SkyDome has grid lines
Jay Jay_1264499Jay Jay_1264499 Posts: 298
Morning, I wonder if someone can help. I was playing around with StoneMason's sky dome from the Enchanted Forest set and put it over a scene I was working on. I then went into the surfaces tab for the dome and changed the background PIC to an hdri image I made in Vue. Rendered great but I can see grid lines from the dome on my sky. Changed to a normal JPEG (non hdri) and got the same results. Has anyone got any ideas on what is causing this?. Thanks to anyone who can assist
Post edited by Jay Jay_1264499 on
  • Forgot to mention, in rendering in 3DLight not Iray!
  • barbultbarbult Posts: 27,495
    Try applying subdivision to the dome. Select the dome in the Scene pane. Then use the context menu Edit->Geometry>Convert to SubD...
    You can find some other hints here.
  • Awesome I'll give that a try. Thank you barbult
  • Roman_K2Roman_K2 Posts: 1,277
    !  I too have seen this happen and I thought it was "just me", thanks.
  • Yep applying SubD to it did the trick! Thank you
    Great to hear that you got it worked out! Thanks for replying with the good news.
  • You're welcome. Thanks again for your quick reply yesterday
  • SzarkSzark Posts: 10,634
    In 3DL this can also happen if the render settings Shading Rate is too high, lowering it will fix it most times without having to Sub-D anything
  • Ah interesting. I'll have to check those settings out. Thanks Szark
  • algovincianalgovincian Posts: 2,696
    This can also happen if rendering using ambient occlusion in 3DL. There is a "bias" parameter that can be adjusted which can help get rid of it without subdivision.
    - Greg
  • I didn't check the ambient occlusion settings so thanks for the tip algovincian. Also tested with just using a sphere and adding a Vue hdri image to it. Changed some settings and it worked even better! Thanks for your help all.
