Ribbon Fingers
I know I've read it somewhere else about fixing ribbon fingers, and thought, "okay that's easy", but now I can't remember.
It usually happens when I use "Growing Up" or down in this case, and as they reduce in size the fingers become flat and deformed.
I would be obliged if someone could remind me of the answer to this, as it is driving me crazing, having to correct each finger in turn!
Many Thanks
Gray
  • Richard HaseltineRichard Haseltine Posts: 111,842
    What do you mean? Is the mesh getting compressed even before posing, or is this the issue with bends stretching the mesh out weirdly? The latter should not be an issue with purchased morph sets as the bones have beena djusted to work with them - unless you are spawning new morphs rather than using them directly.
  • Okay. Whilst preparing some pictures to show how a G3F, when reduced in age, either by using "Growing up", or the Youth Slider, created deformed ribbon like fingers, I accidentally found the answer. If I save the image as is, with the fault, when I reload it the fault is gone!!  yes
    So that seems to be the answer I think.
    Thanks for your interest
    Gray
