Poser Pro 2010- Library not loading
2»
  • DiYaniraDiYanira Posts: 25
    mjc1016 said:
    DiYanira said:
    Hi, when trying to install the patch for Poser 9 it shows this
    What version of Windows?
    Is IE, Poser or anything else open when installing?
    Are you running the installer as a regular, limited user or as an administrator?
    I use windows 7. there was no program open and I run as administrator.
    Are you specifically right clicking the installer and choosing Run as Admin? Even an Admin account on windows needs to do that on certain files.
    Are you specifically right clicking the installer and choosing Run as Admin? Even an Admin account on windows needs to do that on certain files.Thank you, the right clicking the installer was what work, now is working fine Poser 9. But Poser 8 is still in white libraries I don't find how to uninstall the Internet Explorer 11.
    edited January 2014
    You can use this fix, issued by Microsoft http://www.microsoft.com/en-us/download/details.aspx?id=40722 There are instructions on the page as to how to install the fix.
    Post edited by Chohole on
    You can use this fix, issued by Microsoft http://www.microsoft.com/en-us/download/details.aspx?id=40722 There are instructions on the page as to how to install the fix.Internet Explorer 11 is already install, what do i do now? How i uninstall it?
    The fix from Microsoft took it off my computer when I ran it
    I should be writing somthing wrong in the command prompt, it's not working.
    Obviously the name at the top will be yours, but does this help. I needed help to get it right as well, and a friend did this screen shot for me to follow
    678 x 347 - 107K
    edited January 2014
    Once you get this sorted, I'd advise changing your windows update settings to "check for updates but let me choose whether to download and install them". That way you can catch any further IE updates at the door. I have IE 9, 10, and 11 updates all sitting hidden in my windows updates never to be installed (I do the same for any bing related crap too).
    Post edited by Lissa_xyz on
    Thank you Vascania and Chohole, for your help, I am still trying to make this work.
  • Nester751Nester751 Posts: 365
    On a side note, I just had a similar stoppage with Poser 11, discovered my firewall software updated and changed my settings (grr). After fixing it, works fine :)
