Victoria 4.2 installation through DIM
tried to load a fresh V 4.2 in daz 4.8
message : cannot find support folder
deinstalled and reinstalled through dim:
does not work
installed it manually:
works
flaw in dim ?
all other installations through dim are working
    Installs fine with DIM, you did something wrong.  Does other content install correct through DIM for you?  What is the Install path used in DIM?  Does the DIM install path match a library path in Studio's Content Director Manager?
  • Exactly which packages did you isntall via DIM?
  • RuphussRuphuss Posts: 2,631
    "all other installations through dim are working"
    Victoria 4.2 base
  • fixmypcmikefixmypcmike Posts: 19,692
    Do you have the location you installed to listed as a Poser-format content folder in DAZ Studio?  Are you using the default location?
    1. yes
    2. do i have to ? if this is the cause is this only for V4 stuff ?
    No, but you do have to place the base and all morph packs in the same content directory.
    why doesnt dim do that ?
    this is all about dim
    as i said already manually downloading and installing no problem
  • IceCrMnIceCrMn Posts: 2,322
    He maybe on to something.I installed the PC+ megapac that is currently free for PC+ members.The steamboat installed through DIM put itself in a subfolder called content.
    1928 x 1036 - 263K
  • Please report items that DIM places in the wrong folder by opening a support ticket.
  • JGreenleesJGreenlees Posts: 2,249
    the steamboat machine has been updated with ds4.8 files and will be up in the next few days.
  • jag11jag11 Posts: 885
    does not work
    works
    flaw in dim ?
    I had the same problem yesterday, I fixed it by adding an entry in the Content Directory Manager under Poser Formats. My content is installed on D: drive.
    THsis is known to affect some people if anything goes wrong with their content settings; the DAZ|Studio Formats and Poser Formats sections of the Content Directory Manager must both point to the same folders. DIM and DAZ|Studio do not talk to each other, so any problem must be noticed and fixed manually by checking the settings in both programs.
    ok found the reason
    my DIM reseted the installation path to default which i do not use normally
    i have one special folder for all content coming from DIM
    then i build my categories from there
    now the question again
    are there files that need to be installed to default download folder ?
    No, you aren't required to use the default location
    thank you mike
  • IceDragonArtIceDragonArt Posts: 12,809
    FYI I did finally have to load the Base for v4 manually.  The installer loaded the skins but I had to the base and morph++'s manually
