• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Berlin Neoclassical Architecture
    richardandtracy said:
    OK. It's a start...
    The decorative swags are going to be a problem. May have to try them with normal maps.
    Regards,
    Richard
    I'm quite aware, that this would not be a quick project.
    Here are some shots of typical Berlin windows to those houses.
    https://www.google.com/search?tbnid=oPv4ExmQRJcE7M&tbnh=0&tbnw=0&client=firefox-b-d&hs=Hl99&sca_esv=ad51375bc05ed99f&cs=1&sxsrf=ANbL-n6WxdnpEZ7q76VzK3J7_AZij6AgaQ:1773067143805&udm=2&tbs=rimg:CaD7-BMZkESXYWVxhE9DsDhM4AIA&q=Berliner+Fenster&sa=X&ved=2ahUKEwjuipDqhZOTAxWUNPsDHZxFNxQQuIIBegQIOBAA&biw=2159&bih=1271&dpr=1
    What software are you using in your screenshot?
    Is it Sketchup?
    I looked into it, but it's rentware.
    By
    Masterstroke Masterstroke March 9 in Product Suggestions
  • OBJ Imports related question
    Most of them are grouped for better handling and organizational purposes. Sometimes, not grouping objects in SketchUp leads to messing up the geometry and whatnot. However, I've tried exploding some groups and leaving the objects as they are, but doesn't seem to be helpful.
    I've saved a version with no groups at all, just objects and oh boy.. not only that the file has no separate items in DS, but texture got lost and the project got white again :)).
    By
    da_kovacs da_kovacs February 17 in New Users
    And they are separate objects, not just separate groups, in SketchUp?
    By
    Richard Haseltine Richard Haseltine February 17 in New Users
    The thing is that even though it is said that DS can import separate items, for me this is not happening. As shown in the attachment, I have all settings checked. Is this option app specific maybe? I mean, I'm sure it works with Blender just fine, but as advised, I'm using SketchUp and with that, it doesn't work for sure.
    By
    Well, I'm completely lost now. I've tried it with a completely new object with a simple texture and the same happens. The model is white... I thought of the MTL file as well, meaning that the pathfiles are either corrupted or something is missing, but creating a new model should've excluded this. I'm not sure what to do..it was working well before the update..
    Regarding grouping, it seems that SketchUp OBJ's don't separate objects, but exporting as 3DS do. I'll go with that instead.
    By
    da_kovacs da_kovacs February 12 in New Users
    I've found no issue with both DS 2025 Alpha and 2026 Alpha when importing OBJ + MTL files. Diffuse texture maps are shown correctly in Viewport... There should be no change in OBJ Importer of DS 2026.... not sure why DS 2026 failed you.
    As for grouping, starting from DS 2025 Alpha, OBJ Importer gives a new option of Read Objects, which can read OBJ file that contains Separate Objects. It now works well with my Blender workflow i.e. I save multiple items as an OBJ file with exporting materials in Blender, then DS 2025/2026 can import the OBJ file as multiple objects with assigned texture maps + correct surface names, so far so good ~
    But I know nothing about SketchUp... not sure if it can save an OBJ file with data of separate objects ...
    By
    crosswind crosswind February 12 in New Users
    Hello!
    I'm in need of a little help here to understand better file importing and how to work with OBJ's correctly in DS. The host tool I'm building a scene is SketchUp and I'm exporting the model as OBJ with the settings shown in the attachment.
    Everything was working perfectly until I've updated DS 25 Alpha to DS 26 Alpha and now all my imports are looking white. It's like DS doesn't load the textures or something. Environment and other settings are unchanged and working with DS models works just fine. It only started affecting OBJ's.
    Also, does anyone know if there's anywhere an option in DS to display an OBJ with its original grouping/tag settings? I mean, currently an imported OBJ only comes with its name and that's it. Everything is grouped together and can't work with its components like a table or a picture at all. The only way I can see the model's details is under "Surfaces", but that's not exatly what I'm looking for..
    I don't know if any of this makes any sense, but it would be awesome if someone could help in any way.
    Thanks!
    By
  • Hexagon open source
    Interesting thought and thread.
    Loved Hexagon and found it simple to learn. Prior to Hexagon I tried Sketchup which I found very awkward to use and created awfull topology. Later switched to Wings3D which I also found easy to learn. Wings3D lacked some tools which Hexagon had, so I jumped ship. I only stopped using Hexagon in favor of Silo as on later Windows versions, Hex was unstable to use.
    Silo was also easy to learn yet lacked some of the tools of Hexagon.
    I now use Blender, MOI3D and 3DCoat.
    Vanilla Blender  lacks some of the cool tools Hex has but there is a rich library of add-ons for Blender which can remedy this situation
    Blender does have a better subdivision workflow which I did not find stable in Hexagon.
    Groboto3D was fun but no longer being developed.
    I would welcome further development of Hexagon3D for stability issues.
    By
    kenmo kenmo December 2025 in Hexagon Discussion
  • DAZ3D to Vue Plugin
    There was a Poser to Vue and Sketchup to Vue plugins when E-onsoftware was publishing Vue.
    I can not remember if the Poser plugin was developed by E-onsoftware of Poser.
    The Sketchup plugin (actually a script) was developed by a Vue fan/creator and sold on the old Cornucopia3D site.
    There was a post on "Vue Galleries" on Facebook which seems to back your thought Vue may become "opensource" via Bentley (present owners of Vue).
    Love Daz but lately it has been giving me issues with large scenes. I use Blender and Vue but I am more comfortable with Vue.
    Plus I would have to purchase several Blender-addons to give me some of the features of Vue, especially plants and ecosystems. And Vue's material functions are so much easier than Blenders.
    By
    kenmo kenmo December 2025 in Product Suggestions
    You’re absolutely right, “more efficient” really depends on what you’re most familiar with. Many architects naturally choose tools like Rhino, SketchUp or 3ds Max because they’re well-established in that field and fit architectural workflows very well.
    For me personally, Hexagon has always been more of a hobby tool. I just enjoy that old-school vibe, and it’s also a bit nostalgic since my father and I used to experiment with Hexagon together for fun. In that sense, it’s less of a pure modeling tool for me and more of something I feel emotionally attached to. I use Blender too, of course, but Hexagon still feels a bit like home.
    That’s why I appreciate having so many different programs to choose from: everyone can work with whatever feels most intuitive, whether it’s cutting-edge or pleasantly old-school.
    In the end, the result is what truly matters, because all these tools are simply there to help us express our creativity. I always say that you can create a beautiful sketch with a simple pencil just as well as with a Montblanc.
    By
    Nova Nova November 2025 in Hexagon Discussion
    "More efficient and much faster" is relative to the application you know better.  Someone who worked in Blender and switched to Hexagon would most likely say the same about Blender over Hexagon, especially when it comes to applying the tools in question.  If you know Blender well, the hotkeys and quick access to the tools make it very fast for modeling.  I used to think 3dsmax was so much more efficient than Blender when I first switched, but then once I really learned the tools and hotkeys in Blender, it became evident that it was at least as fast as Max was.
    I agree, though that there aren't many people using Blender for architecture.  There might be even less (aside from you, of course) using Hexagon for such things.  I think polygon-based modeling packages in general are really only used for visualization in that field.  Correct me if I'm wrong, but I think Rhino, SketchUp, and some other solid modeling packages are far more popular in Arch Viz.  3dsmax might be the only exception.
    By
    gregsgraphics_cafd0962a0 gregsgraphics_cafd0962a0 November 2025 in Hexagon Discussion
  • Can you help me with a college project?
    Oooh... Questions!
    1-  How long have you used Daz 3D Studio?
    A:  Approximately 17.675 Earth years. This is without accounting for temporal variations due to chronometric phase variance or progressive orbital oscillation within the galactic plane. Probably.
    2-  Do you use any other software with Daz 3D? (bridges, photo editing, or other rendering software?
    A: Yes... Blender, SketchUp, Hexagon, Poser, Bryce, Nomad Sculpt*, Valance3D*, Sculptura*, MeshMixer, Photoshop, GIMP, Krita, Inkscape, Procreate*, Pixelmator*, Sketchbook*, UltimateUnwrap, Filter Forge, Kerkythea, ... That's most of them, not counting ones I have that I very rarely use for a specific purpose
    3- How easy or difficult was it to learn Daz Studio?
    A: I learned it a long time ago and I have a terrible memory... I think it was semi-decently-easyish to learn... I actually learned Poser first (via books and magazines), but with DS there were lots of wonderful helpful people here on the forums that shared their knowledge and wisdom when I asked questions.
    4- Did you have to purchase a specific computer to use the application?
    A: No, but over the years I've tried to buy a computer that is at least a little good at rendering... honestly they've mostly been mid-range computers... no expensive graphics cards or high end graphics capabilities.
    5- How much money have you spent at the marketplace or other third-party sites for content?
    A: That's classified information. Also I have no idea.
    6- What kinds of bugs or errors have you ran into?
    A: Mostly spiders, but they are arachnids... errors... lots over the years... the main issue I feel is that by the time I catch up to everyone else computer-wise, DS has gotten more complicated and I'm always rendering at the same speed... but the plus is most of the bugs that I've encountered are easy to deal with because they are old news by then.
    7- Is there anything you would change about the application?
    A: Quite a few things, but I gave up long ago on hoping for things I'd like to see implemented... I used to have a list somewhere (for surveys and stuff), but none of that every came to be (they weren't weird things, lots of other people wanted them too)... one of the things I'd love to see is a decent manual... I feel like once upon a time the community would have really come together to help make a good user manual, but I feel like that ship may have sailed over the past few years. It seems like most people are happy with random YouTube tutorials and paying for video courses (I'm not a fan of videos for lots of reasons).
    Disclaimer:  ​DS used to be a big deal to me, but for various reasons I'm only faintly interested it these days.
    By
    McGyver McGyver September 2025 in The Commons
  • Exterior of West Park and the grounds
    I grew up at Belmont in Surrey, now classed as being in Greater London. My dad worked as a steam boiler stoker in the Belmont/Henderson hospital which was one of the many old gothic psychiatric hospitals in Surrey and had been a former workhouse in Victorian times. From our house we had almost exactly this view of the Belmont Hospital:
      Belmont Hospital, Sutton: Former Workhouse and Pauper School. Art Prints,  Posters & Puzzles from Mary Evans
    A mile or two away near the village of Banstead was the Banstead psychiatric hospital which looked like this:
    undefined
    Then there was the Epsom cluster of psychiatric establishments which included the West Park one. There are more pictures and links from the Wikipedia pages for each of these hospitals.
    A good way to find outsides for the Jack Tomalin West Park is by searching for "psychiatric hospital" on the Trimble/sketchup warehouse. Then edit the downloaded buildings in Sketchup. Also, if you have Carrara, there's a freeware plugin by Inagoni called Architools which can make buildings in Carrara and export them. Downloadable for free from github. https://github.com/Chaplier/inagoni/releases/tag/v1.0?fbclid=IwAR3lM3yptVqAqC6-z4AISXXDEboBuyb0Ipr54jOZbzzdFn44PQlPlegqgEk
    Another way is to cheat. One time I used parts of the Dream Home, splattered it with grunge and pretended it was the outside of West Park. I put Grovebrook House in the background.  It looks close enough if you're only driving in the gateway and then entering the front lobby.
    By
    Speculativism Speculativism July 2025 in Product Suggestions
  • Show Us Your Bryce Renders Part 13
    The terrain was self made and given a material from Gritstone Hills and High Resolution Terrains 2. The castle is the Château de Chambord from SketchUp and the lake a 2D-Disk with my water material. The clouds from the CloudSphere1 and the ambient light by the belonging SkySC1 HDRI from the Sky Toolbox and the key light by the sun.
    Castle near Lake
    By
    Horo Horo April 2025 in Bryce Discussion
  • Star Wars Renders 2013 +
    tkdrobert said:
    Rogue7 said:
    Awesome pics tkdrobert where did you find the ship?
    Sketchup.
    Great job
    By
    Rogue7 Rogue7 March 2025 in The Commons
    Sketchup.
    By
    tkdrobert tkdrobert March 2025 in The Commons
  • Help with creating clothes, a house and other stuff
    this might suit you then too
    https://www.sweethome3d.com/
    I haven't used it but for houses it's popular
    are tutorials on Youtube
    https://youtube.com/playlist?list=PLtu3HarR0EUZwMcTm1JzTmo4yCfNuUtCg&si=tVUFcF7QxWmkjz_U
    looking it's as easy as Sketchup or Architools in Carrara yes
    By
    WendyLuvsCatz WendyLuvsCatz March 2025 in New Users
    well I started in 2009 using Google Sketchup which was free with no computer experience whatsoever let alone 3D modeling
    sadly Trimble bought it and it's ridiculously expensive now
    I moved from there to Carrara, back then using iClone and  Poser
    clothing wasn't something I really did, just props but now that's fairly easy too in D|S4 with Genesis# figures and Dforce, you can literally even drape simple shapes and have them look good
    By
  • Closets, drawers and vanity mirror
    I made a closet set with drawers and a vanity mirror in Sketchup, imported into Daz as FBX.  I replaced bulbs around the mirror with a single LED strip to be a little more modern (modify the emissive on the mirror object to change the lighting).  The individual drawers can be "opened" by selecting a drawer and changing the Z coordinate.  The cupboard doors can be opened and closed by using the rotator nulls for each door (rotating on Y).  Drawers are instances, so modifying the parent instance materials will modify all of them.  The closets are duplicates, to enable the null rotation for opening them (the simplest of rigging).  The materials themselves are basic Daz Uber variations.
    Zip is a Scene Subset, so just unzip, copy/paste into library somewhere and merge into a scene.   Note, the padded blocks sofas in the scene render are another of my freebies, here.
    Vanity Mirror example scene
    Vanity Mirror, Drawers and Closets
    By
    Pickle Renderer Pickle Renderer December 2024 in Freebies
  • Converting matching objects to instances?
    Anything happen with this?  My idea is you select the first item, then select a bunch of other items and it replaces the other items with instances of the first, retaining the position and orientation of the other item.  That would be easier than trying to do a match on all properties.
    e.g. use case right now I imported a wardrobe with about 20 drawers I made in Sketchup - each drawer has a handle.  I imported fbx so I basically got one mesh per drawer.  The drawers are identical (except position).  It would be nice to select them all and "convert to instances", or something.
    By
    Pickle Renderer Pickle Renderer December 2024 in Daz Studio Discussion
Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
