Save Pose Preset script Question
DraagonStorm
The documentation at Save Pose Preset shows setting up for nodes (xrotation, yrotation, zrotation), but what about Pose Controls? These values are not saved using this sample.
Strangely I was *just* playing with this.
The DzFileIoSettings ends up wanting a list of the names of all Nodes and Properties underneath the node getting saved.
What I did was replace the lines that create the "hard-coded" arrays of the nodes/properties to iterate all child nodes and store the node and property names.
Basically:
Then, alter the code that is setting the values in the settings file to refer the node names and properties just staged:
Hopefully this should put you on the right track. I'd appreciate you letting me know if you see any mistakes here.
(I just wrote a script to save pose presets for every object in the scene.)
