Where are the Iray Uber Shaders???
amulackamulack Posts: 11
Where can I get the! Iray Uber Shader Base and all other iray shaders for manual download? I can not find it anywhere. :-O
Thanks.
  • RedzRedz Posts: 1,459
    I believe the shaders and lights weren't included in the 4.8 download but will be available as a DIM update soon (hopefully today)
  • amulackamulack Posts: 11
    Now, the new Default Lights and Shaders for DAZ Studio 4.8+ are in the product library in DAZ Studio 4.8 Pro and we can manually downlod it.
    Thank you DAZ!
  • JoltrastJoltrast Posts: 208
    edited June 2015
    Thank you DAZ!
    I have 4.8 installed (not beta) and don't have the Iray Uber Shaders. Where can I manually download them please? Thanks!
    EDIT:
    Nevermind, I found them in my Poser folder.
    Post edited by Joltrast on
  • Richard HaseltineRichard Haseltine Posts: 111,315
    Joltrast said:
    Thank you DAZ!
    Default Lights and Shaders. The optimised settings for G2F and g2M are in the Genesis 2 Starter Essentials packages.
    edited June 2015
    I can't find optimised settings in the G2F Starter Essentials. There's a lot in there though, but mostly props, characters and lights for Barefoot Dancer.
    I've just looked in G2M starter essentials though and they are in there under "Phillip"!?
    I have also found Low/Medium and High render settings, for Barefoot Dancer.
    You have downloaded the updated versions? Released a day or two after the production build of DS 4.8.
    edited June 2015
    Double post
    edited June 2015
    Once I knew what the thumbnail looked like http://images.thinkdrawart.com/wp-content/uploads/2015/05/DazStudioIrayMaterials6.jpg
    I did a search for it and again, it's tucked away in a Poser directory that I never use!
    At least I know it's there now. Is there an easy way to move it?
    Is it safe to edit the base path?
    Thanks again!
    Yes, my Runtime is a whole scary mess, but I daren't mess with it in case I lose my old stuff!
  • AnotherUserNameAnotherUserName Posts: 2,727
    Thanks again!
    What directory did you find them in? Ive been looking for them for days.
    Thanks again!
    Well my directory is unlikely to look like yours, but you can try:
    %\Shader Presets/Daz Uber
    %\content\People\Genesis 2 Female\Materials\Iray
    You'd probably be quicker running at search in the search box at the top of the directory tree. It was the only way I found mine!
    You shouldn't be seeing the Content folder in the path, and the files shouldn't be in a Runtime folder. Those suggest an installation issue.
    edited June 2015
    My runtime is a bit of a mess, i know that, but I daren't move anything. Last time I tried I lost a lot of my older content.
    I'd pay someone to fix it though!
  • HeraHera Posts: 1,970
    edited June 2015
    Where do you find them though? I'm mainly looking for the !Iray Uber Base
    And is there any good shader for making water?
    Post edited by Hera on
    DAZ Studio Formats>My DAZ 3D Library>Shader Presets>Iray, assuming you installed to My DAZ 3D Library. There are a couple of basic water presets, but for different situations rather than for different looking waters.
    edited June 2015
    I found it, but it was nowhere where I thought it was ;-) - now I', moving them to Shader Presents so I'll be able to find them in the future.
  • sandmanmaxsandmanmax Posts: 992
    So I need to download the Genesis 2 Starter Essentials to get the updated shaders for G2F and G2M?  Just that one?  Or do I need also download V6 and Lillith 6 and all other Genesis 2 characters I've bought?
    The Starter Esentials have the presets for the figures, and the Default Lights and Shaders has the actual shader code. As far as I am aware none of the characters from before the release of Iray has been updated with new presets for Iray.
    Do those other pre-Iray characters need a preset for each one? I've just been using the Uber Shader Base on all my G2 figures, and the renders so far have all been pretty much what I expected a correct conversion to look like. They compare well with the differences between a 3Delight render and an Iray render (with preset) of the G2 base texture.
    I'd say each individual skin texture set should probably have its own preset...
