Geometry Shell 1
Hi I have the package System 46 and I would like to know is possiable to convert Geometry Shell  to a prop please
If so all help would be much appreciated.
Best Regards
George
  • gcshepgcshep Posts: 28
    Forgot to add attachments showing the problem I am have first two are of DAZ the third is imported into iClone 3DXchange 7
    1920 x 1043 - 379K
    1916 x 1042 - 332K
  • The shell can't be converted to a prop as it needs to folow the chnaging shape of the base. You could try exporting as OBJ, then load and rig with the Transfer Utility, but I suspect you may be better off looking at the destination application to see what methods it offers for achieving a similar effect.
    Thank you Richard.
    I have attached a screen shot of the issue I have after exporting it as an FBX in to iClone 3DXchange.
    Thank you Richard.
  • The image isn't acceptable as it shows the nipples of the figure.
    It's possible that this is a bug - the shell is clearly exporting, just no longer correctly fitting the figure (but I don't know if it still adjusts for posing). You may want to file a bug report (open a Technical Suport ticket).
    thank you very much Richard for your help I have submitted a ticket to support.
    Best regards
    George
