• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Lighting a painting.
    You're absolutely right about sketchup and the weird geometry sometimes.  Try running your object through this https://github.com/wjakob/instant-meshes .  I forget who to thank, but i found it on a forum thread here recently.  It will clean up your sketchup geometry and convert it to quads which will work better here in DAZ.
    By
    Spacious Spacious February 2021 in Technical Help (nuts n bolts)
    This is what I mentioned in my previous post. The surface normals of geometry for the surface have to be pointing in the right direction or the IES Profile wont work as intended. There was a wall light/street light in the store with an IES Profile already loaded that shone in the wrong direction, to the right instead of down, which had the normals facing the wrong way and had to be fixed. I did it myself by using the Geometry tool I think, it was a while ago so I can't remember exactly :)
    Sure, of course they are.  That's one of the great things about sketchup is a single surface will appear triangulated if the vertices aren't coplanar, and if they're pointing "away" from the viewpoint they appear with a blueish tint.  The issue is more subtle I think.  For example, I applied BEGA 2675 (from here) IES profile to my light material, with the following result:
    As you can see, the lighting is skewed to the right.  You would expect that simply choosing the first three vertices on the surface, assuming they're coplanar, would be enough to generate a basis for transforming the profile.  This is not the first time I've had trouble with IES profiles on surfaces.
    Note that normals don't have a helicity, so it's not clear from looking at the above what's "wrong" with the geometry (the geometry is fine, there's something wrong with the algorithm).
    By
    Robinson Robinson February 2021 in Technical Help (nuts n bolts)
    Here's a thing I'm trying to do... not sure how to do it...  Got some archviz I made in Sketchup and want to light some paintings, so I thought I'd do a wall lamp, art gallery style (in Sketchup) and make one of the surfaces emissive.
    Sketchup Painting Light
    Now from previous experience I know that IES profiles don't really work on arbitrary geometry (I tried one profile, but it seemed to be skewed off to the left so I gave up on that).  As you can see from the second image with a standard emissive, I'm simply getting over-exposed from the light against the top of the painting.
    Archviz
    What I want to do is illuminate a whole area of the painting, as if it were coming from the lamps.  Here's a close-up of the lamp:
    Lamp close-up
    Are there any "tricks" I can use?  I tried a light plane with very low opacity, but of course it emits two sided so lights the entire room, which I don't really want.  Any ideas gratefully accepted.
    By
  • Imported .obj with messy geometry texture
    There is a sketchup plugin which offers front-to-back and back-to-front copy: https://sketchucation.com/plugin/740-tt_uv_toolkit
    By
    genius_3587271 genius_3587271 January 2021 in New Users
  • **FREE* 20 Free Classic Car Models!
    Miss Bad Wolf said:
    Checking them out, but what is a skp file?
    Sketchup. It's a different modeling program.
    By
    Torquinox Torquinox January 2021 in Freebies
    yes Sketchup has double the geometry as it backface culls and DAZ studio does not like overlapping geometry inhabiting the same 3D space
    By
    WendyLuvsCatz WendyLuvsCatz December 2020 in New Users
    Yes, it will be broken into triangles - the thing to avoid, or at least a thing to avoid, is long, thin triangles - which you appear to have above (it's the way Sketchup has always tended to break up the large planes that make up its models, and it has always tended to be an issue as here as I recall).
    By
    Richard Haseltine Richard Haseltine December 2020 in New Users
    Merry Christmas Everyone!
    i'm a beginner and maybe the problem i'm having is something simple to solve but i don't know how.
    I made this street in sketchup, I opened it in 3ds max, everything ok and exported as obj ... for some reason only the part of the asphalt got messy and as I change the position of the camera, the mess in the texture changes randomly .
    There are no double faces on the model.
    I don't know if this is something that needs to be corrected within DAZ or directly in the model (but as I said, everything is perfect in sketchup and 3ds max), but I have already created two complete furnished houses, using this same process and I didn't have this problem importing into DAZ before ... now this asphalt thing is killing me.
    By
    FExFO FExFO December 2020 in New Users
  • Obj's Exported From SketchUp Into Daz Not Showing UP
    Try exporting it as a DAE into Blender and from Blender, out as an OBJ...
    Are you using SketchUp Pro's native OBJ export or a Ruby plugin like TIG's OBJexporter or the one that comes with SketchUV?
    Those are good, but they often fail with bad or complicated models... and to be honest SU's native OBJ export really sucks and I stopped using it years ago because it's just unreliable when used with DS or Poser... it seems to work okay with other programs, but with each version of SU, the OBJ export/Import had some other unique weirdness (Then again... that impression was formed when I worked on a Mac, and everything is weird on a Mac).
    To avoid me being too wordy or not wordy enough, I hope you don't mind me asking... How familiar with SketchUp are you?... do you model with it or just use it to bring stuff over from 3D Warehouse?
    Like if you are fairly familiar with it, I don't wanna make suggestions you probably already know, and if you don't give a poop about ever using SU for anything other than getting models into DS, then I don't want to bother you with unnecessary info or potentially unfamiliar terminology.
    By
    McGyver McGyver December 2020 in The Commons
    I can't seem to edit my friggin' comment without messing with code, so sorry to make this a separate post...
    I'm not clear as to whether the import has failed or the import seems successful, but you just are not seeing the model... two common reasons for this is the model is either scaled hundreds of times larger than the opening scene and you are actually inside the model and it so large it's outside the camera's range (plus if you are inside you are looking at the back of the normals which make them invisible)... and the other is the model is way outside the world center or world zero (X-0.0, Y-0.0, Z-0.0 coordinates)... the camera is set to aim a world center, but your model was made in Timbuktu 1000 miles away, so it's there but so far away you can't see it... that can be compounded by scale in consistency making it worse.
    SketchUp models generally end up being really, really big in most other programs.
    If you can see that the model has been imported but you don't see it, try shrinking the scale... it might be gigantic...  DS's import scale is confusing (I generally import to Poser and make it a PP2, and export that to DAZ, but that's because their my own models)... you might have to shrink it down by 95% or more.
    By
    I used to make my own models in SketchUp and export them as DAEs into Blender, then after tweaking whatever need to be tweaked in Blender, I'd export them a OBJs to DAZ or Poser...
    The "SketchUp export DAE, open in Blender and export as OBJ" is the most reliable way to assure a model works in DS.
    I've found a way better method that involves using Ultimate Unwrap 3D... that's a bit more complicated, but it yeilds better results.
    Many warehouse models are usually a mess with reversed faces, weird grouping, crazy scaling, models made way out of world zero, hidden geometry and other trashy mistakes that make most of them too much trouble to fix or use.
    I have a bit of knowledge about SU to DS import and I'd be happy to share whatever I can if you are interested.
    By
    I use a lot of SKP models from 3D Warehouse.  I open the SKP with Sketchup and then export them as Obj's to be used in Daz.  Seems nothing I do will make the imported obj show up.  As shown as I click accept nothing happens.  It use to be 90% success rate bringing in the model, but its down less than 1 in 20 making it through.
    Any Sketchup users here?
    By
    mechengineer97 mechengineer97 December 2020 in The Commons
  • Why do YOU use DS instead of something else?
    ...as mentioned in several replies here, initially it was the cost of entry and rather intuitive setup.  I also wasn't sure at the outset if I'd like this (particularly coming from a traditional art background), so plunking down 250$ (the price for Poser) or multiple hundreds/thousands for one of the pro grade programmes up front on a very limited income didn't seem like a sound idea (kind of like all those expensive exercise machines advertised on television that wind up in the attic or garage to become dust collectors after a few uses).
    Daz on the other hand was free, and was the full base programme, not a hamstrung demo that lasted only a limited time and/or you couldn't save what you did in it.  It came with a bundle of free content (the old 3D Bridge Pack which had the LE versions of Aiko 3 and a few animals as well as some props) and there were more freebies available not just on teh site here, but on others like Rendo, Content Paradise, and ShareCG.  This was enough to get a good feel for the software before actually putting down the zlotys for content in the store. Yeah there was also Blender (2.4) but at the time I found the UI was rather cumbersome (keyboard driven and coming from a lifetime of working with traditional art media it seemed rather counter intuitive).  To create a scene in Blender one also had to pretty much create everything in it from scratch, a fairly daunting process (I actually dabbled  a bit with CG in the 80s back when everything needed to be coded, debugged, and compiled).
    I also worked with the other programmes Daz offered (Bryce Carrara and Hexagon, the latter which was rather unstable at the time) as well as looked into Vue, Sketchup, Wings3D, and eventually bought Poser 6 (at a discount when 7 was in the wings) for its materials and cloth room. However Daz became my primary software, particularly as it began to grow. Yeah it isn't designed for creating large environments like Bryce and Carrara, but I learned to "fake it" back in the days before HDRs.  Granted it is very limited in modelling potential having only primitives, grouping and basic surfacing to work with, however the Polygon Editor makes kitbashing much easier.  With the Genesis concept and Iray, it evolved into something more powerful.  I could now design my own custom characters by mixing different figure morphs and shapes which was not possible beforehand.  As I find it to now be superb for character design, much of my content purchasing has gravitated towards merchant, morph, and shader resources along with plugins like GenX2 Skin Builder, LAMH, Garibaldi Express (now the built in Strand Hair Creator), and Ultimate Pose Master.
    In short, I have seen this quirky little programme I installed thirteen years ago has grown immensely. over the  years I've bene working with it (I still have the installer for ver. 1.8 as well as those for all subsequent updates).
    Since Blender reworked it's UI and set-up, I have finally adopted it primarily for modelling purposes as it is not only more powerful but very stable.  However,with the new Daz bridge, I am curious about exploring it for rendering as well since Cycles also has an out of core process like Octane (albeit being a path tracing rather than of PBR engine).
    So, I guess to address the original question, I've used Daz for along time, know my way around it pretty well, understand it's potentials and limitations (along with ways to get around the latter), have a hefty investment in it built over the years, it is not subscription based software (yet), and it basically does what I need for my illustration work.   As long as it doesn't change the minimum OS requirement to W10 I'm good (and even then I'll just stay with the whatever last version supports W7).  A Linux version would be nice but I also understand the can of worms that would open up (even some of the big software developers don't support it).
    By
    kyoto kid kyoto kid November 2020 in The Commons
  • Marvelous Designer - Survey
    I only have daz as a hobby. Limited time and financial demands force me to make choices. After learning DAZ for more than 2 years, I decided to get some modeling and texture software. During this week Black Friday, I'll probably buy Zbrush (or 3DCoat) and definitely Substance. This is learning for me for about next 3 years :) I have access to Sketchup. MD could be great, but I don't have the time or the money for the other software, especially so specialized. I had the opportunity to try it, for me definitely better than Blender / the connection between me and Blender will never work /. I will need to modify some dresses rather than create a brand new one and ZBrush or 3DCoat could handle that too.
    By
    Quadrifolium Quadrifolium November 2020 in The Commons
  • Dalek appreciation thread
    Only just seen this tread. Thought I’d put this up.
    This is a model I made in sketchup based on the famous 60s book cover. I exported it and rendered in daz Studio. Not sure I got the shape quite right probably a bit too tapered but for a first Dalek attempt I think it captures the spirit of it.
    Though very different from the actual TV Daleks I sort of like the look of it from a nostalgic point of view.
    nice work
    By
    bluto bluto November 2020 in The Commons
    By
    Artbyphil Artbyphil November 2020 in The Commons
  • (Halloween) Norman Bates house from the movie "Psycho"
    Did you tried blender?
    I have Blender but I really don't understand how it works. I am so used to Sketchup... I tryed it out a few times but it drives me crazy.
    Yes. It needs to do a few days YouTube viewing to get the ground. But it's worth. I for myself use it to remap texture zones and UV mapping (smart) of 3rd party 3d models.
    By
    Lothar Weber Lothar Weber October 2020 in Art Studio
    By
    Ralf1958 Ralf1958 October 2020 in Art Studio
    Does anyone of you guys know of a good tool for a complete UV remapping of a model created in Sketchup? I cannot find anything userfriendly and for a good price that allowes me to unwrap and reassign a clean UV-map. Sketchup is pretty (extremely) messy with that.
    By
  • Is there a method to zoom faster (farther)?
    I am working with some sketchup models and it takes forever to zoom in. Any help would be appreciated!
    Using a Space Mouse allows you to zoom, pan, etc. extremely fast in Daz, (Similiar to the controls in a first person video game). You will need to install the Space Mouse Software and adjust the settings, because the default are way too fast.
    I can't recommend Space Mouse.
    They are coated in a rubber material that dissolves to a gluey mess after a couple of years.
    It happened to mine, and many others going by complaints on the web. Apparently they are still using the same material regardless, so it will dissolve over a fairly short time.
    By
    elusiv_3763c6f5e0 elusiv_3763c6f5e0 October 2020 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
