Fall 2016 - mcjAimAnim - Target, Targeter, Rotator, Animate
mCasualmCasual Posts: 4,604
edited August 2016 in Freebies
similar to mcjAutoLimb, but it will work with anything !
so
1 - you select a target, for example, a null node near a door handle
2 - you select a targeter, (a bit like an arrow head ), example, Victoria6's index tip
3 - you select the rotator, example, Victoria6's shoulder
note: the Rotator could also be, her foreArm, her Collarbone, her chest, her abdomen, her hip, her root node, a node she's parented to !
4 - you select the range of frames to process, example, the whole play-range
5 - you click the GO button and bam, the script oriented the shoulder bone so that the shoulder to index line points at the target, for the whole range of frames specified !
since i lost the mcjAimAnim code (hardware issues ) i was saying in a post below
that i will try to re-write it later this fall BUT there's my mcjOptimalPose script here
https://sites.google.com/site/mcasualsdazscripts7/mcjoptimalposea
which may actually be what mcjAimAnim became
my main animation tool based on goals is mcjAutoLimb
https://sites.google.com/site/mcasualsdazscripts6/mcjautolimb2015
( i hope you did not miss the release of the free niceiful door and wall prop shown here !!! )
Post edited by mCasual on
  • mCasualmCasual Posts: 4,604
    edited July 2015
    Example of a clever trick
    create a null node at the exact location of your figure's right toes
    ( this can be done easily using mcjParent or mcjMakeTarget )
    parent the figure to this null node
    Use this null node as the rotator
    Victoria will tilt her whole body while maintaining her toes location
    Still reading?
    ok now the parent node is animated
    but that's a bit awkward to carry along
    so, create a null node, lets call it the H node
    use mcjParent to make that node follow Victoria's hip node position and rotation for the duration of the animation
    unparent Victoria from her Rotator node
    use mcjParent to makeVictoria's hip node  follow the position and rotation of the H node for the duration of the animation!
    but yes she's more likely to simply adjust her arm or abdomen to reach the door handle )
    edited July 2015
    so as i was saying ... today we'll have mcjAimAnim
    which just re-orients a joint to solve an Aim,
    it will work for Pose work
    and it will work for animations
    1318 x 744 - 396K
    edited July 2015
    even ifthis system needs only 3 nodes selected
    you can select more, this way you can adjust , for example, a shoulder then a forearm, then a hand
    1023 x 578 - 256K
    edited July 2015
    when there's no locked rotation axis, the maths is easy, but ... well, i'll do it !
    here, the target is the yellow ball, the targeter is the light-blue ball, the Rotator is the cube ( to which the light-blue ball is parented
    and we want the Aiming to be solved using only the Y and X rotations
    when we dont lock the z axis we get XYZ rotations -30,40,10
    1036 x 584 - 201K
    i dont understand the forum's commenting protocol yet
    anyway, it worked !
    luckily i had a project-point-on-normal plane function stashed :)
    //==================================================================////==================================================================function projectPointOnPlane( p, n ){	var t = p.dot( n );	var v = DzVec3(   p.x - t * n.x,  p.y - t * n.y, p.z - t * n.z );	return( v );}
    you would think that
    limbRoot.getWSRot( t ).getZAxis();
    would return a normalized vector, wouldn't you
    well you would be wrong
    so, remember that
    and you too, me
    well ... tomorrow :)
  • DigiDotzDigiDotz Posts: 508
    oi oi subcribe to thread...
    300 x 350 - 15K
    edited July 2015
    removed
    edited July 2015
    and who knows, maybe the 'tomorrow mentioned in the title is today :)
    oops that picture is for the other similar script
    edited July 2015
    ( looks like the prefered image width is 800 )
    1920 x 1080 - 642K
    1920 x 1080 - 848K
    edited July 2015
    var joint = Scene.getPrimarySelection();
    var r = joint.getWSRot();
    var o = joint.getOrientation();
    o = o.multiply( r );
    there, now we have the current rotation axis for the selected node;
    edited July 2015
    the rotated joint orientation was the missing piece
    function getWSAxis( joint, axisNo ){	var v = new DzVec3( 0, 1, 0 );	switch( axisNo )	{		case 0:			v = joint.getOrientation().getXAxis();		break;		case 1:			v = joint.getOrientation().getYAxis();		break;		case 2:			v = joint.getOrientation().getZAxis();		break;	}	var r = joint.getWSRot();	return( r.multVec( v ) );}
    1249 x 695 - 128K
    edited July 2015
    removed
    edited July 2015
    well that's odd
    i'm pretty sure that, as long as there's no rotation limits
    one can aim a vector anywhere using 2 rotation axis
    it almost works perfectly when i do, say, rotateY followed by rotate Z
    but not quite !
    in fact in one test situation it took 50 cycles of RotY/rotZ
    until i reached the limits of the float() precision
    1464 x 826 - 219K
    edited July 2015
    maybe if i measure the needed angles first then apply them
    instead of measuring-applying them in turn
    ... nope same results
    834 x 368 - 66K
    edited July 2015
    when i'm free to use all 3 axis, no problem
    with 2 axis, in 2 operations i get very close to the result, but i have to use successive approximations to get perfect results
    i hope to solve the 2 axis cases today ( as i did in recent todays :) )
    1920 x 1080 - 633K
  • JigSaw73JigSaw73 Posts: 80
    Subscribing for updates - thank you!
  • The script is looking really good, I've been wanting to do this for so long.
  • Hello
    Script seems nice but where can i download it ?
    Thanks for your hard work mcj
    edited August 2016
    Hello
    i dont think i posted it
    i cant remember exactly why i didnt complete it , last summer
    i'll try not to forget it !
    well i do remember there were some vector/maths problems to solve, but usually i dont just stop!
    for now i have other projects i dont want to stray away from
    but i'll get back to it soon'ish
    note that you can follow my current works here http://mcasual.deviantart.com/gallery/
    problem - i searched for that script on my drives and i fear it's one of the programs i lost in a hard drive incident ( hard drive, motherboard, cpu, monitor incident actually )
    i started resuscitating the mcjAimAnim script but it will be posted only later this autumn
  • ZaarZaar Posts: 3
    Hello mCasual.  Can't seem to find the script download link. Does the script still exist?  Would love to try it.
    edited August 2016
    since i lost the code (hardware issues ) i was saying in the posts above
