Van Gogh's maid - mcjColorMyWorld's script
mCasualmCasual Posts: 4,607
edited May 2013 in Freebies
download here
https://sites.google.com/site/mcasualsdazscripts2/mcjcolormyworld
History:
May 2nd 2013 added Ambient Color option
April 14th 2012 corrected issue: script was trying to color more nodes than were in the selection list
April 13th 2012 release
NEW in this version, colorize the Ambient Color channel as well
while developing mcjPrimMaker i also quickly wrote a script to apply random colors to those primitives, and i'm giving it to you Smile
this easy:
Select one or many nodes in your scene
Click on the browse button and select an image on your hard disk
Click the "ColorMyWorld" Button
482 x 600 - 68K
622 x 622 - 82K
600 x 600 - 133K
600 x 600 - 118K
600 x 988 - 42K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited May 2013
    new in this version -- Ambient color channel colorization
    ( was added for the needs of mcjJet for lighted billboards )
    600 x 400 - 30K
    827 x 827 - 60K
  • MythmakerMythmaker Posts: 606
    edited September 2016
    Just discovered this script. Exactly what I wanted! Works with iRay too! Yeeeepeeee
    Some 'Curious Tea' cupcake & cookies gif render just for Jacques!
    Post edited by Mythmaker on
     Thanks, note that with matAnim you can turn on animatability of the color channels of a surface
    ( i'll test it to see if that's still true )
    though with Daz Studio 4, the material animations are lost when you exit Daz Studio they dont seem to be saved with the scene files
    so there's uhhh matAnimSave for that purpose https://sites.google.com/site/mcasualsdazscripts4/mcjanimatsave
    Thanks MCasual I have both matAnm and matanimsave and they work nicely in 4.9 and make my anim life so much more exciting!
    I haven't tried the material anim with mcjpropagate yet but I will soon. That one is so full of potential!
    I added the above cupcake video to Youtube so people looking for random color in DS could find them easier... smiley
    Hi MCasual, I was wondering if you had plans for matAnim to include the new dForce surface properties?  I was thinking it could be useful to increase the expansion ratio of an object to give it a little "inflation" at the end of the simulation (after it is constrained by another object, that is).
    edited May 2018
    maybe you could use mcjElevate, use a fully-White image as the elevation Map
    this has the effect of adding a morph that expands the object along the facet normals
    by painting parts of that image in black you can exclude part of the garment from expansion
    see below the pumpkin orange material being expanded
    800 x 800 - 123K
    800 x 800 - 367K
    That may work, if it is a morph, I can dial it in near the end, and the dynamics should respect it still.  I'll post back after a test!  Thanks for the idea!
    edited May 2018
    Your script worked great, thanks!  Unfortunately, it seems that I can't animate something if it is running a dForce modifier.  I earlier tried to animate the translation of it, but that did not work either.  I was hoping surfaces or morphs would.  Oh well, so even if matAnim affected those surfaces properties, I could not animate them either.
    Here is what I was working on:  https://www.daz3d.com/forums/discussion/comment/3647196/#Comment_3647196
    Post edited by 3dOutlaw on
    i did not try dForce yet actually ( yes that's odd )  but with the old Cloth Sim panel in Daz Studio there was a function accessible using t he right-top button menu of the panel to "freeze" the simulation
    without this, indeed, just touching a transclate/scale etc button destroyed the animation
    that's different, that's dynamics using my mcjElasticSim script
  • Richard HaseltineRichard Haseltine Posts: 111,342
    dForce does not drop the simulated state if the figure or garment is adjusted - only a new sim or using the Clear command will remove it. There is still a Freeze command so that a different item can be simmed.
  • RuphussRuphuss Posts: 2,631
    wheres the freeze command pls ?
    In the Parameters pane, under General>Simulation, with the object selected.
