Bug issue with C8.5
Akulla3DAkulla3D Posts: 131
edited June 2012 in Carrara Discussion
So been playing with Gen in the new beta release see image below. A changed the ears to elf type and added aldoria hair, if you look closely the hair is raping around the ears. Is there a work around or is this something that is known issue or does it need to be reported as a bug.
640 x 528 - 115K
Post edited by Akulla3D on
  • fixmypcmikefixmypcmike Posts: 19,565
    Here's the solution for this problem in DAZ Studio -- I don't have C8.5 so I can't say if it's the same.
    When you apply a morph to Genesis a corresponding morph is created in the hair if the morph is set to autofollow. You need to display hidden morphs in the hair and dial back the auto-generated morph for the elf ears.
  • Akulla3DAkulla3D Posts: 131
    thx I will try and see if I can figure that out.
    Anyone know where to find the hidden morphs in Carrara as mentioned above. I went to vertex model area and found the morph but cant get it to change.
  • 3DAGE3DAGE Posts: 3,311
    I think the morphs for the hair should be accessed through the "Parameters" panel, instead of the Vertex modeller.
    I did find the other morphs mentioned above, but I could not change the parameter it was like disabled as far as being able to change it.
