batch rendering non-photorealistic avi's
UncleZeeUncleZee Posts: 20
edited December 2012 in Carrara Discussion
SORRY WRONG PLACE TO POST - cant find any way to delete.
Hi there
Is anybody else out there having problems rendering a batch of files to avi - if the files are using non-realistic (toon type) render mode. I got through one and then every other one I try crashed C8 and then when I reboot it looses all my setting for where my content is located!?
Then render fine outside the batch editor - but this is gonna seriously impact my work load having to wait for individual files to render.
Cheers
Z
Post edited by UncleZee on
  • UncleZeeUncleZee Posts: 20
    Hi there
    Cheers
    Z
    Where did you intend to post, I can move it there for you, or merge it with your post in the Carrara forum
    Post edited by Chohole on
    Hi there
    It was for the Carrara forum - I've already manually cut and pasted it there.
    Thanks for your help
    Z
    Hi there
    Cheers
    Z
  • evilproducerevilproducer Posts: 9,040
    Have you tried to render to image sequences? Also what version of C8? Is it the production build or the C8.5 beta? Might make a difference.
  • Richard HaseltineRichard Haseltine Posts: 96,888
    Moved to Carrara Discussions and threads merged.
    Hi there
    I'm using Carrara 8 8.1.1.12 on windows 7.
    They work fine when I render individual movies - but fail when I add them to the batch renderer
    Cheers
    Z
    Completely fail, or does the first one in the batch render and then Carrara crashes when it switches to the next one in the queue?
    Hi there
    It's completely fails. I only ever managed to render one. Even that same one doesn't work. When it loads the files, the render info doesn't appear correctly - all I see is the default for 'diffuse' - all the other panels are empty.
    Z
