problem with genesis 2, missing dsf file.
I've uninstalled Daz, then reinstalled everything with the DLM. Started the Content Management Service. But only part of Genesis 2 seems to have installed. Some of the files are there, but the .dsf is missing. Tried re-downloading it using the dlm again, same results. Any ideas?
I get an error message saying "/data/DAZ 3D/Genesis 2/Female/Genesis2Female.dsf" is missing.
    Have you checked in your installation location /data/ folder if the file is actually there, or D|S only thinks it isn't? Also, are you sure D|S and DIM are agreeing on where to install things? The two programs don't talk to each other, and by default DIM does not install content to the same location as D|S by default looks for it. Yes, that is as accident-prone as it sounds.
    Can you post screenshots of your DIM installation location and D|S Directory Manager settings? They should be preserved from your previous installation (unless you know how to do a clean sweep of the hidden files), but sometimes Weird Stuff™ happens.
  • JaderailJaderail Posts: 0
    If your missing the Start up scene you need to change that in Preferences>StartUp so it points to the Genesis.duf
    Here is mine pointing to my DIM content folder.
    426 x 186 - 22K
    edited October 2013
    Not trying to step on toes, but I'm not sure adding the startup scene for Genesis 1 would help with the /data files for G2F.
    Post edited by Lissa_xyz on
    Miss read the post... ignore the goofy blue guy...
  • edited December 1969
    DS wasn't looking in the C drive where DLM was installing stuff. It was looking at the drive I had an old installation on. Seems I have to go in and specifically add each sub-directory (like "people" or "product X",) even though I've added the parent directory. But now I know how to add the directory for anything I can't find at least. Thanks!
    You never ADD sub-directories Just the TOP folder. But you add it as BOTH a Daz Studio Format folder and as Poser Format both.
    Like shown here.
    444 x 365 - 51K
    If adding your sub-directories are fixing your issue, you may have a nested runtime problem.
