hi does anyone know how to get the skin like this shiny and oily
lasagnamanlasagnaman Posts: 1,001
hi can someone help me asap ty
1100 x 1250 - 758K
  • xyer0xyer0 Posts: 6,515
     Try lowering the Glossy Roughness and/or Top Coat Rougness (in Surfaces tab [Iray]) below .20 until you get the effect you want.
  • AlienRendersAlienRenders Posts: 807
    You could try this (select the "Skin" surfaces):
    Metallic Flakes Weight: 0.05
    Metallic Flakes Roughness: .45 (Play with this setting. Lower is shinier)
    Metallic Flakes Size: 0.01
    Metallic Flakes Strength: 0.5
    Metallic Flakes Thin Film: 10000
    Metallic Flakes Thin Film IOR: 1.0
    Other metallic flakes settings at default.
  • RobotHeadArtRobotHeadArt Posts: 917
    You can turn off limits and increase the glossy layered weight and the top coat weight values.  The values to use would depend on the light and the other parameters on the skin.  You could try increasing these numbers in integer increments until you get the desired look.
    V3Digitimes's Iray Converter products include a set of gloss management scripts that give you an easy way of tuning the gloss on skin/lips/nails as well.
  • ChangelingChickChangelingChick Posts: 3,448
    That looks like a high top coat weight with a low roughness on it.
  • 3Diva3Diva Posts: 12,058
    You might try tweaking the "Glossy Layered Weight", "Glossy Specular" color, and "Glossiness" to see if that gives you the look you want BEFORE resorting to messing with the "Metallic Flakes Weight". Increasing the Metallic Flakes Weight will often increase your render time by like 200%.
  • kaotkblisskaotkbliss Posts: 2,918
    I usually just add a geoshell, apply the iray uber base, then apply the iray water preset.
    Not the best way, but it works
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,845
    edited June 2016
    I'm liking this product http://www.daz3d.com/hdri-optimized-skin-hair-shaders -one of the promo pics shows model not using product then with with light, medium and high settingsimage
    this is link to forum on it and posted couple of my pics too  http://www.daz3d.com/forums/discussion/95716/released-hdri-optimized-skin-hair-shaders-commercial#latest
    Post edited by Chohole on
