Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Two quick questions about lighting if you don't mind:
* I added a Photometric Spotlight to a simple scene and it appears to cast almost no light at all with the default values. Even at 200% Intensity, the illumination is barely visible.
* Of the four Environment Modes, do any offer the option of Scene lights -and- Sun/Sky?
Thanks in advance.
Can you send a render and screenshot of the scene?
There is not one for Sun-Sky and lights. This is a photoreal render engine and that combo really isn't needed when you use the sun. You'll need windows if it is an interior. :) Just like real world. Then you can add emitters etc from there. Adn outside renders will just use sun ....turn on a flashlight outside during the day and it doesn't shine very well :)
Give me a better idea of the scene, and I can help more. :)
Kat
Ah, so all interior light needs to be done with either emitters or Photometric spot lights? Got it. :)
Pic attached, default Photometric Spotlight not too far from the central objects.
Thank you awesomely for the info I wondered where the emitter switch was hiding.. :)
One last thing where is the Shader Pane > Emitter as can't find it to change the luminance.. :(
thanks. I was about to ask the same question. I thought I could load an existing scene with distant lights and render the scene in Iray.
Here's a screenshot for you. :)
Kat
@SnowSultan - Shot you a PM. :)
Kat
What's the difference between a photometric spotlight and a regular one?
Kat
Cool thank you for the info and pic, another one of those sneaky hiding settings.. :) lol
But have come across another strange issue with the emitter setting as this pic shows the dome of the light I have set as the emitter but the side facing the camera is dark when it should be light.. Not sure why probably missing something just not sure what as never came across this with using Reality / Luxrender..
Any help please would be greatly appreciated thank you.. :)
The photometric spot and point lights are new and meant to be used in Iray in place of the one's you are used to using. :) They work the same way, just different coding.
Kat
Aside from one is for use in Iray and one in 3Delight, the PM lights have parameters based on real lights - temperature and luminance - and have fall-off since they are "real", which the default DS spots have always lacked. You can also chaneg the shape of the PM spots, so you can get a more diffuse beam of light with softer edges that wrap around lit objects.
Kat
Which lamp is that? I'll load it up and see what settings need to be on what surface. :)
Kat
Kat
The lamp is part of the Classic Deco Product http://www.daz3d.com/classic-deco .. :D
I assume Iray won't work with AoA's atmospheric camera. Are there any ways to do godrays with Iray?
Your Iray with AoA question got answered when you posted it in the Iray render thread, in case you missed that. :)
They are shader based lights and will not work in Iray. You can still use them in 3Delight.
You will have to postwork godrays as Iray isn't using a cloud/atmospheric system. :)
Kat
Kat
I have the whole dome lighting here. Steps:
Load lamp
Apply emission shader to lamp dome
Create camera and switch to that camera
Turn off headlamp on camera parameters
Turn up Luminance value
Render
Kat
Just wanted to add in that you can also use IES profiles on the PM lights.
You can use them on the Surrfaces set to Emit as well. :)
Kat
Should plug ins like Look at my Hair work with Iray yet?
(I'm not sure if I'm missing a step or that, duh, it's beta)
I'm going to say no, because they are built on a Renderman/3Delight specific curve scheme...it's not that they can't translate to other types of curves (other than RiCurves), it's just that they don't. Other wise it would be easy to get them into Luxrender or Blender, too.
You do have the option of creating a geometry hair from the curve based hair, which should work, but at the cost of a much larger memory footprint.
I know I am missing something obvious, but I have run out of things to try...
No matter what I do, I can't seem to get the Photometric Spotlights to emit any light.
I have a couple of mesh lights in the scene. And one of these spotlights. I have twiddled the parameters of the spotlight for hours now. Moved it all around. Even to the point of being right on top of the subject. But nothing seems to be coming out...
I know this is hard to answer without seeing the scene, but some one must have some pointers. Or have had similar situations.
Take a look at posts #26 and #27 for tips about lighting: http://www.daz3d.com/forums/viewreply/778481/
edit: clarified text
Thanks. Looked. Tried. But no change.
Meaning I turned off the headlamps on the cameras. I upped the the lumens to an insane level on the spotlight. And I reset the temperature too. Not even a flicker of light is coming out of it. I even tried turning the light off to see if the control was inverted.
How about a scene with just a primitive ans a Photometric Spotlight?
Did that yesterday and everything was remarkably dark. Thought it was just me... but going to try again.
Same scene. Deleted everything but the camera and the spotlight. Added a primitive. Rendered. Nothing. Just a black scene. Like I said, nothing comes out of the spotlight.
Spotlight parameters:
Illumination: On
Light Tint: 255-255-207
Intensity: 100%
Spread: 86
Beam Expon: 4
Light Geometry: Point
Height: 10
Width: 10
Two Sided: On
Render Emitter: On
Luminous: Up at Ridiculous right now
Temperature: 6500
wow glad i found this thread thanks for sharing everyone
Added a Photometric Point light. Left default settings. Rendered. Nothing but black.
Deleted the spotlight. Rendered again. Nothing but black.
Changed to 3Delight. Rendered. Can see the primitive.
Switched back to Iray again. Rendered. Nothing but black.
Solved...
Environment Mode has to be Scene Only. Then the Photometric lights emit.
