PostgreSQL CMS
Thadeus72Thadeus72 Posts: 415
hi
i try to install postgre sql cms with the dim and i lost my smart content
i have windows 7 and kaspersky
kaspersky seem to block nothing
i'd like to reinstall the old cms but i don't find the exe ... where is it ?
thanks in advance
    Did you also install the file called 'PostgreSQL CMS From Valentina CMS Conversion'?
    That converst the older Valentina db files to PostgreSQL and then you Smart Content should work as expected. I would strongly advise you to try the newer Posetgres CMS system, as it has proved to be much more stable than the older Valentina one.
    When you run DAZ Studio, go to the drop-down menu in the Content Library pane, and try clicking on 'Start CMS' and let me know if that works.
    i’d like to reinstall the old cms but i don’t find the exe ... where is it ?
    There never was an EXE for this, it was always installed as part of the main application install.
  • Thadeus72Thadeus72 Posts: 415
    ok i will try and i will do screen capture to show my problem
    thanks for your help
    hi
    yes i install 'PostgreSQL CMS From Valentina CMS Conversion" but nothing happen
    when i click on start cms nothing happen to
    i reinstall everything but samrt content don't appear
    The other thing to try is to reimport the metadata.
    In the drop-down menu in the Content Library pane, select 'Content DB Maintenance' and then 'Re-Import Metadata' Hopefully that will fix Smart Content for you.
    If that doesn't work, please let me know.
    hi
    i reimport metadatas but it was very speed and nothing change
    thanks a lot for your help and your patience
  • fixmypcmikefixmypcmike Posts: 19,713
    In the Content Library pane, do you see 3 items (DAZ Studio Formats, Poser Formats, Other Formats) or 5 (the above plus Products and Categories)?
    hi
    i see daz format, poser format and other import format
    i reinstall postgresql and i activate kaspesky notification , it say nothing ...
    thanks
    If you don't see 'Products' and 'Categories' in your Content Library pane, it means that your CMS (PostgreSQL) is not running.
    When you run DAZ Studio, you should have several instances of 'postgres.exe' running in Task Manager. With DAZ Studio and the Task Manager open, try to 'Start CMS' from the Content Library drop-down menu to see if that causes CMS to run.
    If that doesn't do anything, then there is something wrong with your install of PosstgreSQL or something is blocking it. Mike will be able to help more I'M sure.
    i have no potgres.exe running in task manager
    i reinstall postgre and desactivate kaspersky
    nothing change
    hi
    it is possible to reinstall the "old smart content " , i need the product list
    thanks in advance
  • atticanneatticanne Posts: 3,009
    Did you get your problem solved yet?
    no
    i don't have smart content anymore ;o)
