READY - Rendering daz studio scenes as skyballs ( equirectangular / spherical images )
mCasualmCasual Posts: 4,607
edited July 2015 in Freebies
https://sites.google.com/site/mcasualsdazscripts5/mcjsphericalcam
( if you downloaded the script on July 2 before 9 am eastern,
you may have the version that will fail the stretcher.bat phase
so get the new one that was posted a few minutes later )
the script animates your camera, over, say, 72 frames
you render those 72 frames
this render covered the entire environment sphere
then using the script, the mcjSqueeze and imagemagick utilities, it assembles a mosaic/panorama
You then apply this as the texture on giant spheres and you get great fake backdrops/lighting for your scenes !
i added a few skyBall props as obj files, to be imported using Daz Preset ( scale = 100% )
those spheres have a 1 Km radius
their normals and UV mapings are ready for equirectangular panoramas
this is from the initial posting
it gives a good idea of the way the camera is animated
var cam = Scene.getSelectedNode( 0 );
var xr = cam.getXRotControl();
var yr = cam.getYRotControl();
for( var y = 0; y < 6; y++ )
 var XRotAng = 75 - y * 30
 for( var x = 0; x < 12; x++ )
  var YRotAng = x * 30;
  Scene.setFrame( y * 12 + x )
  xr.setValue(XRotAng);
  yr.setValue(YRotAng);
512 x 512 - 40K
1280 x 720 - 146K
512 x 1537 - 70K
333 x 2000 - 54K
1356 x 690 - 204K
Post edited by mCasual on
«134
    Sweet...
    And if you rinse and repeat a couple of times, changing the 'exposure value' up/down, you can then run the results through something like Picturenaut ( http://www.hdrlabs.com/picturenaut/index.html ) and create your own HDRI...
  • mCasualmCasual Posts: 4,607
    mjc1016 said:
    Sweet...
    thanks i didn't look much into HDR software
    here's the first result
    72 512x512 daz studio renders, deformed by imagemagick and assembled by imagemagick
    the top row of image tiles seems to be mistreated by imagemagick
    and there's problematic stitchings
    but s'not all bad
    2000 x 1000 - 348K
    Basically all an HDRI is, is a series of underexposed and overexposed versions of the same image stacked in a way that preserves the full dynamic range of the 'real' scene.. This is then usable as light source for rendering because it has 'real' minimum/maximum values...and in the best ones, a bit beyond what our eyes can actually see...and all the color and shadow information at the time the original shot was taken.
    inside mcjCastle
    hardware render ... so the lighting is ... well openGL'ish maybe if i turn specular off
    2000 x 1000 - 203K
    edited June 2015
    still in mcjCastle but someone stole the ceilings and floors
    fig 2 - applied on an environment sphere
    even with a 6000x3000 resolution, since it covers a 360 degrees panorama, it's a bit blurry
    512 x 512 - 145K
    2000 x 1000 - 255K
    edited June 2015
    so .... friday
    because i want to figure if it's inevitable or not that the image has cracks ( or bad photo stitchings if you will )
    well actually i suspect it's because my camera's Field of view is not precisely 30 degrees ) when the focal length is 65 mm
    i think it may be 45 degrees when it's 35mm ... i have a long study of the matter .... in the old forum i guess
    to quote myself
    "about the focal lengths - in Daz Studio the focal length is relative to the vertical aperture of the camera for a backplate 35 mm tall"
    so tan( fov / 2 ) = 17.5mm / 65mm
    fov/2 = arctan( 17.5mm / 65mm ) = 15.0684882 degrees
    so FOV = 30.1369763 degrees degrees
    there you have it,
    not 30 degrees
    hence the cracks
    tan(15 degrees) = 0.26794919243
    17.5mm / 0.26794919243 = 65.3108891 millimeters
    we set the camera Focal length at 65.3108891 mm
    well .... that's not quite it yet
    ( the 3d scene in this case is a 100 meters 24x24x24 Cube centered at 0,0,0 )
    Fig 2 - when applied on a sphere it looks perfect!!!!!!
    see that's amy 100 metes down and away seen from the center of the cube ... oops, that's the real cube, not the sphere :D
    Fig 3 - uhhhh that's not as glorious as Fig 2 :|
    1080 x 1080 - 596K
    1080 x 1080 - 666K
    2000 x 1000 - 553K
    edited June 2015
    ONE LAST TRY FOR NOW ...
    must be because we're dealing with curved trapezes
    2000 x 1000 - 474K
  • EsemwyEsemwy Posts: 578
    Cool. Overlapping the frames by a bit and using the pano tools in Photoshop or the Gimp would likely get rid of the seams.
    edited June 2015
    i think i saw the word "spline" mentioned in the imagemagick deform manual so maybe i'll be able to use it
    instead of the (un)Perspective types of effects
    else i'll write an exe or daz script or something
    there's 18000000 pixels to process so i will need a fast solution
    i never tested the speed of javascript vs daz scripts
    maybe daz script could do it in a minute or 2
    interesting ( and sad )
    processing 512x512 pixels using a script, 1 multiplication and 1 division
    Daz Studio 1.8 - a bit more than 4 seconds
    Daz Studio 2.3 - a bit less than 4 seconds
    Daz Studio 3 - 15 to 18 seconds
    Daz Studio 4.8 32 bit - about 26 seconds
    Daz Studio 4.7, 4.8 64 bit - about 28 seconds
    since i have 72 tiles to process .... it's out of the question
    mcjSqueeze.exe does it in a fraction of a second but will only support uncompressed bmp and tga files
    800 x 800 - 25K
    edited June 2015
    OOPS
    Fig 1 contrary to what i was saying
    they ARE straight-edged trapezes
    Fig 2
    but the proper focal length for 30 degrees slices seems to be almost 68 mm
    Fig3
    OOPS AGAIN
    they ARE NOT straight-edged trapezes
    horizontaledgey speaking
    Fig4 nah s'ok to treat them as straight edged trapezes ( more facets would yield less distorsion )
    but i must get the complete trapezes ... and i dont quite have that yet
    Fig 6 hmm still not quite figured it
    all of this seems fine
    aspectRatio )     // 1
    farClippingPlane )  // 412805
    focalDistance )    // 360
    focalLength )     // 65.3108901977539
    nearClippingPlane ) // 5
    type )         // 6
    getFieldOfView () ) // 30.0000008348
    1728 x 842 - 109K
    904 x 717 - 28K
    744 x 734 - 80K
    740 x 736 - 78K
    736 x 712 - 133K
    edited June 2015
    see that?
    as the vertical angle of the camera changes, the same horizontal segment's width changes
    which is not what the 3d simulator in my head was predicting
    a 5 Km diameter sphere
    whatever the diameter, the middle of the vertical edges are closer than the corner vertices
    but the segment doesn't move, the camera doesn't change position .... the camera just rotates ... so what the...
    600 x 600 - 191K
    Casual said:
    see that?
    I had to split the gif and load it as layers in Photoshop before I could see it, but sure enough.
    Maybe the camera doesn't rotate around it's entrance pupil (often mistakenly called the nodal point)? It sure looks like parallax error.
    I can't even imagine why that would be the case, but it's the effect you get in real photography when taking panoramas and the entrance pupil of the camera lens isn't centered over the tripod or within its elevation cradle.
    http://www.vrphotography.com/data/pages/techtutorials/technotes/nodalptalign-tn.html
    http://www.johnhpanos.com/epcalib.htm
    edited June 2015
    there's the explanation,
    if we wanted the sphere-vertex pointed to by the orange arrow
    to stay on the right-side-wall of the pyramid ( aka view frustum )
    we'd have to rotate it around an axis perpendicular to the blue line
    but that's not what we have
    we have the camera/pyramid rotating around an axis perpendicular to the green line
    so what i'll do is, i'll mathematically render the vertices of each one of the sphere facets
    make sure they are in the daz studio rendered images
    and use that to cut out the rendered image
    then i stretch it to fit a square-tile
    code for the camera animation, 12 x 6 renders 360 degrees by 180 degrees
    animateCam();
    function animateCam()
     var HSlices = 12;
     var VSlices = HSlices / 2;
     var StepAngle = 360 / HSlices;
     // 30 degrees when we have 12 HSlices
     var TopAngle = 90 - StepAngle / 2;
     // 75 degreeswhen we have 12 HSlices
     var cam = Scene.getPrimarySelection();
     if( !cam )
      return;
     for( var y = 0; y < VSlices; y++ )
      var XRotAng = TopAngle - y * StepAngle
      for( var x = 0; x < HSlices; x++ )
       var YRotAng = x * StepAngle;
       Scene.setFrame( y * HSlices + x )
       xr.setValue( XRotAng );
       yr.setValue( -YRotAng );
    734 x 732 - 92K
    edited June 2015
    code to "render" the world position of a ball named ball
    as seen from a camera named cam
    which is located at (0,0,0)
    only for square renders
    rendered .... meaning ... a pixel coordinate
    it's interesting to note that
    when you have a camera at 0,0,0 pointing along the Z axis
    "rendering" vertices is simply a matter of scaling the X and Y coordinates of those vertices by a number proportional to their Z coordinate
    var resolution = 512
    var cam = Scene.findNodeByLabel( "cam" );
    var ball = Scene.findNodeByLabel( "ball" );
    var p = ball.getWSPos();
    var rot = cam.getWSRot();
    rot.invert();
    p = rot.multVec( p );
    p.normalize()
    focallength = cam.focalLength
    backplate = cam.frameWidth
    scaler = -focallength / p.z
    p.x *= scaler
    p.y *= scaler
    p.z *= scaler
    p.x /= backplate
    p.y /= backplate
    var halfrez = resolution/2
    p.x *= resolution
    p.y *= resolution
    p.x += halfrez
    p.y += halfrez
    debug( p.x, p.y );
  • WandererWanderer Posts: 957
    mjc1016 said:
    Sweet...
    And once again, thanks!
    edited June 2015
    markers for the tile image corners
    512 x 384 - 1M
    edited June 2015
    using a 60mm lens we get each sky slice in the render frame
    the script knows how to compute the rendered pixel positions of the triangle/trapeze windows
    stretching those cutouts will be done either by imagemagick or by an exe of mine
    let's see .... pixel coordinates for the first triangle-trapeze
    px0 256 491
    px1 256 491
    px2 138 35
    px3 374 35
    hmm that does make sense
    1920 x 1080 - 79K
    TADA !
    i think i just have to tell imagemagick to work harder on the poles of the sphere
    2000 x 1000 - 326K
    edited June 2015
    TADA Squared !
    using imagemagick to deform the rendered tiles
    BilinearReverse instead of bilinearForward
    it looks perfect ( but probably aint)(but maybe is improvable )
    Fig 2
    remember that this is a 6000x3000 pixels image
    here's a non scaled down 2000x2000 area of the image
    i cant see visible defects so far
    Fig 3 i loaded the GuardHouse that comes with Poser
    here again i rendered in Hardware/OpenGL mode and the way the camera angles interact with Specular surfaces
    created problems - so you'll have to either turn off specularity on large flat surfaces or render in software mode
    animating the camera takes 1 second
    hardware rendering the 72 512x512 tiles takes less than a minute
    generating the batch file for the next phase takes 1 second
    processing the 72 tiles takes a minute or 2 (batch file+imagemagick)
    assembling the mosaic takes a few seconds (batch file+imagemagick)
    note that Renderman i.e. 3Delight have the possibility
    to use a spherical render camera
    sphere
    Spherical camera projection. Valid parameters:
    RIB declaration:
    Projection "sphere" "float hsweep" [360] "float vsweep" [180]
    so someone someday should make one for Daz Studio
    if it's not already done
    but my script solution has the advantage that you can render the Daz Studio tiles in Blender Cycles (
    1920 x 1080 - 744K
    2000 x 1000 - 291K
    2000 x 2000 - 463K
    2000 x 1000 - 346K
    edited June 2015
    so the name is chosen mcjSphericalCam.dsa
    you'll be able to create the camera animation in Daz Studio
    and prepare two batch files named cropStretch.bat and montage.bat
    the camera animation can be exported
    so you could render your tiles in Daz Studio 1, 2, 3, 4 Blender, Poser or Carrara
    Once the (usually 72) tiles are rendered
    you can run the batch file cropStretch.bat
    and imagemagick will massage the 72 tiles
    then you can run the batch file montage.bat
    and imagemagick will assemble the (usually 6144x3072) mosaic and save it as a jpeg or png image
    the other popular format will probably be 128 tiles (16x8 ) and a mosaic size of 8192x4096
    1460 x 195 - 88K
    1470 x 648 - 85K
    1020 x 570 - 84K
    edited June 2015
    The script will help you adjust your render camera's focal length
    567 x 504 - 54K
    aperture science brings you the auto focal length button
    there was cake, it was a blackforest cake, with delicious cherries and chocolate scrapings on top
    576 x 536 - 56K
  • josejonesfilmsjosejonesfilms Posts: 2
    this is some amazing work guys, how hard is this to implement and try out in Daz3d at the moment?
    Did you also say it could be used in Blender?
    edited June 2015
    i'm currently working on something else, but i expect that tomorrow
    i'll finish this here
    usage will be
    - get and install imagemagick (not by me )
    - in daz studio, set up your scene
    - create and select your render camera (a normal camera)
    - run the script
    - it creates a 72 or 128 frames camera animation, it's the camera looking in 72 directions
    - render the 72 frames
    - use the script and imagemagick to process the 72 renders
    - use the script/image magick to assemble the 72 images into one big 6000x3000 pixels image
    this image can be applied to a sphere in Daz Studio or to Blender's "World Environment"
    it's just a painted sphere, but when you're at the center, and it gives the illusion that you're in the original daz scene
    and in the case of Blender or Daz Studio IRAY or Daz Studio-Uber-Environment
    that sphere can actually be used as lighting
    adding fake shadows is harder, except in Daz Studio IRAY it's super easy ( but just the floor shadows )
    1920 x 1080 - 1M
    expected release June 20th eastern time zone's evening
  • atticanneatticanne Posts: 3,009
    Great! I'll be watching for it.
    edited June 2015
    i wrote and tested the camera animation exporter for DS 1,2,3,4
    next i do the Poser and Blender camera animation exporters, test them once
    then there's a few odds and ends to do
    then i write the 1 page manual and release !
    unrelated image, Amy and the propeller-skater-skirt
    600 x 600 - 456K
    edited June 2015
    doing a 128-tiles render in Blender ... seems to work fine
    and Blender has HDR and EXR and 16 bit formats, so, possibly ( not sure !) one could build true HDR skyballs in Blender
    so it will work like this
    create the camera animation using the mcjSphericalCam script in Daz Studio
    still in Daz Studio mcjSphericalCam, export the camera animation as a blender python script blendcamanim.py
    in Blender, select a camera, open and run blendcamanim.py
    render the 72 or 128 frames (tiles) at a resolution like 512x512
    assemble the rendered tiles into the 8192x4096 mozaic
    using a batch file supplied by the mcjSphericalCam script
    and the freeware image processing utility imagemagick
    since the image tiles can come from "foreign" sources like Blender, Poser and Carrara
    there will be 2 special buttons named
    "Create foreign mcjMontage.bat"
    and
    "run foreign mcjMontage.bat"
    you'll select the first of the rendered images, the mcjSphericalCam will
    try to figure the tile sizes and column/rows to build the mosaic
    fig 2 - mcjSphericalCam generated mcjMontage .bat
    which assembled (using imagemagick) the 8K x 4K pixel mozaic
    That's not the final product !
    but is shows that the camera rotated in the proper direction
    the script will even be able to handle bizarre sequences like images from browsers
    this is the batch file montage_cbk.bat which produces the mosaic montage_cbk.jpg
    "c:/imagemagick/montage.exe"  -geometry +0+0 -tile 12x6 cbk.jpg cbk(1).jpg cbk(2).jpg cbk(3).jpg
    2000 x 1000 - 307K
    512 x 512 - 34K
    edited June 2015
    tada !
    the camera animation was created in Daz Studio, using mcjSphericalCam
    then exported as a Blender python script
    then in blender the camera animation was applied to a camera
    an image processing batch file was created in Daz Studio, using mcjSphericalCam
    this batch file was executed, and with the help of imageMagick 128 new cropped-and-stretched tiles were produced
    another image processing batch file was created in Daz Studio, using mcjSphericalCam
    this batch file was executed, and with the help of imageMagick the 8192x4096 spherical panorama was created
    the bottom row tiles will be improved
    fig2 the spherical panorama applied to a sphere in Daz Studio and a "real figure" no shadows but that can be done with iray, or using Carnite's method https://www.youtube.com/watch?v=qo2OVy9tf8E
    fig 3 - not sure why yet but i had to stretch the sky-sphere vertically to get the white balls to be circular
    fig 4 - well looks like the problem is my sky-sphere object in daz studio and its UV coordinates
    or, it's inevitable that objects not at far distances break the illusion
    But, mcjSphericalUVs seems to be doing good work
    soooo
    1000 x 1000 - 141K
    1920 x 1080 - 842K
    1920 x 1080 - 727K
    2000 x 1000 - 230K
  • RAMWolffRAMWolff Posts: 10,386
    This newest project is coming along very nicely Casual. It will be so cool to make my own HDR files.... Now will I be able to export in the native .hdr format or just a image file?
