Animating a Keyboard using a MIDI text file
KeironKeiron Posts: 419
edited February 2016 in Art Studio
Hi and Welcome to Animating a Keyboard using MIDI
Please find below a video link showing you how to get started
You will need Casuals great MIDIload script
MIDI helper latest version is now 2.4
A Text Editor like Notepad
A MIDi text file ie a MIDI file that has been converted to a text file
A model Keyboard
You can get MIDIhelper here
http://keiron.me.uk/download/MIDI_Helper_ver2.4.xlsb
You can get TextPad here
https://www.textpad.com/download/index.html
You can get mf2t here
http://matsp888.no-ip.org/~mats/software/winunix/midi/mf2t/
You can get MIDICSV from here
http://www.fourmilab.ch/webtools/midicsv/
After downloading I've renamed the MF2t xxxxxx to just Mf2t and placed it in the Program folder on the C drive I've then pointed
MIDIload to that so I can convert the MIDI file from within the program
On Line MIDI to Text converter
http://flashmusicgames.com/midi/mid2txt.php
You can get MIDiload here
https://sites.google.com/site/mcasualsdazscripts5/mcjmidikit
You might also like to get some of his models the 66 and 88 keyboards is very cool, can be fully animated and it's free
Here is a link for the 1 - 16 channel configs for the 88 key Wurkzell
http://keiron.me.uk/download/Wurkzell_Config_310116.zip
Post edited by Keiron on
  • KeironKeiron Posts: 419
    16  configs for the 88 key Wurkzell link added
    To use
    1. Obtain 88 key Wurkzell keyboard + MIDIload from Casual's site
    2. Check files with Antivirus of your choice
    3. Unzip to a loction of your choice
    4. Load Wurkzell keyboard into Daz Studio. I'm using 4.9 at this time
    5. Select whole Wurkzell Keybord model
    6. Ensure you have loaded MIDI text file
    7. Using Load locate the unzipped Config files and choose the one with the MIDI channel you want to use
    So if it's a instrument on channel 1 then choose the channel1 text file config. Once its loaded push into timeline once
    Tutorial Added
    How to position the Generation 2 Genesis 2 figure's Collar Shoulders, Arms , Hands and Fingers.
    Adding fixed points for the Collar Shoulders, Arms, hands
    How to position the fingers to get maximum stretch of the hand using the Hands Carpals, Fingers and Thumbs
    Tutorial Added
    How to move the fingers and thumbs to match the notes played
    How to correct the hand position
    How to set the shoulder and forearm to position the hands
    How to create the fixed positions
    How to set the Interpolation type from TCB - Linear to Constant
    When to set Constant to TCB
    Tutorial added
    How to tackle Chord changes in the Animation
    How to add the finger changes to match Keyboard notes
  • pierre_basmoreaupierre_basmoreau Posts: 15
    edited February 2025
    Hi,
    I found your discussion because I am interesting to animate a piano keyboard.(Protozoon's Grand Piano).
    In your discussion, you tell
    "You can get mf2t here http://matsp888.no-ip.org/~mats/software/winunix/midi/mf2t/"
    but the link is broken.
    I found the new version of mf2t for several OS at this address : https://pieter.vanoostrum.org/en/midi2text-mf2t-t2mf/
    I thought it will be usefull for all.
    Best regards
    Post edited by pierre_basmoreau on
    Hi Thank you for the update
    I'd make sure the names of the mf2t file is the same as the old one other wise it may not work in the progrm
    Good luck with you animations
    Kindest wishes
    Keiron
