General Freebie Requests
1272830323350
  • DollyGirlDollyGirl Posts: 2,649
    robkelk said:
    http://freelancecomics.blogspot.ca/2011/04/descargas-downloads.html
    (And, yeah, I want a copy of the one illustrated by http://web.archive.org/web/20071107041816im_/http://xposer.org/hosting/216352465_21.jpg, too - but only if I can get it legally Maybe somebody could make a more modern version of it... especially if we give them better reference images to work with.)
    How about asking Sasuke256 about sweet talking shukky into posting it on their sharecg account. That is how I got the Cy_Co. Someone started a thread and everyone jumped on board saying they too would like the model.
    Yeah, Sasuke256 has gotten a few of the other things up from requests, too.
  • baronvonbaronbaronvonbaron Posts: 0
    edited February 2013
    I did send Sasuke a PM on ShareCG today… Hope they are still active…
    Post edited by baronvonbaron on
  • robkelkrobkelk Posts: 3,259
    dddx said:
    @robkelk
    While those are great alternatives, I already have all those… :/
    I tend to prefer Aiko 3 over Aiko 4… Renders take less time, etc…
    Incidentally, are there any other links for the following?
    http://www.3digitalcrafts.net/studiomaya/1download/character/yuna.zip
    http://www.3digitalcrafts.net/studiomaya/1download/mayahair/SpiralTwinTail_BJD.zip
    See the first link I gave you in the post that you replied to - it has links for both of these.
    The links to those two items are dead, that's why I asked if there were mirrors…
    The best mirror I know of is the Wayback Machine at archive.org ... but it isn't perfect.
    Feed the link into the Wayback Machine for the Yuna outfit:
    http://web.archive.org/web/20130120152427/http://www.3digitalcrafts.net/studiomaya/crbst_30.html
    As for the hair, it appears to be a paid item now. (If you're feeling lucky, see page 3 of this thread for an alternate link, and feed that into the Wayback Machine... but I make no promises.)
    Post edited by robkelk on
  • SteveM17SteveM17 Posts: 971
    Does anyone know where I can find bullet hole props? So that you can stick them on walls or vehicles to make it look like they've been damaged? In fact any prop that can suggest/signify damage would be cool.
    Here's a pack of shattered glass and other damage, including some bullet holes...
    http://www.sharecg.com/v/66942/gallery/5/3D-Model/Shattered-Glass
    Thank you… I have used web.archive.org several times… Not sure why I didn't try it with that link… I think started using it that way after seeing some of your links in your Aiko 3 resources thread…
    Wasn't able to find the hair, but I found other hair…and broken downloads for more nice hair…
    Bahh, this is a vicious cycle :(
  • 404nicg404nicg Posts: 270
    Hello all I'm looking for a nose piercing(not the ring kind) that I can use in Daz 3d on genesis. Thanks!
    Cool Tuna has a couple for M4 that might work. There are some for David and M3
    http://www.cooltuna.com/poser/poser-freebies.html
    They are closer to the bottom of the page
    Yeah, they'll work...just resave them after you reposition them and they'll be set the next time you want them.
    Cheers! Looking for debris and other destruction now.
    SteveM17 said:
    Here's a pack of shattered glass and other damage, including some bullet holes... http://www.sharecg.com/v/66942/gallery/5/3D-Model/Shattered-Glass
    Cheers! Looking for debris and other destruction now.[/quote
    Ok, I've gone wrong somewhere. This is what I get when I try to import one of the shatered glass objs onto a windscreen.
    1442 x 902 - 86K
  • JaderailJaderail Posts: 0
    What you need are post work Brushes to Add the Bullet holes to your Render. That set is not designed you be used the way your are trying to use it.
    Thanks for the quick reply!
    I've never used post work brushes (in fact I'm not sure what they are!), Apart from messing around with filters I don't do any postwork at all. I'm just wanting to slap bullet holes on props/scenery, nothing fancy or photorealistic. Isn't there something I can just stick on there?
    As Jade says you can use brushes here is a link to some free ones
    http://www.obsidiandawn.com/bullet-holes-photoshop-gimp-brushes
    Post edited by DollyGirl on
    Dollygirl said:
    As Jade says you can use brushed here is a link to some free one
    http://www.obsidiandawn.com/bullet-holes-photoshop-gimp-brushesIf those Brushes are in a PNG format you can use them in the DS4.5 LIE and add them right to the textures before you render.
    The link below is to Turbosquid and general search for "ruin". You can use objs directly into DAZ and 3ds files can be converted in Hexegon. You import the file in Hex then save out as obj.
    http://www.turbosquid.com/Search/Index.cfm?keyword=ruin
    you can do a search on sharecg and rendo on words like ruin, rubble, rusty and get some cool stuff that way.
    if they aren't which some of Dawn's stuff she does not include the png. Then use this little guy to convert them to pngs.
    http://www.downloadsource.net/7072/ABR-Viewer/
    Thanks for your advice guys. I downloaded the bulletholes you suggested, and applied/pasted them to a texture in good old MSPaint - the most basic art package ever. And it worked! It might not hold up to close scrutiny, but it has the effect I wanted as you can see below. I also found some good "ruins" type stuff, so thanks for that also.
    Now I'm off to do some damage!
    1447 x 905 - 119K
  • SassanikSassanik Posts: 340
    A winter parka? Anyone know where I can find a winter parka? Something one might wear on a trip to the south pole?
    Amy
    Here's one that works but you may need to add your own textures.
    http://www001.upp.so-net.ne.jp/ruten-ryojo/poser/download.html
  • foxyladyfoxylady Posts: 0
    Amy
    This is my favorite.
    http://www.sharecg.com/v/28700/Poser/Winter-Days-V4
    Thanks alot for your quick reply! They were exactly what I needed!
    Thank you guys! Those are great options! I will give them a try!
    Amy
  • joea64_bdfaa5ca94joea64_bdfaa5ca94 Posts: 298
    I would like to see if one of the modelers here could make up a coffin prop (with removable lid and interior/pillow) based on this coffin:
    http://upload.wikimedia.org/wikipedia/commons/6/6e/Sarg_Mary_Vetsera.jpg
    (This is the coffin in which Baroness Marie Vetsera was buried following her death in the 1889 Mayerling incident. It's typical of elaborate coffins made for members of the Austro-Hungarian aristocracy in the late 19th and early 20th centuries; Archduke Franz Ferdinand and his wife were buried in similar coffins following their assassination in 1914.) The fanciness of this type of coffin makes it, I think, a good match for aristocratic-vampire (hello, Count!) scenes and gothic/steampunk/horror scenes. I've gone through pretty much all the other free coffin and casket props out there, including Karth's, and none of them looks quite right for the kinds of elaborately elegant scenes I have in mind.
    (I also would love to find a better-quality modern-type casket model, similar to the kind of thing you see on Turbosquid but a lot less expensive, but that's a request for another day.)
    Well, the problem with that style is that there's not a lot of the detail that can be modeled in, without driving the poly count through the roof. And a quick look around...there don't seem to be many pics that show the details well enough to create displacement/bump/normal maps. Some probably do exist, but will need hunting down.
    I'd say, it's not likely to end up as a freebie...due to the amount of work that will go into it.
  • Faeryl WomynFaeryl Womyn Posts: 3,302
    I don't think it's necessary to have the model an exact match to that image. All one needs to do is create the cross with body on it to go on the lid like in the picture, then below that is what looks like little balls grouped together with ribbons between each one (I didn't enlarge the image to view that so could be wrong), then below that for two rows are filigree decoration circling the casket bottom, and the base all filigree with pedestals, not all that different from the old style claw footed tubs. You can find images to represent all those parts with no problem. It just needs to be elaborate, not an exact match and you can find images for those anywhere.
    The one thing not answered is if this request is for a distressed model or new look model.
