Uhhm - where are the Latex Shaders?
EddyMI3DEddyMI3D Posts: 365
edited February 2013 in Carrara Discussion
Hello out there!
Does anybody know where the Latex Shaders (http://184.72.52.194/doku.php/public/read_me/index/13274/start#product_information) have gone?
Thanks in advance,
Eddy
Post edited by EddyMI3D on
«1
  • 3drendero3drendero Posts: 2,017
    There is some Carrara latex action in this set:
    http://www.daz3d.com/glossy-shaders
    Just listed, not previewed.
    The PA for the shaders in the first link above does not sell the shaders anymore.
    The DeviantArt page shows a new name and the journal has entries about severe depression issues.
  • EddyMI3DEddyMI3D Posts: 365
    Thank you for this infos and your efforts.
    Eddy
  • DartanbeckDartanbeck Posts: 21,245
    What a bummer! Hope everything works out.
  • Kevin SandersonKevin Sanderson Posts: 1,643
    If it's the same CoolArtDude, they've posted here in the past couple weeks.
    Post edited by Kevin Sanderson on
    Holyforest isn't the CoolArtDude, is it? I didn't think so. But I thought CoolArtDude had shaders at the store and I wasn't finding his name amongst the vendors. Do you know?
    Eddy, did you try those shaders? I wasn't sure what sort of latex you meant. Latex shiny stuff, latex gloves... but for shiny latex stuff, some of the plastic shaders that come with Carrara could be slightly altered to get a great look.
    Latex seems pretty easy... It needs a low value in the reflection channel, but you will probably need a reflection map in your background. If you search your runtime you'll probably find something called reflect.jpg or reflectmap.jpg They are so common you might have several.
    Carrara doesn't have a global reflection shader *hint hint plugin makers!* so if you don't already have an hdr in the background, add the reflection map as the background.
    Hello and thank you for all your replies.
    I tried some glossy shaders from Digital Painter
    and a HDRI background map delivered with Reality.
    So i produced this one. (seems to be a bit cold there ;-) )
    Eddy
    2000 x 2000 - 520K
  • NoneNone Posts: 0
    Daz decided to remove me as a vendor without even telling me, I have the 2nd and 3rd set I did but due to a hard drive issue I lost the first set, was thinking of uploading them to sharecg or something, but work is taking all my time atm
    Post edited by None on
    Hello CoolArtDude,
    thank you for your reply. Sorry to hear that they took you off.
    Take your time. Work is for living, so more important.
    Thanks for your efforts and take care.
    Eddy
  • NoneNone Posts: 0
    http://www.sharecg.com/v/67576/browse/7/Material-and-Shader/Carrara-Latex-Shaders---Set-2
    I doubt I will upload the 3rd set as It never sold well and I cant say I liked it myself, was more a mess about, you can change the colours easily enough, and play about with SSS, although that never seems to do anything other than slow the render down :lol:
    Anyhow, thanks a lot for sharing.
    A really huge package - I'll try them soon.
    Very kind of you.
    Have a good time.
    Eddy
    Ok, this is the former image with the CoolArtDude's Latex Shaders
    2000 x 2000 - 515K
  • NoneNone Posts: 0
    tempted to say it looked better before :lol:
    they were my first attempt at making shaders and trying to give back something, as well as learn something, you can always adjust the highlight and shininess to suit, I always found IBL or HDRI to work best :)
    Thank you CoolArtDude for the free release, news post here: http://carraracafe.com/?p=2647
    I like the second image, looks more like new clean latex for a photoshoot, the first one is more like old dusty latex...
  • NoneNone Posts: 0
    If anyone has the first set could they send it to me? I cant be arsed to redo it, and it was the only thing Carrara wise I couldn't recover from the old drive :/
    Updated the news post with the request for the first set.
    Thanks again.
    Thank you for the third set.
  • NoneNone Posts: 0
    you're welcome - guess no one has the first set :( - maybe i will remake it, will have to see when i have the time
  • BrianP21361BrianP21361 Posts: 791
    CoolArtDude,
    Thanks for these terrific shaders.
  • NoneNone Posts: 0
    no problem, i was working on some leather shaders before daz dropper me without a word, but lost them in hdd failure - thought i had them on back up drive :( - i have multiple backups now - learn from my mistake - have backups of backups :)
    Thanks, updated the news post again at http://carraracafe.com/?p=2647
    Thank you for posting and I hope we will see some more products from you, free or not.
  • NoneNone Posts: 0
    you never know ;)
  • 3DAGE3DAGE Posts: 3,311
    Hi Cool Art Dude :)
    On the ShareCG page,. under Usage right,.. you have "All rights reserved" which means theoretically nobody can use it. or download it
  • NoneNone Posts: 0
    aw feck - i shall correct that
    edit: should be better now :)
    No problem, :)
    It happens all the time with those multiple choice / options. .. too many boxes.
  • NoneNone Posts: 0
    indeed, did you see PM i sent you?
    I've had No PM's :(
    me no like new PM system.
