Poser help needed!
music2u4umusic2u4u Posts: 2,822
Hi folks. I usually don't post here, just lurk, but I have a friend who is having a problem with Poser. It is a pretty common thing I hear, so maybe some Poser expert can give us a resolve.
I do know, this issue was addressed a few years ago and a few clicks cleared up the problem, but I can't remember how or who posted it, so here we go:
How do you fix the flipped normal problem in Poser when you import an .obj file. Over half the model is transparent. I know there is a way to do it, but I can't remember. Any help would be greatly appreciated by many I am sure.
Anyone?
  • CherokeeCherokee Posts: 292
    Poser has a Render setting to Remove Backfacing Polys but that's not a solution to the import problem.
    Go into the materials room and check to see that the "make normals forward" box is checked.
    That only works for rendering, the mesh still has reversed polys, that's what is needed to correct.
    I usually solve the problem by importing the model into a modeling application like 3D Studio and exporting it without normals. That way the polys are all double-sided and therefore are always facing the right direction regardless.
    Try importing the model into Poseray and then exporting it back out again.
    https://sites.google.com/site/poseray/
    UVmapper Pro can fix normals as well.
  • McGyverMcGyver Posts: 7,008
    If I'm not mistaken that model comes from 3D warehouse. It looked like a SketchUp issue... Lots of people who are great modeler don't understand the flipped normals in SU.
    Open the model up in SU... Go to View> Face Style> Monochrome... You'll see that the parts of your model that are Blueish-purple are the same parts that are reversed in Poser.
    There are two ways of fixing this.... The best is to flip them manually, You will have to choose- View> Hidden Geometry and then go into the various groups that make up the model and flip the normals to the WHITE side facing out... (the problem is the part may not be "painted" on the other side)... you flip the normals by Choosing- Edit> Face (or Surfaces)> Reverse faces.
    There is a script that tries to figure out what faces are flipped improperly and tries to fix it... it may be OrientFaces.rb, but I forget... Go to SketchUcation and look around in the plugins index at the plugins forum...
    I have to run now, I'll try and check back tonight and see if there is something better out there... Good luck.
    926 x 509 - 129K
    There is this- Automatic Face Reverser:
    http://sketchucation.com/forums/viewtopic.php?t=5333
    I can't really try it out now but I figured I'd give you a Heads up on it...
  • music2u4umusic2u4u Posts: 2,822
    edited February 2013
    I do alot of Sketchup modeling. There are tons of models with this problem. Beginners especially. They think,click, ooooo color and go with that. It works fine for SU but it won't work when exporting. There are two sides like you said, a white one and a bluish one. Each will take a color or texture. The side that is white will dominate when exported. You also will get a surface called "Font" which will always be white. Sometimes the entire model. These are the flipped normals with the wrong side (bluish) one textured or colored. Will stay white.
    One way to resolve this is to use grouping. If you make a flat plane, select it, go to edit, make group. The entire plane will then select with edges. Now texture or color it and it will export with that color or texture on both sides everytime. I group everything. Make a room, make a wall plane, cut your window or door way, now group it. Now pull out the wall for thickness. Now texture it all one color, OR, go to edit, edit group, open the group up and color inside wall part, and use a brick texture on the outside wall part. click the group off and it will hold the color and bricks in place. It can get complicated, but gets easy after you learn how to work with groups...also you can group something, like a table leg, then go to edit, copy, paste into place, and it will duplicate the leg on top of the other one, then just use the arrows on your keyboard to move them side to side or up and down. This makes a precise placement. I do this for tires on cars, you can even flip the tire in edit also.
    The person who made this car must have either converted it from a .3ds file or .obj file and just didn't know about grouping correctly. I have made hundreds of models in SU and never had a single complaint on import of the .obj files from any program user. This is the key...grouping!
    Daz Studio 3.1 import and rendered:
    1280 x 1024 - 105K
    Post edited by music2u4u on
    I was going to mention that, when you look at the model in person it appears to be a conversion issue (probably 3ds)... I tried using a couple of the plugins for face orientation and none of them really worked on this model... they would reverse some of the faces, but most remained unchanged... The original model was great, but if you look close there are lots of little gaps and stray faces here and there... but still, as is its not bad.
    I forgot to mention it but, I think the reversed face transparency thing in Poser only really shows up in preview... I think it only really becomes a problem with advanced materials and image based textures where you can see the texture is reversed... like lettering. I think most simple materials render okay in Poser...
    Here is another face reverser (this one by TIG) for SU if you ever need it... http://sketchucation.com/forums/viewtopic.php?t=30107
    I get the disappearing faces in my icon when I make a .pp2 file, but the model itself always comes up full when opened in Daz Studio, so I have never really worried about it. I just don't do that much in Poser because it crashes everytime I try to load a character or more than one prop. So, I use it mainly for converting .obj files to .pp2 files.
    Anyone?
    Maybe no one is still at DAZ now that remembers that thread. I've searched through the old forums but haven't located it yet.
  • BWSmanBWSman Posts: 0
    Got into the Material room & on the Poser surface node; click the Normals Forward checkbox.
    516 x 732 - 231K
    I mentioned that in a message above. That isn't a fix, it's a work around.
  • wimvdb_dc63ee9ce6wimvdb_dc63ee9ce6 Posts: 183
    In the render settings, select the Preview tab, then UNCHECK Remove Backfacing polygons. That will show the backfacing polygons
    Alternatively in the group editor, you can select the group which contains the backfacing polygons and then select Reverse Group Normals. This will only work however if the entire group has reversed normals.
