Apply Smoothing Modifier and Collision Iterations
malcolm jacobsmalcolm jacobs Posts: 107
hi to every one on the forum,
i hope someone can help with this,
i'm having some trouble with dress poke though,
i upload some images , perhaps thats better for people to see what i mean.
1) i can get the dress to fit, but when i render the image i get poke though ive tried many times to stop this, but honestly i don't know where i'm going wrong.
2) this is lilblackone dress on alysa body morphs with tights
yes she does look beautiful, untill i render the character.
tried parent change to fit victoria 4 and tried fit lilblackone genesis figure
tryed adjusting the size parameters,
any ideas please?
  • malcolm jacobsmalcolm jacobs Posts: 107
    any ideas please?
    676 x 876 - 35K
    ok
    676 x 876 - 30K
    1280 x 1024 - 140K
    Malmaoo said:
    ok
    different shot
    still got some trouble
    any ideas
    thank you for any ideas you all might have
    1280 x 1024 - 133K
    Malmaoo said:
    Malmaoo said:
    ok
    different shot
    any ideas
    problem with the thights poke through the dress
    looks perfect until i render the character
    676 x 876 - 25K
    in this shot again,
    the dress pokes trhough
    any ideas?
    thanks
    800 x 876 - 54K
  • ElliandraElliandra Posts: 476
    Hey Mal!
    I did a tutorial on applying and using the smoothing modifiers on V4 but it will work for pretty much anything in DAZ Studio if you want to take a look it is located here:
    http://www.daz3d.com/forums/discussion/9823/
    Elli
  • SzarkSzark Posts: 10,634
    What are the smmothing and collision set to? Up the collison to 15 to start with.
    Also the mesh resolutuon of the dress may not be good enough to collide with the figure. Add SuBD and try again.
    thanks Szark, ill try that, i only used low settings on both.
    i will give it a go.
    thank you,
    ill post the result if it works
    Elliandra said:
    Hey Mal!
    Elli
    to Elliandra, thanks, i will take a look at your Tutorial, and see if i can get a better result
    finding out what Daz can do, a little bit more each day
    kind regards
    Hey Mal!
    thank you Elliandra,for your information regarding Smoothing ,
    ect ect,
    any ideas about the following,
    i have to ask, Tights, or stokings in the Autofit ?"
    why is there no option for "Tights, or stokings in the Autofit ?" don't know why daz never thought of making tights or stokings as an option on Autofit. maybe they did, but it's missing in my
    Daz 4.5 pro....
    My Question: I have the LDStokings trying to Put Alyson's LD Stokings
    Onto Genisis the Figure , but i can't get them to go.
    also tried V4 Stokings, to fit on genisis, not very good results
    Autofit does not have Alyson Listed in the menue
    the Autofit Does not list Stokings either
    any idea, What to click on? ,
    thank you for any help.
