• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • remove all light
    This question has probably been asked many times, I just don't know how to find it in the discussions. I would appreciate a tip on that too. Though my question is why when I am in filament view and I have no lights in a scene and HDRI set to "Scene Only" do I still see my object , when the screen should be black?
    Thanks
    By
    rfaraino rfaraino September 2025 in Daz Studio Discussion
  • Daz Studio 2026 Beta - version 6.25.2026.6423! (Updated March 09, 2026)
    Richard Haseltine said:
    Filament active will do that too. Adding a default camera would do the same, I think. But yes, I do not get the prompt for a truly empty scene.
    I forgot about Filament.
    Creating a Default Camera on New doesn't, not when I tried anyway.
    By
    DoctorJellybean DoctorJellybean September 2025 in Daz Studio Discussion
    DoctorJellybean said:
    a_gus said:
    This message is a general comment on the Daz software, whatever the version. But I'm taking advantage of the arrival of the new version to give some feedback on what could, in my humble opinion, make it run more smoothly:
    The first point is that a new, empty scene is created as soon as the application is opened. And when we open an existing scene from a file, and open the application in the process, an empty scene is systematically created and we're asked if we want to save it...
    The natural answer is "no", but before opening the existing scene, closing the empty scene takes an unnecessarily long time.
    Would it be possible for the application not to create an empty scene on opening, with, why not, a launcher of recent scenes instead?
    Another behavior that exasperates me is the fact that, in certain selection windows (for example, to select a constraint object), we have to select the element, then click on “OK”. It would be quicker to double-click on the element to select it, as you can only select one.
    Actually, a new scene is only created when the application is opened with the Iray viewport active. That creates an Environment Options Node and a Tonemapper Options Node, which constitutes a new scene. I think when it Loads a File on Launch, it also constitutes a new scene.
    By
    Richard Haseltine Richard Haseltine September 2025 in Daz Studio Discussion
  • Things I'm Playing with ........
    I've lost my muse ,been mostly trying to move things from Poser formats to DUF's and trying to figure out iRay shaders ,and how to get stuff to look right in Filament if they have transparences .......and having brain farts ,loseing focus ,and being very frustrated ......latest render didn't turn out the way I wanted it gotta figure out how to fix it .....
    Lumino wings  but they don't look right ,
    By
    carrie58 carrie58 August 2025 in Art Studio
  • The New Mac FAQ
    The current release is Daz Studio 4.24.0.3. I use it on my Mac and Window computers without issue. The Alpha DS 2025 is a work in progress and does give an Apple OS user the option to use Filament/FilaToon. But scripts/plugins are not available yet. I am using both on my Macs and shifting from one to the other as I need different processes.
    You can have all versions loaded at the same time if you isolate the 4.21 installers before downloading any updates. Put them into a folder separate and labeled what they are. I believe this is discussed above in this thread.
    By
    memcneil70 memcneil70 August 2025 in Technical Help (nuts n bolts)
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE QUATTORDICI
    Ciao ragazzi, mi è capitato un altro deterioramento di scena, diverso dai precedenti.
    Una scena piccola sulla quale non ho lavorato neanche così tanto, ho fatto 3-4 render, fino a ieri sera nessun problema, la riapro stamattina e la vedo così (foto 1).
    Se però attivo la Iray preview, l'immagine si forma comunque (foto 2), e idem se la visualizzo in "cartoon shaded". Solo in "filament" non si vede. Ho anche provato a salvare lo scenario (il corridoio insomma) come subset, senza personaggi o tonemapper/environment options, e aprirlo in una scena nuova vuota, ma si crea la stessa identica situazione.
    Dipende sempre dalla scheda video?
    C'è modo di salvare la scena o devo rifarla nuova?
    By
    vangelrise vangelrise August 2025 in The Commons
  • All Lights
    Distant Lights have diection but not location (they always shine from "outside" the scene). You are rotating the light node but the render/Iray Preview/Filament Drawstyle is not reflecting that? Are the lights set to point at something?
    By
    Richard Haseltine Richard Haseltine August 2025 in Daz Studio Discussion
  • No lights in preview.
    pauldb13 said:
    For me I can't can't get any preview lights at all even using Ctrl-L. The scene stays dark in perspective view making it impossible to work in. With Ctrl-L not working at all how can I solve this problem?
    I tried Ctrl-L several times and I still get this in every camera. It's too datk to work in even in perspective mode it's the same lighting, i.e. none.
    You're with Filament draw style for which a distant light is needed. You can switch to Texture shaded draw style by hitting Ctrl + 9.Then turn off Preview Light.
    By
    crosswind crosswind August 2025 in Daz Studio Discussion
    empartoo said:
    MIH_BAD said:
    vicster56 said:
    Hey all! After I updated this morning, DAZ Studio 2025 ALPHA - version 6.25.2025.21308 will not load. see Attached files. Thanks!
    Don't take it the wrong way, thanks for posting. I would use DAZ 4 if you don't have the 50xx series ...
    Just wait for public release ... there is no advantage at all (I think)
    Happy rendering heart
    I don't know this to be true. I have a 3060ti and there is a gigantic, extremely noticeable speed increase when using 2025aplha. What would take 2 hours to render in 4, take only 20-30 mins. The ui is way more responsive when in iRay preview, and I have yet to have an freezing issues, which are quite common in 4.
    @MIH_BAD I would also like to bring to your attention that for Mac OS users, the Alpha allows us to use Filament/FilaToon products. And I agree that my RTX 4090 Win11, enjoys a reduction is rendering time, along with my MacMini Pro M4. And the more users testing this Alpha, the more input the programmers are receiving to improve it. I do hope your experience improves.
    Mary
    By
    memcneil70 memcneil70 August 2025 in Daz Studio Discussion
    I think I just earned the award for the craziest behavior. The button that's supposed to assign the shader to a selected surface in Shader Mixer is instead creating a camera.
    I hope this means they're making extensive changes to Shader Mixer to improve its usability. And if that's the case, they might consider adding a shader builder for Filament, since the one for RenderMan no longer exists
    By
    almahiedra almahiedra August 2025 in Daz Studio Discussion
  • UltraScenery - new(er) territory [Commercial]
    Sorry, I kind of crashed out yesterday. Today is a bit of a bust too. I short-hand the proper name for Daz Studio 6.25.2025.22607 as DS6 or the Alpha. The last five numbers are the current version.
    Right now I only have the Alpha installed on my Windows 11, RTX 4090 and my MacMini Pro M4. I am not installing it on my Windows 10, GTX-1080Ti desktop and GTX-1080 laptop. It could be installed but will be depreciated over time, so I considered it not worth the space on my drive which is limited.
    What I have found is the DS6 renders really fast on the Mac. It also allows me to use Filament/FilaToon now. I am able to switch between DS 4.24 (Beta) and DS 6 (Alpha) in my workflow. Simply save a file and open it in the version of DS that I need. One thing I have learned the hard way is to save, and save often. When I am ready to render, close everything down on the Mac or Win 11, reboot, open the DS 6 and the file, verify all the settings are still there, add the file name, and hit render. Find something else to do for five minutes or so. Rather than the two to three hours I used to deal with on the Mac's Beta.
    Just watch out for really high vertices. They bite hard.
    While I am not as tech savvy as many here, I started with reading both threads for DS6 and have tried to keep up with them. Sometimes they do go WAY over my head. But at times I get answers before I have a problem. And I can also identify things at times too.
    Regarding USC2, I would start in DS4.24 and then open the scene in DS6. I just don't know if there is any interaction between the scene and plugin for a simple render. That is what I want to test.
    By
    memcneil70 memcneil70 August 2025 in Daz PA Commercial Products
  • Memory question
    The Alpha was released early because of the RTX 5000 series kept folks from using DS 4.24. It is the qt4 vs qt6 issue. So right now plugins and most scripts do not work in DS2025. But on my MacMini M4 the other day I was able to create a render of a character, outfit, hair, scene, and simulate it. I had to replace the hair as it had an unusual reaction to dForce. The new hair was close to 6 million vertices and it crashed. I had saved thankfully prior to that. Rebooted and reopened and loaded the hair again. I also used PowerPose. Rendered okay. Apple computers have access to Filament/FilaToon now as well. But if I want to use many of the scripts I rely on, I save my scene file and reopen them in the Beta, DS 4.24.
    One thing I have found out is many of my renders run faster on DS2025 than on DS 4.24.
    But if you want more technical details:
    Daz Studio 2025 (6.25.2025.x) - NVIDIA Iray 2024 - Daz 3D Forums
    Daz Studio 2025 ALPHA - version 6.25.2025.22607! (Updated August 14, 2025) - Daz 3D Forums
    By
    memcneil70 memcneil70 August 2025 in The Commons
    jbrettl said:
    jbrettl said:
    jbrettl said:
    Currently the log this time is stopped at
    2025-08-16 17:23:43.331 [INFO] :: Begin asset load (open): /Props/SY Whips And Lashes Genesis 3 and Genesis 8/Props/SYWAL Short Whip.duf
    and it has been over 40 minutes
    I'm pretty sure it is hung :)
    I have uninstalled Daz Alpha through DIM and removed the directory and registry remnants, re-installed.  I did not remove %appdata% pieces
    I have two 5090's.  Through devmgmt.msc disabled one, didn't help, disabled both, didn't help (I really don't want to pull the beast out again and pull cables :) )
    I have tested both 5090's successfully independently with a scene that will load
    Thanks
    That does sound pretty extreme, but not terribly informative. Does Task Manager show activity (e.g. CPU activity or RAM increasing) for DS? Does a different Viewport Drawstyle help?
    I'll try whatever you want.  The rest of the system was responding fine so It isn't like Daz was running away with anything.  But good idea, I'll check to see if memory increases that will indicate some processing.  I'm not sure how the viewport comes into play. It does default to filament and I left it there.  I'll try with texture
    Yeah, weird, it is just not doing anything memory wise.  It actually went down to xxx,608 now, but not fluctuating
    CPU fluctuates but around 6.x%
    Obviously the best thing is to have other people obvserve the same behavior.  I don't know if you have that product to test, but if others do, maybe it is just me.
    Can I post to ask people with the product to test (tee hee, already done)? and if I link to the product would that be considereded advertising for the product, and is that ok in this thread?
    I have seen the same behavior with a figure I had stored in previous versions.  It has a lot of custom morphs, but I have narrowed it down to being connected to the Nagaleon tail.  I have a re-rigged version of that I use, which has around twice the bones as the original version.  I notice the original version loads slowly (>1 minute load time), and my re-rigged one doesn't load in 2 hours.  I may leave it overnight tonight to see if it loads at all.
    I also saw it lock up after the texture message, using around 1 CPU worth of load, so it seems to be spinning a single thread.  I think the texture thing might be a red herring: I loaded the figure with all textures removed (just a plain white iRay surface) and got the same behavior.  Not convinced that final log message is actually meaningful.  I am somewhat suspicious of the depth of the chain of bones causing some weird issue, but it really is just a guess.
    By
    gilrandree gilrandree August 2025 in Daz Studio Discussion
    Thanks
    By
    jbrettl jbrettl August 2025 in Daz Studio Discussion
    Thanks
    By
    Thanks
    By
  • Need help with rendering
    Do you mean you don't use Iray to render, or just not using the Viewport Iray preview?
    Is the issue with filament due to computer performance?
    If so, there's not much to be done about it.
    Texture shaded doesn't have any of those options what so ever.
    By
    DrunkMonkeyProductions DrunkMonkeyProductions August 2025 in Daz Studio Discussion
    Hi, I need some help, due my potato PC, I can't use Iray, so I use Filament or Texture shaded, and each one have one problem, in Filament, I can only use 1 light, so I can't do a light dome, and in Texture shaded, I need to change the color saturation, contrast or vibrancy, but I can't find how to do it like in Filament, any help please
    By
    kennyrodriguezu kennyrodriguezu August 2025 in Daz Studio Discussion
    I have a MacMini Pro M4 and I found that a scene file that had over 6.6 million vertices took 5 minutes 54 seconds when rendered in DS 6. I had built the file in DS 4.24 and had some slow responses because of the hair, so decided to try DS 6. It came through like a champ. Another character render took less than that.
    And this is on top of being able to use Filament/FilaToon!
    But as noted in Evergreen, scripts and plugins are not working in the Alpha. So use 4.24 for that and reopen in the Alpha.
    By
  • Can you render out an IRAY Viewport-preview to a file?
    DrunkMonkeyProductions said:
    WendyLuvsCatz said:
    just pick viewport instead of iray or 3Delight in the dropdown in the render tab
    Unless i'm doing something wrong, that just results in an opengl render, not iray, even if the viewport is set to iray preview when you press the render button.
    oh, I wrongly assumed it would as it works for Filament, wireframe etc, know 3Delight won't, you can use interactive render with lower settings and save a similar style
    By
    WendyLuvsCatz WendyLuvsCatz August 2025 in Technical Help (nuts n bolts)
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
