Geometry Shell 1
gcshep
Hi I have the package System 46 and I would like to know is possiable to convert Geometry Shell to a prop please
If so all help would be much appreciated.
Best Regards
George
Best Regards
George
Forgot to add attachments showing the problem I am have first two are of DAZ the third is imported into iClone 3DXchange 7
The shell can't be converted to a prop as it needs to folow the chnaging shape of the base. You could try exporting as OBJ, then load and rig with the Transfer Utility, but I suspect you may be better off looking at the destination application to see what methods it offers for achieving a similar effect.
Thank you Richard.
I have attached a screen shot of the issue I have after exporting it as an FBX in to iClone 3DXchange.
Thank you Richard.
The image isn't acceptable as it shows the nipples of the figure.
It's possible that this is a bug - the shell is clearly exporting, just no longer correctly fitting the figure (but I don't know if it still adjusts for posing). You may want to file a bug report (open a Technical Suport ticket).
thank you very much Richard for your help I have submitted a ticket to support.
Best regards
George
