• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Loading the Highlands set makes daz crash-problem solved-cannot use filament view
    Vic, just for your info, this is from our prototyping PC which has a gently ageing i4770K (ancient compared to your CPU), an elderly GTX 1050 on monitor duty and an RTX 3060 for rendering with 24Gb (yup, odd!) of system RAM. Both cards are using Nvidia's 511.65 studio drivers, rather than the gaming ones. It is running the Public Build (essentially the Beta) of Studio 4.20, not the General Release. This is the closest I can get to your PC. Highlands loads fine in both preview and render mode using 6GB of system RAM once it's settled down. It crashes Studio instantly in Filament with an unsigned variable error. This is probably correctable by directly editing the .duf file but... life is too short. It doesn't work in Filament.
    I think you're running out of system RAM due to the way you use your PC and the other software you've installed. You appear to be doing what we do with 4 PCs on just your one! You could prove/disprove this one way or the other by wiping your boot drive and starting again and just installing Studio before any of your DAWs et.al.  but it's a huge amount of work which may amount to nothing. Hard to recommend, but it depends how much you want to be able to use Highlands or sets that impose a similar load on your PC. Have you run any of the diagnostics I suggested earlier? I think they, too, will prove nothing is wrong with your system but it's worth doing to eliminate a potential cause.
    I genuinely have nothing left to offer and because there's nothing wrong with the product, you won't get much joy from Support I suspect. Over to you...
    By
    TimberWolf TimberWolf May 2022 in Daz Studio Discussion
  • how to quicken an Iray animation in the settings
    Padone said:
    You can also use the interactive mode instead of photoreal, since you said you can go with loss of quality. Or use filament. Personally with iray I can't go below photoreal with 128 to 256 iterations for my quality taste, depending on the scene, even using the denoiser.
    for still images that is understandable but for animations it is less crucial
    By
    WendyLuvsCatz WendyLuvsCatz May 2022 in Daz Studio Discussion
    p.s. Of course these are just the settings. The first thing you have to do is simplify the scene, for example using the scene optimizer addon.
    By
    Padone Padone May 2022 in Daz Studio Discussion
    It's two different issues. Some of the big sets have never worked with Filament from the outset. We've got 4.15, 4.16 and 4.20 on different machines here; Highlands has never worked with Filament on any of those versions, and neither have many other products.
    An insta-crash to desktop without any notification from Studio (unlike the Filament crash) is, in my experience, almost always related to Studio's intolerance of virtual memory paging. That said, I could be wrong of course but I think this is conflating two entirely separate problems.
    By
    From your second Zip...
    Are you using a Wacom tablet, have you tried disconnecting it?
    In relation to Filament, there is mention of "std::vector<unsigned char,std::allocator<unsigned char> >::_Xlength" - Doesn't sound good, therefore I would not use Filament preview.
    By
    PerttiA PerttiA May 2022 in Daz Studio Discussion
    I'm also having DAZ Studio (4.20) crash when trying to use Highlands. Oddly it seems to occur when I try to work in Filament or texture shaded mode rather than in Iray. And I have 32 gb of system RAM, so I'm dubious that memory is the problem.
    I'm also having similar problems trying to work with Plains and Mountains when trying to get closer to the mountains
    By
    Charlie Judge Charlie Judge May 2022 in Daz Studio Discussion
    I dont know if this matters but here is another report, with all other things closed and most window browsers, i reinstalled the DIM, daz was in filament view while highland loaded
    By
    VicS VicS May 2022 in Daz Studio Discussion
  • Why does the preview renderer have no shadows?
    the preview render is actually whatever is in the viewport including wireframe or bounding box views etc
    the only thing it doesn't preview is 3Delight
    Filament has shadows if you have lights
    Textured view can to an extent with spotlights
    By
    Soemtimes it craashed right off the bat sometimes it lets me do a few thigs first
    Is anyone else having this problem, if so i8s there any way to make it run load and work correctly?
    thanks
    https://www.daz3d.com/highlands
    By
  • When will the Filament Render be available for Mac users?
    Yes, you'll have to wait for D|S5 to have Filamnet, but D|S does work under Monterey, so if you want you can keep working in D|S 4.20.xxx now until Filament is available in D|S5.
    -- Walt
    By
    wsterdan wsterdan May 2022 in Daz Studio Discussion
    leemoon_c43b45a114 said:
    I am looking forward to DS 5 when it arrives.  Perhaps others with more inside knowledge can offer a better guess on when that might be. :)
    Lee
    No insider knowledge, sadly, but a DAZ rep did post that they actually had Filament working in the pre-beta they were going to release before they finally got DAZ Studtio to work  under Big Sur without needing a DAZ Stuido 5 update.
    No new word as to when D|S 5 will be released to the best of my knowledge, but hopefully it will be beforethe  two two-year anniversary of Filament being released for Windows.
    -- Walt
    By
    From what I understand, Filament could appear in the next major version of DAZ Studio (version 5) for macOS.  The DAZ development folks first needed to update the cross-platform SDK used to create DAZ Studio.  This would allow for additional macOS features (and Windows features.)
    No timeline has been given for when we might see DAZ Studio 5, or if it will initially offer Filament for Mac.
    Lee
    By
    Lee Moon Lee Moon May 2022 in Daz Studio Discussion
    Hi, this is njs (he/him).
    I was just wondering when the Filament Render be available for mac users?
    I do remember asking the tech support team about it, they replied back saying not at this time.
    It could happen eventually.
    I'm just curious if anyone knows about it yet.
    By
    njs njs May 2022 in Daz Studio Discussion
  • iClone 8 and CC4 anyone?
    @FSMCDesigns yes, G2 not G3.
    I was looking around for something that I might be able to migrate to which has those missing features but is not a start-from-scratch modeller like Blender. Even Blender with Diffeo is a bit of a schlep switching between DAZ Studio and Blender. As far as I know, DAZ Studio and Poser are the only two applications which are so similar - there isn't another like them. So it is a pity that neither has the wished-for features. I would pay for a DAZ Studio which could boast a decent cloth sim, a decent animation toolset and soft-body physics. Even a better real-time render engine because the version of Filament that is implemented right now is not even close to Eevee.
    By
    marble marble May 2022 in The Commons
  • Hair transluscent in most angles in filament?
    I am wondering why it takes so long to get Filament to render hair correctly. It's almost good enough for finished renders, esp if rendering at twice the resolution and then resampling which makes it look more crisp.
    By
    PPehrson PPehrson May 2022 in Daz Studio Discussion
  • Toning down preview strengh
    There will also be a Filament Options node which you can select and adjust to tame the brightness.
    By
    Richard Haseltine Richard Haseltine May 2022 in Daz Studio Discussion
    That definitely looks like a Filament preview, so switch to a different viewport draw style.
    By
    Gordig Gordig May 2022 in Daz Studio Discussion
    Do you mean to be using Filament?
    By
  • List of Filament Resources
    Review: SF Beautiful Skin Filament by Sickleyield and Fuseling
    https://www.daz3d.com/sf-beautiful-skin-filament
    Organic material is a big challenge for DAZ Filament, it often looks quite unnatural, especially when compared to IRAY - the price to pay for lightspeed renders on weak Hardware.
    SF Beautiful Skin Filament tries to help the user achieve a more realistic look for skin material in DAZ Filament.
    It does this with the clever use of additional geometry: a geoshell is placed beneath the skin of a G3 or G8 figure, the slightly reduced opacity of the skin surface fakes a subsurfacescattering effect by letting the underlying shell material influence the look of the skin.
    To further support the user, 2 Filament lights have been included.
    Finally the customer receives two Filament hair shader presets and Filament hair caps as a bonus (These are not being reviewed)
    How to use it:
    First complete your basic figure and light setup. You can use and fine tune the included Filament lights.
    Then select the figure and choose one of the three basic skin tones in the "Materials" folder which suits your figure best (here G8F)
    Next add the appropriate "SSS Emulator Shell" in the "Anatomy" folder. Your figure should be still selected.
    Now you can further enhance the look of your figure by using one of the 15 "Complete Presets" (here the 15 Presets for the basic G8F Dark Skin Material (also in the "Materials" folder).
    Finally you can use the 30 "Diffuse Tints" to fine tune your figures' skin tone. (They can be used with all three basic skin tones you might have chosen, here G8F)
    My impression:
    Raw render without any changes:
    Lighting has been tweaked:
    Tweaked lighting and the RSSY Filament Base Shader Preset applied to the skin. (From the product: "RSSY 3Delight and IRAY to Filament"):
    Tweaked light and "SF Beautiful Skin Filament" applied:
    These are the results I got as an advanced beginner tweaking only a few minutes.
    Comparing the four skin renders I personally prefer the last one. My impression is that the RSSY Base Shader can't replace this product and therefore I recommend it. Filament will never reach IRAY standard, but this product gets you a step closer, it has become a great addition to my DAZ Filament tool box.
    By
    mding mding May 2022 in The Commons
  • Daz Studio Pro BETA - version 4.20.0.17! (*UPDATED*)
    Anarkia333 said:
    WendyLuvsCatz said:
    OK this is new and exceedingly annoying.
    the animation range reverting to 217 on reopening scenes is always annoying and stopped for a few builds
    now it is back with sprinkles on top, it does it on the fly everytime I do something like pan a camera angry
    OMG guys use DAZ for animation is soo ridiculous cheeky
    yeah, just spent 17 hours rendering the New Sponza Atrium from Intel with iray 1800 frames
    https://www.facebook.com/wendy5/videos/3939049862886761
    back to Filament and sanity now wink
    BTW DAZ does not import the FBX nicely so unless you have something that does Like Carrara with textures and glow on bulbs! to export an obj, don't bother
    https://www.intel.com/content/www/us/en/developer/topic-technology/graphics-processing-research/samples.html
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
