1972)
    https://www.youtube.com/watch?v=m6BQKFs3-VM
    COUNTABLE FREEBIES: (Alphabetic order)
    #01! 3D Photo Scene Rocky Plains by Dreamlight
    https://digitalartistreviews.com/2019/12/24/christmas-2019-freebie/
    #02! Amelie (Death Stranding) Morph for G8F by ElSinestroUno
    https://www.deviantart.com/elsinestrouno/art/Amelie-Death-Stranding-Morph-for-G8F-836591073  **
    [Hair]
    #03! Ashley Brown for G8F by Shinteo
    https://www.patreon.com/posts/ashley-browns-46096967
    [Short Pants]
    #04! Aurochs Skull 1977-5012 (OBJ) by NHM_Imaging
    https://sketchfab.com/3d-models/aurochs-skull-1977-5012-30a8753007bd4e9fac33c18a06512562  **
    #05! Colt "Peacemaker" (OBJ) by Lucien_Lilippe
    https://www.sharecg.com/v/81506/gallery/5/3D-Model/Colt-peacemaker  **
    #06! ED's Brick Shader (Iray) by Edheldil3D
    https://www.deviantart.com/edheldil3d/art/Freebie-ED-s-Brick-Shader-Iray-788871766  **
    #07! Goat Shack Accessories by McGyver
    https://sharecg.com/v/39278/gallery/11/Poser/Goat-Shack-AccessoriesUpdated  **
    [Worn wooden board]
    #08! Grass as Grass can be! (DAZ3D, Iray) by SmidA
    https://www.renderosity.com/freestuff/items/88095/grass-as-grass-can-be-daz3d-iray-  **
    #09! Harmonica (.blend) by abraxal
    https://www.sharecg.com/v/1883/3d-model/Harmonica  **
    [Exported from Blender as .obj]
    #10! HD Infinite Rock - Iray by Kaindayo
    https://sharecg.com/v/83765/related/21/DAZ-Studio/HD-Infinite-Rock  **
    #11! Iray car related shader presets 'megapack' by Tom2099
    https://www.deviantart.com/tom2099/art/Iray-car-related-shader-presets-megapack-539622361  **
    #12! mcjHatsAreTheFashionOfTheDay (Script) by mCasual/Jacques
    https://sites.google.com/site/mcasualsdazscripts9/mcjhatsarethefashionoftheday
    #13! Morphing Garden Style Stone by Mapps Graphics
    http://www.freewebs.com/mapps/downloads4.htm  (last item)
    #14! Nico DMC5 for G8F by TaliDesade
    https://www.deviantart.com/talidesade/art/Nico-DMC5-Genesis-8-DOWNLOAD-866641918  **
    #15! Nico for G8F and G8.1F by Shinteo
    https://www.patreon.com/posts/nico-for-g8f-and-50970518
    [Boots and Top]
    #16! Passer domesticus (OBJ) by Digital Archive of Natural History
    https://sketchfab.com/3d-models/passer-domesticus-eeffd0bb0d28471aae9b13937b2087db  **
    #17! Props - Special Toys by squarepeg3d
    https://www.renderosity.com/freestuff/items/76265/modular-madness---special-toys---100-free  **
    [Leather and metal shaders used]
    #18! Remains Set 2 - Ruined Cottage by DryJack
    https://sharecg.com/v/55041/gallery/21/DAZ-Studio/Remains-Set-2-Ruined-Cottage  **
    [Wooden plank]
    #19! Riley for G8F by Shinteo
    https://www.patreon.com/posts/riley-for-g8f-42409109
    #20! Rusty junk set 1 by DryJack
    https://www.sharecg.com/v/53012/gallery/21/DAZ-Studio/Rusty-junk-set-1  **
    [Tin cans]
    #21! SAV Famous Hat Collection for M4 by StudioArtVartanian
    https://www.renderosity.com/mod/freestuff/sav-famous-hat-collection-for-m4/66816  **
    #22! SY 200 Morphs for Genesis 8 Head and Body by SickleYield
    https://sharecg.com/v/91888/view/21/DAZ-Studio/SY-200-Morphs-for-Genesis-8-Head-and-Body  **
    #23! Windmill (.blend) by yanix
    https://sketchfab.com/3d-models/windmill-747c168a3adc47528e8cd6483f0dabba  **
    #24! Winchester Model 1873 (.blend) by Tuuttipingu
    https://sketchfab.com/3d-models/winchester-model-1873-f1f57078e79e49289e14f0a551b5b60e  **
    #25! Wood Stick 04 (.fbx) by 3dhdscan
    https://sketchfab.com/3d-models/wood-stick-04-b7fe8a4a3c2f4f038662ae47cfbfa6a7  **
    NO-COUNT ITEMS:
    ---   Gun belts by Questor
    PURCHASED/PAID FOR ITEMS: None      100%    Freebies
    *1     E-mail address required
    **     Registration required
    #x!   Countable Items (Bold ones are used by me for the first time I think.)
    ---     No longer available freebies
    ++    Free with DAZ Studio (or the Essentials)
    $x.   Purchased/Paid For Item
    Rendered with DAZ Studio 4.10.0.123 (nVidia Iray)
    Other free software used: Blender 2.79b, GIMP v2.10.24 and Irfanview 4.57
    Postwork: used the AltaLux Image Enhancement Filter (Effect) by Stefano Tommesani that comes with Irfanview and some filters (oa) that come with GIMP.
    By
    JackyBrown JackyBrown July 2021 in Freebies
  • 3D Art Freebie Challenge-July 2021-"Wild Wild West" -Main Thread Only
    A Noise in the Dark
    Characters:
    Outfits
    Environment:
    Tools:
    Postwork:
    No purchased items.
    This is approved, please move to entries!
    By
    Saphirewild Saphirewild July 2021 in Freebies
    The tale:
    Soundtrack:
    [Hair]
    [Short Pants]
    [Worn wooden board]
    [Boots and Top]
    [Wooden plank]
    [Tin cans]
    NO-COUNT ITEMS:
    By
  • Json Parser syntax error in log - Genesis 8 Male Smart Content no longer working
    Well, I don't think it's a morph file.  Maybe something else.
    I temporarily moved all the 3rd-party add-on morph directories away from the Library directory and still got the error.  I then moved the named character subdirectories out of the DAZ 3D morph directory and still got the error.  I then had just the base figure stuff -- all about two years old, 2019, by file date.
    I even moved my 3rd party product library out of the tree so DAZ wouldn't see it when it started -- same error.
    It's either some other type of file associated with a G8M load, or some other key DAZ Studio file is corrupted.
    By
    Olo_Ordinaire Olo_Ordinaire July 2021 in Technical Help (nuts n bolts)
  • HELP IDENTIFY could it have its own Section?
    SickleYield said:
    Torquinox said:
    Maybe. The real traffic is in The Commons. This is a sideshow. I'd sometimes look at the ID posts when they were in The Commons. Sometimes, I even knew the answer - Not often. These days, not at all.
    It seems Sickleyield sometimes looks here. I doubt she's looking for ideas of what to do, but she might be interested in what people are saying.
    But I'm not a moderator?  I'm just a Published Artist.
    Sorry, SY. I don't understand. "Just" a published artist? No. Actually, I think you're the most generous and helpful PA I've ever met, and you're a gift to the Daz community. That's a fact.
    For context, FSMC said, "It has been pointed out in other threads that many PAs don't even visit this forum or are told not to as new PAs for whatever reason." I know you look here because I saw your recent post about your work on a high heel morph solution. I hope you're successful with it. AFAIK, you look in many forums around here. If you're also a moderator, that's a well-kept secret. angel
    By
    Torquinox Torquinox July 2021 in Product Suggestions
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
