Supersuit in Carrara?
I can load genesis and apply the supersuit but I can't find how to adjust the suit. Is this possible in Carrara 8.5?
  • bighbigh Posts: 8,147
    works better in DS .
  • edited December 1969
    But can it be adjusted in Carrara?
    edited October 2013
    yes - click actor - look under parameters
    Post edited by bigh on
    Found it thanks!
    What about the colors, can't figure out how to adjust them now.
  • TerritanTerritan Posts: 75
    Found it thanks!
    How is the color channel set in the suit's shader?
    (Looking at the supersuit bundle now. If it's really that alien to Carrara, it may not be worth it.)
  • DartanbeckDartanbeck Posts: 14,671
    I know that the shaders for the Supersuit are created specifically for DS, I haven't tried them.
    Found it thanks!
    the only way I know that works is to do it in DS and save as DUF ( that will work for sure )
    Cool! That's easy, and adds itto the library anyways. Thanks bigh!
    you welcome
    here's one from C8.5
    840 x 630 - 57K
    Looks good bigh, thanks for the info.
    you welcome
    more info -
    ok - after you have your DUF in C .
    you can goto Browser
    Products - S
    find Supersuit
    you can play with it by clicking on the suits things - ( but have to get the texture from DS first )
    I'm still not doing something right. Saved as .DUF but when I opened it in Carrara all I had was an empty suit. Dragged it to actor but it didn't fit to genesis.
    OK, I saved it as a scene and it worked. When I saved it as a character preset it was the empty suit.
  • StezzaKararaStezzaKarara Posts: 4,881
    I used eyeGore for Genisis with the super suit in DS and saved the scene then opened in Carrara and posed and added the other bits
    Seems ok.. I haven't really used the super suit since I bought it so was a good practice to find out.
    450 x 800 - 234K
    Looks good!
    I'm starting to make a little progress.
    neat :-)
    HELP Me
    1280 x 720 - 406K
