Cyborg test render
BC RiceBC Rice Posts: 591
Picked up the Cyborg character on sale today. Did a quick and dirty render. He's pretty neat. :)
http://www.youtube.com/watch?v=ixgpZltihJs
  • 3drendero3drendero Posts: 2,017
    Yepp, awesome character, here are my quick renders. Still having issues with detached pistons, even after trying Dzfires recommendation to reload and avoid zero pose. Do you get the same with the M4 General poses included with Carrara?
    500 x 650 - 98K
    500 x 650 - 129K
  • StezzaStezza Posts: 7,820
    I've tried importing a duf from DS with no luck, I've got it fitted to M4 with no luck I've imported a poser file with no luck..
    Nothing seems to work with this guy in Carrara. I've pointed stuff with no results either.
    But I'll hang onto it in the hope that one day the machine will work :roll:
    Works fine in Poser and DS
    640 x 480 - 18K
    edited September 2012
    The hands and feet issue I think there are 2 solutions for, over in the common thread in either one of both threads named cyber m4.
    Post 2 has a file that may or may not help:
    http://www.daz3d.com/forums/discussion/6113/P30
    Post 4 has another tip:
    http://www.sharecg.com/v/60772/related/11/Poser/Genesis-Hand-and-Foot-Fix-Pose
    Dzfire says never use the zero pose.
    One more untested trick, export from ds4 with:
    http://www.daz3d.com/shop/poser-format-exporter-pfe
    Final trick is to convert him to genesis with this instruction far down the thread:
    http://www.daz3d.com/forums/discussion/6753/P105
    Post edited by 3drendero on
    after trying all the tips..
    none worked except for the last one converting him to Genesis did the trick.. although not perfect it at least can be used.
    thanks for the links
    800 x 600 - 242K
    Post edited by Stezza on
  • BC RiceBC Rice Posts: 591
    I'm confused. Mine moves fine in Carrara.
    mine doesn't work in either Carrara 8.1pro nor 8.5B
    weird! :roll:
    Mine works in Carrara 8.1 Pro, I just load him up from
    Browser/Content/Figures/DZFire
    Only issue is the broken pistons seen in the second post, when I use the General Poses on him.
    I use 7 Pro. Not sure if that's making a difference. (Can't imagine why it would)
    Fiddling around today seeing I can't get any new stuff from here that will work in Carrara so I revisted an older problem and got the Cyber guy to work..
    Sweet smiley
    No more escaping pistons.... so far... wink
    Fix: open Daz Studio ( sorry it has to be done ) load up genesis... load up the cyborg then I cloned genesis onto the cyborg.. removed genesis and saved the cyborg..
