re-centering a scene
texjonestexjones Posts: 0
I wanted to find out if there was any easy way to re-center a scene over the center axis? Instead of moving the whole setup to where I need it, can I just edit the center axis to the point/area I want? Since most poses evolve around the center?
    You can't move the centre axis as far as I know, but you can select everything in the scene, and parent it to a Null, then move everything to where you want it using the Null. You can just select everything in the Scene and move it as one anyway, but the Null may be easier, you can unparent everything when done.
