Hello
I realized an object.
I want to duplicate it 10 times.
How do I do?
In DAZ Studio 4.5 you do the following:
Select the object you want to duplicate or Instance > Create pull down menu > Create Node Instance
Once it is created you can select the items from the Scene Tab and move them to where you want them.
Remember that the items will follow what ever you do to the original or parent item. So if you raise the arm, the arms of the instance will follow.
Jimmy you are slacking today aren't you :roll: That is not at all like you, normally you are very quick on the draw, And this time it was the Boss who beat you, hehe. :coolsmile:
Good luck!
You can use the Create menu, and use the New Node Instances option, and enter the number of instances you want.
This is a recent addition to DS4.5, you had to merge from a saved scene in the past.
EDIT:
Too slow!
I know! It must be the cold seeping into my old bones :)
Ooh yes I know that feeling, especially up here on this drafty mountain.
