Carrara Challenge #22: “Wild, Wild West” - WIP Thread
123457»
  • chickenmanchickenman Posts: 1,202
    edited February 2016
    Played some more with it.
    Two Pipe smokers and a disgruntled poker player, created the deck of cards, removed poke through and added smoke from pipes as well as modified the other smoke.
    1900 x 1682 - 2M
    Post edited by chickenman on
  • wgdjohnwgdjohn Posts: 2,634
    MistyMist said:
    doesn't look like there are bars for the windows. band on the run.
    if i'd a test rendered this first, would've modeled bars instead of the deputy badge.
    should be fairly painless to add a few cylinders.
    I'd think that you could model a single bar, cylinder, and just replicate or duplicate for the others.
  • StezzaStezza Posts: 9,212
    you missed some pokethru on the dude on the left with his jacket bottom ;-)
  • bighbigh Posts: 8,147
    and you should move the ducks hand down to the drink
    then I would say its a wrap
  • 3DAGE3DAGE Posts: 3,315
    Hi Chickenman  :)
    try a volumetric fog in that scene ,. make it's bounding box cover the whole building so that the main cloud is inside,. if you adjust the density it should give you some smokey atmosphere,.
    I also agree with Big H on the hand of the chickenman ,. maybe holding the bottle pouring a drink.
    Nice
    The smoke clouds in the picture are already volumetric clouds including the smoke from the two pipes. I will play with them some more to see hat i get.
    Thanks for the suggestion for Chickenman, I was thinking of doing something with his hands as right now they look out of place.
    Thanks for pointing out the lat bit of Poke through.
    Still need to figure out why the 3 drinks on the bar are glowing as they are duplicates of the others so they should iliminate the same. I wonder if it is the position of the lighting?
    Primoval Fog is an option found underneath Clouds. Oops... just realized that this is part of "Advance Pack" from inagoni which is available from DAZ... see http://www.daz3d.com/advance-pack it is quite a handy add-on.
    Post edited by wgdjohn on
    wahh the time pressure. working tomorrow, haz to finish render today.  still deciding what MsSheriff should wear
    I have that too/
    Clothes not a bikini
  • de3ande3an Posts: 915
    Stezza said:
    the next challenge should be all about that wonderfull white winged warrior that graced our radio stations way back when.....
    bring back Benton Harbor smiley
    You mean The Feathered Fighter, The Fantastic Fowl, The Crusading Capon?  laugh
    He's everywhere, he's everywhere!
    Here is the next test render.
    Just got to work on the glowing shot glasses on the bar.
    Narrowed it down to the shader on the glass not the cylendar in side.
    I played with the Volume cloud I had and got a better result than before and the smoke from the pipe smokers is ok I think.
    1900 x 1682 - 2M
  • HeadwaxHeadwax Posts: 10,562
    nice work chickenman really enjoying the progress of tis image
    here's some wip from me finished image, one with no post and car setup and image cropped
    2000 x 2000 - 819K
    2000 x 2000 - 839K
    1129 x 941 - 361K
    1655 x 1734 - 682K
    Post edited by Headwax on
    Here is the final render I think.
    There is also the setup foor the smoke and the scene setup.
    1900 x 1682 - 2M
    1280 x 984 - 356K
    1280 x 984 - 197K
    render buckets keep sticking over the lanterns. not even up to millenium puppy fur yet
    both render buckets still on the fur, letting it render over night, gotta get up in 6 hours.
    all the banditos ecaped out the windows, sheriff headed out with a posse, buppy is all alone guarding the jail.
    has nice beds for an ow jail.
    Post edited by Mistara on
    yep, the most fantastic crime fighter the world has ever known blush
    Sigh, so close, yet so far.
    1300 x 772 - 203K
    Here is the assemble room for my final image.  Note that the smoke objects have explode modifier and blur effect applied.  I have also posted the mesh of the Yul Brynner style Quaker/Robot with a circuit board face.
    1600 x 909 - 348K
    877 x 880 - 79K
    640 x 480 - 13K
    Post edited by Diomede on
    deadline is tnite?  mebbe can finish another render
    those jail windows need bars, or the banditos will keep escaping.
    Support your local sheriff.  Put some drops of red paint on the floor.
    560 x 304 - 21K
    Gunsmoke?
    the Lorne Green one? Commander Adama.
