My Renders, Now I can go to bed
XaatXuunXaatXuun Posts: 879
edited January 2016 in Art Studio
KInda decided to keep the title close to the same as before
took a break from my pouting, here is what I did today
one in default, second in Cartoon shader, and last 2 playing with Gimp
778 x 778 - 107K
778 x 778 - 301K
778 x 778 - 341K
778 x 778 - 316K
Post edited by XaatXuun on
«13456717
  • starionwolfstarionwolf Posts: 3,670
    Nice renders. Thanks for uploading. The second to last render looks pretty. The scene looks like you took a photo of the model in a sunset.
  • XaatXuunXaatXuun Posts: 879
    edited August 2012
    I didn't get to finish with post work original from Render then some postwork , kept messing it up so ended up with a old photo look
    ETA: it's the last image that is original render with no PW
    779 x 778 - 386K
    779 x 778 - 280K
    779 x 778 - 379K
  • kylumikylumi Posts: 305
    I like your concept....I think if you can add some light at low intensity with the addition of shadow you would get the impression of more depth to your artwork.
    Keep up the good work my friend.:coolsmile:
    thank you
    I was trying to get that trough postwork, but was not getting any the results I was looking for, in time, I'm still learning it.
    Don't worry my friend......we are all learning something every day. That's what makes this hobby so much fun. :coolsmile:
    Been a while that I even opened up DAZ , so last night I was creating a Character I play on a Online game 'The Secret World'
    I need to find the textures for the pistols .. I was too sleepy to find where the folder they re in , so did the render while I rest
    It's still WIP
    No Post work started . . . Yet
    1000 x 998 - 736K
    edited April 2013
    yet again , it's been a while. My HDD died on me a few months back, having to re-download and re-install
    did this while taking a break from downloading and installing and playing online games
    618 x 800 - 90K
    618 x 800 - 81K
    618 x 800 - 53K
    edited April 2013
    need to figure what to do about those Eyeballs, not sure I'll get back to this soon, need to do something about those Eyeballs,
    way past my sleep time, no Post work, not till I figure those eyeballs out, probably ruin it .. I'm just bad at post work
    ETA: okay did toy with it quick like in GIMP, so going to add that here
    1000 x 1294 - 199K
    1000 x 1294 - 351K
    something I whipped up tonight, cheated and used the Uber lighting and not my own . . should have done a spot render , then would had noticed it was too bright on the left hand
    I have some more ideas what to add, so might not be finished yet
    1000 x 1294 - 251K
    think I'll try a different skin for the female, was doing just that then crashed, so posting what I have do so far, and try again later
    1000 x 1294 - 369K
  • bighbigh Posts: 8,147
    like the work you did on this .
    getting closer, spending more time restoring after crashes then it takes to render this
    I think I might have the lighting corrected, but got a error, while making some minor adjustments
    For now this is what/where I'm at. maybe later I'll get a render of what I want
    1000 x 1294 - 315K
    edited May 2013
    Thank you . . it did keep me awake longer then I needed to be
    was getting nervous, just as I was able to get the lighting on this one, it crashed . . well now you know what the others were pointing and on guard about . . I'll get to that one, I really want to get it almost finished . . not sure if my machine could handle adding a scene , but I'll give it a shot, maybe I can get lucky
    1000 x 1294 - 268K
    I see many things need adjusted now . . I was holding my breath the whole time of this render . . was scary, with the many other times it had crashed at 80%.
    still some more tweaking on the lights too.
    have to say I'm happy with the results so far .. not reached that totally happy part yet
    1000 x 1294 - 407K
    have most of what I want downloaded again, so went venturing to what has become available since I last looked, and saw the SOTO flat top . had to get it and whip something up quick so I could use it
    1000 x 1089 - 526K
    Found some more freebies , needed a new model . so I dialed in "Cin"
    I'm not happy with the lighting yet, just had to stop and take a break
    1000 x 1089 - 438K
    played with Cin a lil more, trying different skins
    1100 x 1198 - 577K
    1000 x 1089 - 516K
    no name yet, just some gurl for now
    1100 x 1198 - 244K
    1100 x 1198 - 164K
    1100 x 1198 - 295K
    I decided to do a larger render, sure can see more imperfections when the image is larger
    1200 x 1400 - 448K
    Something I did the other day, just now remembering to post it
    Sharah
    1200 x 1400 - 517K
    something I did today
    Myra
    3 different skins, 2 different hairs
    first one was some weird thing happening, I was trying out the uberEnvironment 2
    1100 x 1175 - 614K
    1100 x 1175 - 623K
    1100 x 1175 - 629K
    1100 x 1175 - 682K
    Melanie
    I did smudge out the nipples, that were poking through, only Post work
    Yeah, I'm still learning the uberlights
    1000 x 1294 - 711K
    something
    1100 x 1282 - 685K
    edited July 2013
    had no connection to the WWW, so had time to get some renders.
    well, been playing with the UberEnvironment lighting , but cannot render what I want to, due to old machine. keeps crashing, this is one that did not crash on me, and still needs better settings
    Stacy
    1100 x 1282 - 762K
    Judy
    skin color didn't come out like it normally does, will need to adjust that
    1100 x 1282 - 884K
    edited July 2013
    yay . .:-) I happy because I be getting the settings closer to getting the renders I want, and not crash . . still need render dials adjusted, least now I'm closer and can fine tune it
    Darby
    only have her Head done, it's still WiP for the body
    1000 x 1089 - 400K
    Tracy Teen
    Still WiP
    1000 x 1089 - 487K
    down loaded this glass shader a few days back forgot about it, installed now, and did a quick render to see how it turns out
    came out great, I didn't do anything but selected the shader.
    I'm sure some adjustments would produce better results
    found the shader in the free forums http://www.daz3d.com/forums/discussion/26564/
    1000 x 1165 - 452K
    opps . . really want to show this, but with better lighting .. too dark .. so here's a WIP
    I have another of these 2, but they are nude, lighting in there also dark but looks cool, I will not post that one
    1000 x 1165 - 238K
