Bryce 7 Pro to Daz Studio Pro 4 Bridge Issues
TVA3dfxTVA3dfx Posts: 0
edited December 1969 in Bryce Discussion
Bryce 7 Pro to Daz Studio Pro 4 Bridge Issues... I can move a character from DAZ Pro to Bryce Pro, but I can't open DAZ from within Bryce.
Any suggestions are appreciated.
Thanks.
Terry
    Moved to the Bryce forum as it doesn't belong in the Welcome Area
  • srieschsriesch Posts: 4,241
    If your issue hasn't been resolved already at this point: exactly what happens when you try? Do you get an error message (and if so, what is it), or does nothing seems to happen, or does something unexpected happen?
  • TVA3dfxTVA3dfx Posts: 0
    Sean... thanks for getting back to me. I eventually got the problem worked out..
  • ronmolinaronmolina Posts: 118
    Tell me how you solved the problem as I am having the same one. I can send to Bryce but cannot see Bryce in Daz when I go the other way. Thanks in advance.
    Make sure you have your object(s) selected in Bryce before you send them to DAZ Studio. If you haven't already, test with something small like a cube to see if the problem is related to the object you are sending.
    Okay thinks I will try that.
    If that doesn't work then send a blank scene from Daz to Bryce first to establish the connection and then open the scene you need to send back to Daz Studio and it should go OK.
    Qualifier: I don't use the bridge myself as I don't use Daz Studio but that is what I've read from other users who report the same problems.
