Daz characters to "3D Figurines"
6r6r Posts: 463
edited February 2015 in Daz Studio Discussion
You can see my "3D Figurines" renders. (No postwork !)
Here is the Freak, unpainted, a little bit painted and full painted :
512 x 512 - 103K
512 x 512 - 107K
512 x 512 - 107K
Post edited by 6r on
«13
  • 6r6r Posts: 463
    edited January 2015
    Hero :
    512 x 512 - 156K
    512 x 512 - 122K
  • 6r6r Posts: 463
    The Brute :
    128 x 256 - 30K
    128 x 256 - 31K
  • 6r6r Posts: 463
    edited January 2015
    Very interesting small renders for 2D games :
    96 x 128 - 14K
    96 x 128 - 16K
    128 x 128 - 19K
    128 x 128 - 16K
  • FetitoFetito Posts: 481
    Could you add a step by step tutorial? :P
  • Proxima ShiningProxima Shining Posts: 969
    Very cool!! How do you do this, pretty please?
  • 6r6r Posts: 463
    Thanks a lot...
    I don't have enough time to make tutorials because I'm working on several projects. And especially this one now to find the best effect. As you can see below I'm trying to use it on "painted" or "plastic" figurines, following the needs.
    The Girl4 with a musculous body... with a painted effect or a plastic effect :
    512 x 512 - 164K
    512 x 512 - 165K
  • 6r6r Posts: 463
    Here is the Freak as a Figurine with a nice plastic effect :
    512 x 512 - 130K
  • Scott LivingstonScott Livingston Posts: 4,352
    These are very convincing, nice work! Can you tell us what shader you are using?
  • CriosCrios Posts: 3,115
    Can be really usefull know the shader or your workflow, if you use post production on renders.
  • 6r6r Posts: 463
    Thanks a lot...
    No ! I don't use any shader. I simply use an included Daz UberEnvironment (+ 1 distant light) and insert a character.
    Then I (generally) delete all the textures to work with Colors only (and right values in the Surface panel !).
    I don't need postwork ! It's why it's interesting to use because it's fast and easy. And it's important to avoid postproduction if I want to make sprites for games : I just have to render a picture or an animation (.png series) with Daz Studio ! No time to waste...
    256 x 512 - 103K
  • 6r6r Posts: 463
    edited January 2015
    Updated : In fact, with the same file I can have 4 different renders by modifying a few things :
    * unpainted Figurine
    * painted Figurine
    * plastic Figurine
    * smooth Pixar effect
    256 x 256 - 80K
    256 x 256 - 83K
    256 x 256 - 83K
    256 x 256 - 85K
  • Atticus BonesAtticus Bones Posts: 364
    edited January 2015
    These are super awesome! Can you please share some screenshots of the settings you used for the painted effect? The AO is really effective.
    Post edited by Atticus Bones on
    6r said:
    Thanks a lot...
    Very clever, and the results speak for themselves. Reminds me of what SnowSultan did here: http://www.daz3d.com/forums/discussion/40700/ though clearly there are some differences too.
    edited January 2015
    Really great, especially because is made only with Uber enviroment and 1 light. You must say us the settings. Please.
    (i ever tryed to make sprite for games, but never satisfied how are coming out).
    Post edited by Crios on
  • IppotamusIppotamus Posts: 1,580
    Really clever and a cool final look.
    Great job!
  • BeeMKayBeeMKay Posts: 7,019
    edited January 2015
    Try the following settings:
    In Ueberenvironment, set Saturation and Contrast to 200%.
    Set the distant light to low output, around 30%, and use shadows with shadow softness cranked up to around 30%.
    In Render Settings, use "Intermediate OpenGDL".
    Render.
    I think that you have to tweak the settings of the UE a bit more to get the soft shadows.
    Mod Edit:- Please repost the images cropped higher to hide the groin area, thanks.
    1400 x 933 - 91K
    1400 x 933 - 72K
    Post edited by BeeMKay on
  • 6r6r Posts: 463
    I'm very happy to know people like my work...
    Fantastic if you have found a nice render !?! Unfortunately I can't see your pictures (removed ?)...
    It's exactly what I wanted to say : With the basics (Uberenvironment + 1 light) YOU can make tests to find YOUR settings and YOUR renders.
    These settings are absolutely not like mine but as you could see I have found several renders by playing with the settings only. Maybe YOU will find a better render than me !?! That would be great !!!
    512 x 512 - 127K
  • 6r6r Posts: 463
    I'm working a lot on this file to improve it or to find other interesting renders.
    Here I have tried with the Textures : (I prefer with Colors only ! But wait and see with other tests...)
    256 x 512 - 82K
    Okay, thanks to Mr/Mrs Mod, I had to rerender this. :-)
    I've tried the setting with Ambient Occulsion selected in the UE, which gave even better results. It's still some experimenting, though.
  • 6r6r Posts: 463
    edited January 2015
    Nice experimenting... Like you I had to test again and again to reach my aim.
    This way I could understand better how it works... then how and where I had to modify parameters.
    It's magic to see the result little by little because it can be very different from the scene before rendering !!!
    Here is a scene : (to show it's the same file without postproduction !)
    512 x 512 - 183K
    512 x 512 - 173K
    512 x 512 - 156K
    edited January 2015
    I get good results with indirect lighting settings.
    I think the Indirect Light with Bounce comes closest to your original, but I don't have the time now to fiddle more with the settings.
    1400 x 933 - 94K
    1400 x 933 - 117K
    edited January 2015
    No luck... Tweaked every single setting, and still can't figure out how to replicate the level of ambient occlusion on those "unpainted" examples.
    lee_lhs you've removed the texture before rendering the characters?
  • 6r6r Posts: 463
    Yes, this way we can have a smooth color effect.
    On this Santa render you can see the use of Displacement (No Textures, Colors only !) ! Displacements are good for a better light/shadow effect.
    512 x 512 - 250K
    512 x 512 - 138K
    edited January 2015
    Yes, I removed the texture (I applied the grey base texture that comes with Genesis starter essentials).
    Then I changed the color, but I am pretty certain I'm still off with some settings.
    To change some of the UE settings, I had to select the light under "Posing".
    Here's the same render using 3DLight instead of GDL when rendering.
    1400 x 933 - 113K
    450 x 638 - 51K
  • 6r6r Posts: 463
    WOW ! Very impressive Minotaur...
    As a teacher it's interesting for me to know I gave you some informations (not the solution !) and you try to "win this challenge" !!! ;-)
    (I'm working with Daz Studio 3 because I need the great HandGrip plugin ! So I can't test with these characters !)
    Iìve asked because i've noticed some gradient on the minotaur skin, probably are created from the grey texture.
    6r say use your parameters, please :D
    Pretty please.
    edited January 2015
    Haha! Yes, I always was one who couldn't resist a challenge. And learning by doing always gets better results in regards to understanding the subject. Plus, it's time consuming; something not everyone has the luxury to do (or the patience).
    Though, can you hint me into the direction of how you get that impressive grey "dirtlike" shadowing done? The obvious solution would be using the distant light for the purpose, but once I use the shadow there (unless I render using 3DL), I get cute little squares there. :roll:
    No, I changed the diffuse color of the grey pre-set. The gradients are created by the use of the specular and glossyness settings, once the Infinite Light enters the picture.
    This are my test:
    First - without texture skin.
    1000 x 1000 - 100K
