How do I save a custom morph?
WillowRavenWillowRaven Posts: 2,959
I want to start fresh of my character in every aspect but her face. How do I save just a face morph and pose? I know how to export a pose by itself, but I want the orph, too. Just for the head, though.
Working in DS4.6.
  • VaskaniaVaskania Posts: 5,999
    edited June 2014
    Is this a character based on pure dial spins? If so, zero out any dial you don't want saved and go to File > Save As > Shaping Preset. Right click in the box and go to Check Only > Check All Modified Only (this is why you zero out the unwanted dials first, it makes things easier), and hit accept..
    Post edited by Vaskania on
  • WillowRavenWillowRaven Posts: 2,959
    edited June 2014
    I started with a freebie character that was close to the work I wanted then dialed from that point. So you are saying zero out the body dials?
    I can't get to the 'right click' step. Where is that?
    Post edited by WillowRaven on
    Yep. Zero out the body and save from there.
    OK ... So I'm basically saving the entire figure, with it saving the face the way I want it? What if I try to use that saved face on another character? Will it zero out any body morphs of the new character?
    edited June 2014
    It shouldn't. If you save any body dials in the preset while they're set at zero (ie having them checked in the save window), then it will zero out those dials when used, but if you zero them out first so they're not included when you 'Check All Modified Only', then the body dials won't be touched. The preset can only be used on characters of the same figure (ie if it's a Genesis-based character, it will only work on Genesis), unless you use GenX2 to transfer it.
    OK ... I'll give it a go :D
