Painter's Lights
XenomorphineXenomorphine Posts: 2,421
If anyone has this...
http://www.daz3d.com/painter-s-lights
What's meant by 'Sun Sky Dial Environment Presets'? Is this aspect 3Delight-compatible or exclusively for Iray renderings?
I'm tempted to get it for when I do start Iray stuff (which won't be until I can afford certain shaders for it), because it appears to be able to produce a night-like effect, but I'm curious as to what the above means. Right now, I'm staying with 3Delight, because it's what I know.
«1
  • BeeMKayBeeMKay Posts: 7,019
    edited June 2015
    The lights presets are Iray only; the Sun-Sky-Dial is a helper to control the direction of the sunlight.
    Though, you don't need special shaders to render in Iray; DS does auto-converting pretty good, and it comes with a good starting collection of shaders.
    Post edited by BeeMKay on
  • XenomorphineXenomorphine Posts: 2,421
    Ah, useful... Thanks!
    From what I've seen, using existing 3Delight-era shaders is a bit hit-or-miss in Iray and there are certain effects I need to reproduce for some art projects. It's like when I had to take the plunge and upgrade all my Genesis morphs to Genesis 2 standard!
    Well, you can get good results with the existing shaders; for example, for the leather boots, I apply the standard leather shader, kicked out the diffuse&gloss; maps, increased the bump, removed the normal maps, and changed the color from brown to near black. Then all it needed was to adjust the glossy roughness so you don't get sparkled to death. ;-)
    But of course, if you are using this for business, it's a lot of time tinkering around with the materials to make it look perfect; a shader preset would certainly save a lot of that time.
    Not quite business, no. But Iray doesn't yet have any equivalent shaders for, say, Marshian's one for creating underwater relics.
    And I'd still like someone to produce sell a small set of some user-friendly one-click night/outer space backgrounds for it. :) There are some work-arounds, but it would be very desirable to have the same kind of functionality we have with 3Delight skydomes, like Digivault's excellent stardomes.
  • RedzRedz Posts: 1,459
    So these are iray lights? I looked at the product and it seemed great, but nowhere did it say iray (either in the promo images or in the description) It's listed as Daz 4.7 compatible, so I assumed it's for 3delight. Can somebody clarify this? Thanks
    edited June 2015
    It's in the product's description, Iray only.
    The 4.7 is not really a reliable value, but the details usually are.
    1548 x 664 - 128K
  • frank0314frank0314 Posts: 15,109
    You can check the readme and see if it says anything there. If installing manually, just go to the product page and look up the sku jsut under hte price and go here. If your installing with DIM then click on the "i" next to the product and it will take you directly to the readme.
    712 x 720 - 88K
    Thanks for the info. I've bought the lights and they are a lovely set.
    Iray wasn't stated in the description, so I wasn't sure. I think that may just have been an oversight.
    As to checking the read me, that's all very well, but I assume I'd have to buy the product in order to see it in the DIM, and I wasn't going to buy unless it was iray.
    Glad I read this - I was unaware they were iray lights also. I glossed over the "iray" bit in "DAZ Studio Iray Material Presets (.DUF)" - I only really noticed the 'daz studio" and the 'duf' bit.
    Yeah, products really need to state something like 'Iray-only'. Otherwise, it's easy to think it just means they're also for Iray, considering 3Delight is the default most people switch to.
    Hope this means Daz isn't going to stop paying the licence/whatever for 3Delight... Would be a shame to find a new update no longer uses it, making all those 3Delight-specific models and shaders suddenly unable to be used! :)
  • IppotamusIppotamus Posts: 1,580
    edited June 2015
    This is just a great set.
    I bought them thinking they were 3Delight. But was happily surprised to see they were actually Iray. :)
    But the PA/Daz might want to put some big Iray stickers on the promo/product page.
    Or mention it in the description.
    I know a lot of people are hungry and looking for Iray products.
    Post edited by Ippotamus on
    In one of the other 4.8 threads, one of the dev team mentioned they just re-upped 3DL, so it's not going anywhere...anytime soon. (If I remember, they used to do a multi-year deal on 3DL...)
    Interesting to know! Wonder how many years that's meant to be.
    There are still some things you can only really do with that rendering option, like motion-blur and such.
    The how long...that was a post on the old forums, so it's lost to the mists of time...and the re-up, that's in either one of the early beta thread or one of the early parts of the release version thread.
    No, you can read the Readmes online here: http://docs.daz3d.com/doku.php/public/read_me/index/start
    'Just check the Product index nmber from the sales page, and click on the number range on the left side, then you can select it from the listing. Very useful page, one I have bookmarked straight away. :-)
  • SpitSpit Posts: 2,342
    It's all well and good to tell people in the forums how to know for sure this product is iRay only. It should state that as fact IN THE PRODUCT DESCRIPTION. The customer shouldn't have to work so hard to know.
    And that Studio 4.7 requirement is very very misleading as well. Neither is it enough to mention in the forums that it's not reliable. It should be changed in the product description.
    Yes. I'm annoyed. I visit the forums frequently, many don't.
  • KhoryKhory Posts: 3,854
    It makes me a bit sad to see that people are trying to focus on a minor (yes really it is) error rather than what a stunning product this is. Especially when the product is by a brand new PA who has never had to jump any of the many hurdles that crop up with submissions. I doubt J.Cade had access to the watermarks as a first time PA and those might have alleviated the issue. The 4.7 instead of 4.8 is akin to writing the wrong year on January 5th of the new one. I think its a lovely set of lights with amazing promos and needs to be treated more like that than an excuse to be vexed about something.
  • MuireanneMuireanne Posts: 82
    These lights have really tempted me to give Iray a try, despite the fact I have a AMD.
  • BarubaryBarubary Posts: 1,233
    edited June 2015
    It's a mistake that can render the entire purchase useless.
    And it's OK for a first time vendor to make a mistake like this, if we even wanna call it that. But one would think someone at least double-checked the product description before uploading it to the store.
    And yet, most of the comments in this thread seem to be in rather good spirit, and some contain quite a few compliments. I really don't see the problem.
    Personally, I find it sad, that a PA feels offended when people so much as inquire about whether or not they can actually use a product instead of just showering it with praise (no matter how well deserved that praise may be).
    Post edited by Barubary on
  • scorpioscorpio Posts: 8,533
    Unfortunately this isn't the only Iray product that has 4.7 as the DS version on the product page.
    I don't know if these also work with 43Delight but I would feel that they don't.
    http://www.daz3d.com/aged-leathers-for-iray
    http://www.daz3d.com/iray-shaders-glass
    http://www.daz3d.com/refracted-iray-glass-presets
    These are just 3 I found I think someone somewhere needs to look at what is going on with the product pages.
    1310 x 464 - 101K
    Even new releases which are because of the punch sale not eligible for returns
    http://www.daz3d.com/expeditionary-force
    My ability to sympathize with someone has nothing to do with my profession and certainly predates my taking up 3d. Nor did I say I was offended. Disappointed perhaps. I simply want people to lighten on someone who is new. I would feel the same way about being kind to people just starting out with something no matter what industry they were in. Especially when much of what is being discussed would not be something that the PA (in this case) was really responsible for doing.
    Unfortunately this isn’t the only Iray product that has 4.7 as the DS version on the product page.
    I don’t know if these also work with 43Delight but I would feel that they don’t.
    I suspect that they were set that way because when they were submitted there was no 4.8. It is possible that because the products were submitted before the version was live that they didn't have the 4.8 option added to what ever form gets filled out when the pages are set up. I know the only requirement I put on any of my Iray products was Iraydium. None the less I have contacted QA to see about getting all the 4.7s changed to 4.8.
    For the time being at least, I think also that it might be best for people to assume that things like lights and shaders/presets are more likely for the default engine (Iray) rather than 3dl since that is by far the largest hole that needs filling.
    First I didn't criticize anyone specifically. My assumption is that DAZ, as part of the process, vets the product pages. I'm probably wrong in my assumptions but that only means there's something lacking in the process, not the people involved. But whatever the reasons for the lack of clarity, there is a lack of clarity and that is important because the majority of customers don't participate in the forums.
    That it is a fine product is a separate matter and one does not preclude the other.
    I appreciate you dropping by and giving the PA point of view since it adds perspective and information to the conversation. But we are still allowed to criticize when an issue pops up are we not?
  • Richard HaseltineRichard Haseltine Posts: 111,473
    The DS version text should now be 4.8 instead of 4.7
    Man, I was so cut up about that being Iray-only... They were just the type of colour schemes I was hoping someone would do for that costume!
    I'll probably get them when I do start switching over to Iray, but it's still a shame I can't use them in any scenes with 3Delight-specific shaders in them.
    First I didn’t criticize anyone specifically.
    The thing is that the title of the thread is "Painter's lights" not "DAZ can we get more clarity about what is and is not Iray". Yes the question was initially about the lights and clarification but the reality is that the product name is going forward on the thread and because of that it reflects on the product even though the thread is only tentatively related to it. People who do a search to find out about the product will end up here and not only are they not really going to find out about the product but they are going to find a bunch of criticism in a thread they expected to be about the product.
    I'm sure they do. But we can't afford robots yet so humans still do all the work and it is a boat load of work even at normal times. Iray introduction was not normal times by any stretch of the imagination.
    I submitted my first Iray product on May 4th and was one of the first ones to do so. Keep in mind that we were still in beta when those products finished QA. During testing there were things to iron out that would not normally have had to happen. In other words, after we submitted there were more changes to the program that we had to correct for. You almost never have that regularly. It added work not just for us but even more work per product for QA.
    I know that the day my product was going through review there were no less than 4 other people who had Iray products submitted that day (and yes that is a large volume of submissions based on the volume of PA's I know). Nor was it business as usual for any of the QA team. QA would also have been flooded with testing new products with new testing parameters for a new default render engine. All the new rules had to be done on the fly because even though testing started for a glut of Iray products there were other non iray products going through testing at the same time. There was no breathing space in there for them to get ready for Iray or any extra time added to days to make up for all the "new" that was going on. Now that I think about it it is pretty amazing that things went as smoothly as they have.
    Nor would the page building have been normal because they were trying to set up pages for an unreleased version of the program. Most products for the last couple of years are compatible with pretty much any version of studio 4. If the code guys didn't get the page system sorted before the product goes live it wasn't a big deal most of the time. And they were working like mad to get the program ready for live so it may not have been a top priority. Compared to getting stuff to work I would expect sort of hope it was down the list a bit. The reality is that everyone in nearly every area has been working at a break neck speed for months to get everything sorted.
    Could things have gone smoother with the naming and the way the types of files are listed or the version of the program? Sure. Personally I am a bit ocd so all my products have the word Iray in them because I wanted everyone to know at a glance I was on board with Iray. Actually, If I thought it would do any good I would get on top of the house and start screaming "Get your Iray here" but that is mostly just because I am excited about it. Considering how many other things were happening at the same time and had to be dealt with the fact that they didn't sort out stronger ways to point people at Iray on some pages is relatively minor compared to some of the stuff that might have gone wrong.
    I'm sure your thinking... Yes but that was weeks ago so no doubt they have had some down time to go back and find they made errors and sort those out. Not so much. Trust me when I say that if anything QA is even more swamped now than they were two months ago. This is not a summer where the PA's are taking a few weeks off to go to the beach. And when we work hard QA ends up working harder. I've alerted them to the need to change the 4.7 and I hope it will be a quick fix because they need to get back to the salt mine and work on products.
    I’m probably wrong in my assumptions but that only means there’s something lacking in the process, not the people involved. But whatever the reasons for the lack of clarity, there is a lack of clarity and that is important because the majority of customers don’t participate in the forums.
    I don't disagree that things could have gone smoother or be more clear in some cases. But with many things you can only predict other peoples needs so much. And it is even harder to try to be that predictive sort of person when your also being pulled by half a dozen things that have to be dealt with asap if not yesterday. To be honest, if I we were going on my personal view point/needs the assumption would always be that the product is Iray and that notification only needs to be made if there is additional 3dl support. Iray is the default render engine now and while I am sure at some point I will be doing 3dl support for some things my purchases are all Iray oriented right now. So that is my mindset at the moment. One quirk of human nature is that people always believe that what they need/want at the moment is exactly what everyone else needs/wants at that moment. That may have been true about power rangers toys at Christmas and english 101 when your a freshman but it is not true about many other thing in life. Clearly not everyone else needs to only know it will work with Iray. Working out a middle ground that fully informs everyone about what they need to know turned out to be a work in progress as far as Iray and 3dl.
    Yes, of course. I guess I am someone who sees criticizing others as more a last resort than a first recourse. I know it is pretty much the common methodology in this industry for some reason but there are days I still balk at it. I'm still a big fan of honey before vinegar.
    edited June 2015
    In the midst of all this discussion I assume that you did all see Richards comment here http://www.daz3d.com/forums/discussion/57732/P15/#840836 , just a couple of posts up ^^^
    The problem was reported by the Forum team, and has now been sorted out. SO now the thread can go back on topic.
    Post edited by Chohole on
  • SuperdogSuperdog Posts: 765
    edited June 2015
    If the product actually has the word "IRAY" in the title then it's a safe bet it's for IRAY. Confusion arises when a product has both IRAY and 3DR shaders. I wish this was spelt out more clearly sometimes. Lovely light set by the way.
    Regarding past G2 products - will they be updated at some point with IRAY shaders? DS does a good job with converting shaders for IRAY but it would be great to have specific IRAY shaders for past G2 products as they generally look better and render faster. Are DAZ and the PA's working on this or is the policy to include IRAY shaders from 4.8 onwards?
    Post edited by Superdog on
