YELLOW FRAMEWORK
I may have covered this in a tutorial, but I cannot remember.   The yellow transparent framework- or...whatever it is called- that appears when I move the cursor around...
...can I turn it on and off?  At times, it interferes with the work I'm doing.
  • Richard HaseltineRichard Haseltine Posts: 111,325
    edited February 2017
    In the Draw Settings pane set Node Highlighting to Bounding Box Only.
  • dash2128dash2128 Posts: 736
    THANKS!!!!!!!!!!!!!
  • ed3Ded3D Posts: 2,639
    _also _thanks_``~...
  • magicweavermagicweaver Posts: 256
    edited May 2019
    Thank You Richard, as always THE digital magicman *hugs* wouldn't know what to do without you...(edited) works for DS 4.11 as well ;)
    Post edited by magicweaver on
