Deformations
The arms up and down is being handled with a morph, not a joint rotation. A morph movces the vertices along a straight line from the starting postion to the final position, it doesn't rotate around a centre as the joint does.
AM LynxAlessandro Mastronardi said:
@AllenArt , this model represents an Eurasian Lynx (so not a bobcat or canadian lynx), but once I'm ready with textures I'll put those up too. I'll make also adjustments (morph controls) to control legs positions and posture. Cheers.
[daz3D is really driving me mad]Success!
Okay :-)
On the Parameters Tab look here: Actor/Head/Face/Eyes/Real World
You might have "Eyes Cornea Bulge"
This morph is activated by the Shape preset "OnFleek Cornea Bulge On" which is free here: https://shop.aprilsvanity.com/onfleek-for-genesis-3-8-female-s.htmlTo download, click the "Download for Genesis 8 Female" at the bottom of the product description.
What Model/Morph is this??That's a nice body morph! Would love to know as well.
[daz3D is really driving me mad]vascoaredji said:
You suggested, sorry my english is very poor, to get a "iris bulge morph" somewhere or check if I got a parameter in the "surface pane" to modify settings related to reflection/refraction of the light around the iris ?
Yes, iris or, in looking around I find it may be referred to as a cornea bulge morph. I know there was one at sharecg but didn't find it on first search. I know that several characters came with one - it would be mentioned in the product description if it does. Not in the Surface Pane, look in the Parameters Pane ... possibly somewhere under Actor, head, etc. I'll have to load in a figure and see if I can find one ;-)
[daz3D is really driving me mad]You suggested, sorry my english is very poor, to get a "iris bulge morph" somewhere or check if I got a parameter in the "surface pane" to modify settings related to reflection/refraction of the light around the iris ?
Convert Genesis 8.1 model morph to 8.0FenixPhoenix said:
Regarding Morphs:
- Morphs that work on Genesis 8 should work on Genesis 8.1 automatically. Morphs created for Genesis 8.1 can't be used on Genesis 8 out of the box.
Regarding Geoshells
- These can work on Genesis 8.1 with some manual tweaks. Genesis 8.1 splits the "Torso" skin surface into two different surfaces: "Body" and "Head". So the process to make it work will be as follows:
- Load a Genesis 8 and a Genesis 8.1 Figure.
- Apply the Geoshell to both figures.
- Select your Genesis 8.1 Geoshell and select the surfaces (windows > panes > surfaces) "Body" and "Head".
- Now, in your content library, go to Shaders Presets > Iray > DAZ Uber. Locate the shader "!Iray Uber Base" and apply that to the surfaces you have selected.
- Next, select you Genesis 8 Geoshell and locate the "Torso" surface.
- Copy the settings by using cntrl+c or left click on torso > copy selected surfaces...
- Now select once again the Genesis 8.1 Geoshell and paste the settings into the "Body" and "Head" surfaces.
- You can now save that Geoshell as a wearable for future use.
Custom Maps:
- Custom maps I'm not sure what you mean. Genesis 8.1 has a compatible UV version of Genesis 8, so skins from Gen 8 will be applied without issues to Genesis 8.1. However, Genesis 8.1 skins cannot be used on Genesis 8 if they use 8.1 Base UVs.
Hello, thanks for all of the useful tips & the time you putted into your post :)
I was indeed trying to make a 8.1 morph work on 8.0, but since you made the genesis 8 to 8.1 bridge look so easy, look like I won't need it anymore !
By custom maps I was talking about map I made myself or bought on other marketplace so your answer is on spot.
Cheers !
What Model/Morph is this??There is an outfit sold by "chungdan" called, "MG Outfit for Genesis 8 and 8.1 Females." Does anyone know what models/morphs are use in the promotion? The bodies look curvy, and the breasts look realistic. Pics attached below: Link to page here.
[daz3D is really driving me mad]The issue with the eyes is common to the figures - it's an Iray thing. Similar to the haircap mesh - again there are layers of mesh very close to each other.
You might already have a an iris bulge morph in your collection [check over on the Parameters Tab]. Several characters come with one. There are also a few free ones available possibly over at sharecg.
Also the lighting plays a big role in how the eyes will appear. Iray needs lots of light. Note that the 'create light' features work better with 3Delight. Iray can make use of mesh lights. A sphere for example, cutout geometry at 0.0001, emission 'white' [that turns it on, black turns it off], set to the k* value of maybe 500. Do not put it between camera and figure though or a there may be a snowball of white pixels ... set it off to the side of or higher and behind the camera.
Convert Genesis 8.1 model morph to 8.0Mainly geoshell,custom map & morph :/
I know how to make them compatible toward genesis 8.1, but it would take so much time for all of them
Genesis 8.1 / Victoria 8.1Has anyone faced such a problem? I transfer morphs from 8 models to 8.1 through .... Everything rises normally, but it becomes unrealistic to move my eyes. Even closing them is problematic. Everything else is fine. And so any model when transferring.
Convert Genesis 8.1 model morph to 8.0Hello all, I've been trying to convert my genesis 8.1 morph to genesis 8.0 but without any success.
I tried to export it as an OBJ and just import it back on my figure with the morph loader option, but I lose a lot of details since it only allow subd0 from what I've seen.
Is there a way to completly transfer my genesis 8.1 to a genesis 8.0 figure ? I have a lot of things that I've made for genesis 8.0 and I don't have the courage to redo everything to work properly on genesis 8.1 since the change are so little.
Thanks !
Felldude's Freebies for G8 and G8.1Amputee (Left Leg) Morph for G8F/G8F.1
Maybe I will have a full pack done by April if the morphs are used. (April is Limb loss and Limb Difference Awareness month)
DOWNLOAD
AM Lynx@AllenArt , this model represents an Eurasian Lynx (so not a bobcat or canadian lynx), but once I'm ready with textures I'll put those up too. I'll make also adjustments (morph controls) to control legs positions and posture. Cheers.
SereneNight’s Sci-Fi Fun Thread 3Butch said:
This is my quarterly safari into the forums...
With the one-piece morph, have you tried using the Head Split D-Former? I've followed the benalive tutorial and it separates the head and body surprisingly well...
Oh, yes, I've done that with another RawArt character, Raw Pete. It's just a pain, plus the process essentially downsamples the HD, and you can't get that detail back if you want it. The tutorial is a little difficult to follow in parts -- the teeny type Studio interface coupled with a few places where he figures you can follow along with what he's doing on screen and he stops talking -- but it's workable. Like I say, it's just a pain to need to do that.
Umbra Outfit for Genesis 8 & 8.1 Females [Commercial]N3p3nth3 said:
marble said:
N3p3nth3 said:
marble said:
You (HH) are obviously skilled at crafting a good quality mesh but I'm not really into these fetish sets. I would humbly request that you put those skills towards making a non-fantasy lingerie set. One that might be bought in a real-life department store?
I've looked and can't find a good, realistic full set of bra/panties/garter (suspender belt), perhaps with a thin-soled (non-platform) pair of high-heels. Many of the available stocking sets don't even allow for the pull of the suspender clips (sorry, I don't know the correct terminology). Also, the couple I have bought suffer badly from poke through the moment I dial in a morph to G8F. I never use a base G8F so those purchases are difficult, if not impossible, to fit to my characters.
Have you checked out his original Mystique and Mystique 2? I mean, I've certainly bought some like that in the past as presents - but then again, I've also bought an Agent Provocateur Whitney set (and I think also did beg request HH to do something like that :D). You can ditch the corsets etc. in the Mystiques and get a really nice normal-but-sexy kind of lingerie. I'm doing a render with the Mystique 2 stockings on the HD Athletic body right now - the body's usually a nightmare with a ton of air between the legs and the stockings, and the stockings are following the body like a dream.
OTOH, I appreciate the different-ness of these shoes. There's a lot of vanilla heel options and most of them should work just fine with the Mystique stockings. I will confess to being an inveterate kitbasher, though.
Yes, I looked long and hard at the Mystique 2 product before deciding against it. The pantyhose looks very realistic and that was almost enough to sway me but the rest is just too kinky. The multiple straps in particular. I just want a good, realistic-looking but fairly conservative set for a middle-aged lady I have ready for render. I'm sure that HH could create the definitive product and I'm certain it would sell. I've looked elsewhere (on both "R" sites) and the choice is poor.
Well, the word you used was "realistic" which given the current connotations of garter belts did not lead me to think of conservative. Mystique 1 is less strappy and frankly, just typing lingerie in the search field should still bring you a bunch of reasonable options from reputable vendors, making me echo FSMCDesigns. HH's releases stand out, and that's what is so great about them in addition to their extremely high quality, both visual and technical.
I do know how to type in a search. What I consider a good option might be different to you - as I said, it is just my opinion. I'm not suggestng that HH should stop producing his specialities - just requesting a more conventional look - even as a one-off. It is the high quality that prompted me to ask.
SereneNight’s Sci-Fi Fun Thread 3vwrangler said:
Serene Night said:
I picked up Athena HD Cyborg since she is a very classic gynoid.
Includes guns. The skin is any female you want. She's basically an outfit, a morph, and the boots. The feet require the included foot pose. This character looks great and renders easily. Comes with multiple suit colors, guns, hand poses boots, and foot poses, and a preload for her.
I chose Zelaria's skin for her, since, she had the cyborg eyes.
Looks interesting. Will she be doing battle with/against Boyd and Owen?
An interesting yet frustrating couple days on the new guys front, as well.
Kooki99 seems to have hit their stride. They've had a lot of releases lately. And Joachim has an interesting and somewhat different face. And, alas, continues Kooki99's tradition of dingusless dudes. (I have been vaguely tempted to ask about that, since they have a dA page. However, that feels ... rude, somehow.) On the other hand, that price, though...
And RawArt has Veer in today's sales. (Wonder why vendors have been doing South/West Asian guys lately?Jazz, Nasiri, Adeeb, Rahul, Veer, all in this calendar year and all but one outside of a bundle release. The closest thing to that before now was the guys in and around Sanjay's bundle -- who were, by definition, related to a bundle.) On the one hand, Veer looks interesting -- on the other, he's a one-piece morph, which is what RawArt likes to do, so you can't get the face or body alone. It does look like maybe his skin is a bit more gently textured. And, of course, he does have a dingus.
3D Art Freebie Challenge August_September 2021-"Science" -Main Thread OnlyAugust/September Freebie Contest - Science
Science in my fantasy: space mission, evolution of technology with humanoid robots.
It's more science fiction than real science.Hope you like
Science in my fantasy: space mission, evolution of technology with humanoid robot.
It's more science fiction than real science.No coint g8.1 f and g8.1 m
Freebies
PS Raeny Shape Morphs for Genesis 8 or 8.1 Female by pixeluna
https://www.renderosity.com/freestuff/items/88639/ps-raeny-shape-morphs-for-genesis-8-or-81-female"STRONG" for G8M Character Morph & Pose by Mar3D
https://www.renderosity.com/freestuff/items/82833/strong-for-g8m-character-morph-amp-poseSci-fi Suit for GF8
https://sharecg.com/v/97719/gallery/21/DAZ-Studio/Sci-fi-Suit-for-GF8Heleus Armor for Genesis 8 Male
https://sharecg.com/v/95690/browse/21/DAZ-Studio/Heleus-Armor-for-Genesis-8-MaleRebel Trooper for Genesis 3 Female
https://www.deviantart.com/amyaimei/art/Rebel-Trooper-for-Genesis-3-Female-580677805hologram console
https://sketchfab.com/3d-models/hologram-console-bfbbb481e98e4be38774b1d0204c192cFacility
https://sketchfab.com/3d-models/facility-beta-9d-assets-af82b47372064fda844baec238f68d7bTablet
https://free3d.com/3d-model/ikea-frame-66557.htmlTablet text
SY Math Magics Iray
https://sharecg.com/v/97801/related/21/DAZ-Studio/SY-Math-Magics-Irayallen art jewlry iray shaders
https://www.deviantart.com/laurieart54/art/Jewelry-Iray-Shaders-Freebie-For-Daz-Studio-803216418
https://sharecg.com/v/95893/browse/21/DAZ-Studio/Iray-Jewelry-ShadersBackground image
https://www.nasa.gov/
https://www.nasa.gov/mission_pages/hubble/multimedia/index.html
