My Renders, Now I can go to bed
1246717
  • XaatXuunXaatXuun Posts: 871
    just a couple more Renders of Hye
    I was going for Half Korean when I dialed her in
    Hye 5'4"
    1000 x 1041 - 159K
    1000 x 1041 - 141K
    for fun , trying to recreate someones character in a game, still a WiP, only have the neck up done, without a selection of clothes or hair, it's more of an approximate
    1100 x 1146 - 345K
    edited November 2014
    trying something new, not using any paid dials or anything paid tried to go totally free.
    had to use the paid hair, well didn't have too, it just seemed to looked best with what I dialed in
    it was just with quickie with lighting for a render, something I have saved that I really have to add more lights to, it just a starter thing I have made
    so this is what I came up with
    Calanthe
    1100 x 1149 - 385K
    Post edited by XaatXuun on
    okay use some of my paid dials
    so here be Calanthe P
    1000 x 1006 - 267K
    1000 x 1006 - 263K
    did another all free model, only things not free was hair,eyes ( I need to have good eyes to be satisfy)
    DieTrying's 182 V4 Morphs for Genesis
    and
    Tween Morphs for Genesis
    starting with
    Elka for Genesis
    all can be found at ShareCG
    and here is Waleria
    900 x 901 - 312K
    Another one of Waleria
    the lighting here, I'm still working on
    the first post above I not yet adjust her height, this one it has
    EDIT: opps, I see I forgot to give Waleria any expression
    the pose I forgot where I picked it up from, just some minor adjustments, then saved to use later
    1000 x 1037 - 480K
    had enough pennies, with the help of the 85% off I picked up Young Teens 5 Julie and Justin
    used the Julie dials on Toni
    and now have Toni 3
    1000 x 1014 - 426K
    edited December 2014
    too bad I'm stuck using the machine I have . . would really like to add more props for a better scene, and not just single pose and lights (and limited to how many and which type of lighting)
    found some more freebie's to download, did some mixing of most of them in this image with a new model, Seija
    gonna try something in GIMP, this is one render that should have post work, something I still have yet to learn
    I had another idea for a pose and prop, . . . other then the jedi way, . . . just need to find me a shield, and do another render of what I was really going for
    oh and below is a little reworking of Hye
    1000 x 994 - 206K
    1000 x 1019 - 172K
    bit sloppy, something I did to pass the last hour
    here is a unfinished Nemo in other words WiP
    going for some warrior type
    1121 x 745 - 206K
    dialed Libby a few weeks ago . . just now getting to rendering her
    950 x 955 - 465K
    another Libby
    seems she has Cataracts, I'm think it may be with something with my render settings causing it
    I wanna see if I can figure it out on my own first, had this happen before , and I forgot what I did to fix it
    1200 x 1198 - 168K
    never did finish figuring what I did wrong with Libby's eyes
    rather then get stuck and possible frustrating situation, I dialed in Sheona
    forgive the lighting mistake with the shadow , I was going to use a different set of light, but knowing that the render takes too long when the lights I want ed to use, and being very tired at the time , I decided to just use another set that just doesn't take long to render, also was too lazy to correct it.
    was more a test render any ways
    1100 x 1155 - 541K
    did some rework on Cin
    this is were you'll see the before image http://www.daz3d.com/forums/discussion/2100/P15/#337207
    here is Cin 2
    1100 x 1094 - 314K
    new one
    made some adjustments after this render, just need comp for something else then I'll do a render again
    Thalia
    1000 x 1019 - 638K
    another one of Sheona
    it's not exactly;y the render I wanted to do, just couldn't find a image I was searching for, but this one worked as a background.
    it kinda gave me what I was going for
    1000 x 1019 - 449K
    dial in me a new model
    Luna
    1100 x 1345 - 545K
    just playing with Genisis2
    Not much I can do in the dial department, have picked up a freebie, mainly that's all I used
    1000 x 1017 - 107K
    was sweating it on this render, getting close to the moment of crash. really need to add some shaders to the mini gun, and many other adjustments, but I wanted to get the first render of Taimi
    having a bad insomnia day, so created this scene, body is jelly, but me brain won't slow down, can't get to sleep
    900 x 907 - 520K
  • starionwolfstarionwolf Posts: 3,667
    cool render. For a second I thought she was holding a leaf blower machine. lol. Nice lighting
    edited March 2015
    thank you
    I don't recall where I downloaded it from, I think it was a special freebie,or is a freebie, or it was part of something I bought, but the lighting came from 'FWSA Stacia for Victoria 6'
    bit loopy from no sleep forgive me for not searching the link,
    I suspected the mini gun needed some shaders, and it shows that they're needed after I did the render,
    still had not been through all my models since the paid new dials, from a while back. .
    Remember Agnes http://www.daz3d.com/forums/discussion/2100/P30/#434443
    here is the new Agnes v2.0 :D
    1000 x 1008 - 482K
    edited March 2015
    did this real quick, made an adjustment to one of the lights ( a preset I created) and try to recreate the scene like in the first Agnes, Obvious different skin mat and lighting, and of course the new dials, speaking of which, with the new lighting, I see I need to play with those dials some more, somethings I didn't notice till after the render
    1000 x 1008 - 344K
    still making adjustments, another slight change to the lighting, Skin MAT, itsy bit on body
    Still see more needs to be done till I'll be happy
    Every get that gut feeling that something not good is about to happen
    1000 x 1008 - 339K
    edited March 2015
    a little something I've been trying to recreate, need to work on them dials some more, might have to create a deform or 2 to do it, but see what I can do with the dials first.
    this is one of my characters I play , a screen shot I'm working from (link would work, so posting the image here
    don't really have any male clothing to go with what I'm doing nor the beard, so may be unfinished till I can find these things.
    here is how far I have gotten so far
    882 x 649 - 57K
    1100 x 826 - 502K
    okay this guy was dialed just to get some skins for Genesis Male saved, for me to use
    the one on the right is a freebie M4 Tan, on the left was after some adjustments to it. Unfortunately no matter what I do to the face, it just won't change.
    any ideas what I need to do to get it adjusted better to match the rest ?
    I still see I need to work on it some more, but that face I wanted to get fixed somehow
    1100 x 1098 - 331K
    today's creation
    Faustina
    felt safer using FWArt Lights from the Stacia
    pretty much used Shaders on all the materials. mixed some bump and opacity maps, to give more texture
    1000 x 998 - 458K
    and another new girl
    Kitti
    having a tough time putting together a scene , and it's getting late, I tested her with some of my lights, and just wasn't what I was looking for, ended up changing her clothes .. ended with Hongyu's CowGirl4. Spent hours going through my library, for something to use, but like I said it's getting late, so tonight I ended with this, I have some ideas for later, so you'll be seeing Kitti again
    1200 x 1303 - 169K
    ok ok . .couldn't fall asleep right away, kept thinking what I wanted to do, so played a little with the Chopper, using what shaders I had on the whole thing. I think I'll keep toying with the frame, Tank, and Fender colors
    still need to find more to add, and not crash
    here is another of Kitti
    1100 x 1098 - 325K
    struggling getting a whole scene with Kitti and her toys , too many shaders for this poor old machine, needed a break.
    so dialed another new Genesis model,Neilina as early 20's and early teen. I'll add the early teen version later, I haven't decided totally yet on which hair for Neilina for now it's Longhair_EVO_V3, I did change the Diffuse color.
    top is the Half T-shirt from OpiTex
    pants are from Hongyu’s CowGirl4
    for the top and Pants I used Wilmap's Assorted Textures, and Lace Design
    Fast Metals shaders for the buttons
    Lights from FWArt Stacia (Character lights)
    Pose was a mix from AS-Team Pose01 (Aery Soul) with some minor adjustment and a slight hand pose change
    1200 x 1196 - 601K
    okay, I really need to find more clothes, this took me longer just trying to find something for a early teen
    this is Neilina early Teen
    1200 x 1196 - 647K
