Poke-thru on modelled shirt? Help?
AeonicB
I'm having issues with poke-thru on a shirt. I started modelling it off the neutral Genesis base and used the Auto Transfer utility to fit it to Genesis, but when morphing the shape to Basic Female, it has some poke-thru on some... sensitive spots. I'd post a picture of the problem, but I'm unsure of the forums nudity rules.
Any tips on fixing this? (If anyone wants a picture, PM me...)
Add a smoothing modifier
Did, and it works fine. But smoothing means if the hands get near it, it kind of eats them (something like Poser's cloth room if you have hands on the side and decide to run a simulation.)
Would like a nicer solution than that. :/
If it's the right breast that's poking through, then that is a bug with the auto grouping function in both transfer utility and autofit in 4.5.0.114, it's been fixed in the beta.
How finely divided is the mesh over the breasts (I assume that's the problem area)? You may need to make a custom morph in your modeller, rather than using the auto-transferred morph, for optimum results.
Not very. Guess that's my problem, thanks. :) Mesh looks like heck, but I was thinking of posting it as a freebie as a modest "Hey, I tried" attempt. :)
Also, using Hexagon 2.5 as my modeller. :) Still using DAZ 4.0, nervous after hearing some problems installing 4.5...
