Installing daz content to Poserpro 64 bit.
Just done a new clean install of Posepro 2012 when I built my new PC, now putting Gen 4 figures back on and wondering I get content and getting rid of the message that says ,When used with Poser TM, "Victoria 4.1 Base" must be installed to the same directory as the application executable; due to restrictions on support file locations. Please select the directory that contains your Poser executable. '
    Select DAZ Studio as the target application, not Poser, and EXACTLY the same files will be installed. The installer is looking for a program called poser.exe which Poser Pro does not have.
    You must also install the V4 morphs, A4 and Gril4 etcetc, into the ame folder, and that applies to Morphs++ for V4 as well.
  • edited December 1969
    Shame one has to use a work around because the installer is such a pain.
  • info_7ab70978f3info_7ab70978f3 Posts: 78
    edited November 2012
    Do what most everyone else does and make a text doc in you PP2012 content dir and rename it poser.exe
    or Any other Folder you want V4 in (like Her Own maybe?)
    Post edited by info_7ab70978f3 on
